F-215
SSW–125–01–G–S
SSQ–116–03–L–T
(2,54 mm) .100"
THROUGH-HOLE .025" SQ POST SOCKET
SPECIFICATIONS
For complete specifications
see www.samtec.com?SSW
or www.samtec.com?SSQ
Insulator Material:
Black Liquid Crystal Polymer
(-S & -D) or
Black High Temperature
Thermoplastic (-T)
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Current Rating (TSW/SSW):
5.7 A per pin
(1 pin powered per row)
Current Rating (SSQ/TSW):
6.3 A per pin
Operating Temp Range:
-55°C to +125°C with Gold
-55°C to +105°C with Tin
Contact Resistance: 10 mΩ
Insertion Depth:
(3,68 mm) .145" to
(6,35 mm) .250"
Insertion Force:
(Single contact only)
(–S plating)
Standard= 6 oz (1,67 N) avg
((0,64 mm) .025" SQ pin);
SSW Low Inser tion Force=
3 oz (0,83 N) avg
SSQ Low Insertion Force=
3.3 oz (0,92 N) avg
Normal Force:
Standard= 125 grams (4.4 N)
Withdrawal Force:
(–S plating)
Standard= 5 oz (1,39 N) avg
2.6 oz (0,72 N) avg
2.9 oz (0,81 N) avg
Max Cycles:
100 with 10µ" (0,25 µm) Au
Voltage Rating:
550 VAC mated with TSW
RoHS Compliant:
Yes
Lead-Free Solderable:
Yes
Mates With:
TSW, MTSW, MTLW,
EW, ZW, TSS, ZSS,
TSM, TSSH, HTSS
1
TYPE STRIP
PIN CENTERS
SSW = Solder Tail
–1 = (2,54 mm) .100" Centers
SSQ = Square Tail
(2,54)
.100
2
49
50
(2,41)
.095
–S
(2,54) .100 x No. of Positions + (0,51) .020
100
98
4
2
(2,54) (4,95)
.100 .195
–D
99
97
150
147
3
(2,54)
.100
6
1
3
(2,54)
.100 (5,08)
.200
–T
148
145
150
147
1
4
6
3
(5,08)
.200
–Q
148
145
(7,49)
.295
4
(7,49)
.295
1
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
(8.51)
.335
FILE NO: 090871_0_000
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(2,54) .100 x No. of Spaces
–RA
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
01
thru
50
NO. PINS
PER ROW
SSW–125–02–G–D–RA
SSW–130–01–G–S
SSW–113–02–T–T–RA
LEAD
STYLE
SSW–118–22–F–T
ROW
OPTION
PLATING
OPTION
TAIL
OPTION
–S
–F
–L
–LL
= Locking Lead
= Right Angle
(Leave blank
for straight pin
version)
–P
= 10µ" (0,25 µm) Gold on contact,
Matte Tin on tail
OTHER
OPTION
–RA
= Single Row
= Gold flash on contact,
Matte Tin on tail
SSW, SSQ SERIES
Two leads per strip crimped in opposite
directions on or near centerline.
Available on tails from (2,29 mm) .090"
to (7,87 mm) .310" only. N/A with single
row 1 or 2 positions.
= Single Row
(Notched to mate with LCW)
36 pins max
–D
–G
–“XXX”
= Double Row
= 20µ" (0,51 µm) Gold on contact,
Gold flash on tail
= Polarized
(Specify “XXX” as position number)
–T
–T
= Triple Row
= Matte Tin
(-T N/A on LIF contacts)
ALSO AVAILABLE
(MOQ Required)
–Q
• Other platings
• Notch option
Contact Samtec.
= Double Row
.200" (5,08 mm) row space
(Outer rows filled only)
Straight Pin Versions (Specify “LEAD STYLE” from chart)
SINGLE
DOUBLE
OR
TRIPLE
LEAD STYLE
–S & –P
Standard
Insertion
Force
Low
Insertion
Force*
–01
–21
–02
–22
(4,93) .194
–03
–23
(10,00) .394
–04
–24
(14,83) .584
–06**
N/A
(3,15) .124
–T
–D
–Q
A
(2,64) .104
A
(2,54)
.100
SSW
(0,41) x (0,79)
.016
.031
* LIF N/A with Tin Plating
**Style –06 N/A with SSQ
(5,08)
.200
(2,54)
.100
SSQ
(0,64) SQ
.025
(5,08)
.200
Right Angle Versions (Specify “LEAD STYLE” from chart)
– 22
– 03
– 23
– 04
–24
–Q
SINGLE DOUBLE TRIPLE
(–S & –P)
Standard
Low
Insertion Insertion
A
Force
Force*
– 02
–T
–D
–S & –P
LEAD STYLE
(2,54)
.100
(7,62)
.300
(12,45)
.490
(–D)
(–T & –Q)
A
A
(2,54)
.100
(7,62)
.300
(2,54)
.100
N/A
N/A
(1,52)
.060
A
A
A
A
N/A
SSW
SSQ
(0,41) x (0,79) (0,64)
.016
.031 .025 SQ
(2,54)
.100
*LIF N/A with Tin Plating
(2,54)
.100
WWW.SAMTEC.COM
(5,08)
.200
