SSQ-108-21-G-S
SSQ-108-21-G-S
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 间距:2.54mm 插件
SSQ-108-21-G-S 数据手册
THROUGH-HOLE .025" SQ POST SOCKET 8 G b p s (2.54 mm) .100" PITCH • SSW/SSQ SERIES SSW/SSQ SERIES Mates: TSW, MTSW, MTLW, DW, EW, ZW, TSS, ZSS, TSM, TSSH, HTSS -1 SSW 01 thru 50 = Solder Tail SPECIFICATIONS SSQ Insulator Material: Black Liquid Crystal Polymer (-S & -D) or Black High Temperature Thermoplastic (-T) Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (SSW/TSM): 4.7 A per pin (2 pins powered) Current Rating (SSQ/TSW): 6.3 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" Max Cycles: 100 with 10 µ" (0.25 µm) Au Voltage Rating: 465 VAC / 655 VDC - NO. PINS PER ROW = Square Tail LEAD STYLE Specify LEAD STYLE from chart - PLATING OPTION - –F –S = Gold flash on contact, Matte Tin on tail = Single Row –P = Single Row (36 pins max –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –D –G Lead–Free Solderable: Yes: -S and -D row option No, Lead Wave only: -P, -T and -Q row option —T = Locking Lead Available on tails from (2.29 mm) .090" to (7.87 mm) .310" only. Not Available with single row 1 or 2 positions) –RA = Rightangle –Q “XXX” = Polarized (Specify “XXX” as position number) THROUGH-HOLE SINGLE DOUBLE Standard Low OR TRIPLE Insertion Insertion A Force Force* LEAD STYLE –01 –21 (2.64) .104 –02 –22 (4.93) .194 –03 –23 (10.00) .394 –04 –24 (14.83) .584 –06** N/A (3.15) .124 (2.54) .100 PROCESSING –LL Leave blank for straight pin version) = Double Row .200" (5.08 mm) row space (outer rows filled only) (2.54) .100 x No. of Positions + (0.51) .020 (4.95) .195 OTHER OPTION –T = Matte Tin (-T N/A on LIF contacts) —D - = Triple Row –T (2.41) .095 TAIL OPTION = Double Row = 20 µ" (0.51 µm) Gold on contact, Gold flash on tail —S - ROW OPTION * LIF not available with Tin Plating **Style –06 Not available with SSQ (7.49) .295 —S & —P —D —T —Q (8.51) .335 —Q (7.49) .295 Through-hole LEAD STYLE A A SINGLE DOUBLE TRIPLE (–S ) (–D ) (–T & –Q ) B B B (2.54) .100 –02 –22 (2.54) .100 (2.54) .100 –03 –23 (7.62) .300 (7.62) .300 N/A –04 –24 (12.45) .490 N/A N/A A Straight Pin Versions Right-angle RIGHT-ANGLE Standard Low Insertion Insertion Force Force* A —S & —P B —D B —T B —Q B *LIF not available with Tin Plating Note: Some lengths, styles and options are non-standard, non-returnable. F-224 Right-angle Versions samtec.com?SSW or samtec.com?SSQ Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. (8.51) .335
SSQ-108-21-G-S 价格&库存
很抱歉,暂时无法提供与“SSQ-108-21-G-S”相匹配的价格&库存,您可以联系我们找货
