SSW-118-22-F-T
SSW-118-22-F-T
    SAMTEC(申泰)
    .025 SOCKET STRIPS
SSW-118-22-F-T 数据手册
SURFACE MOUNT .025" SQ POST SOCKET 8 G b p s (2.54 mm) .100" PITCH • SSW SERIES SSW Mates: TSW, MTSW, HTSW, HMTSW, MTLW, EW, ZW, TSS, HTSS, ZSS, TSM, TSSH, DW, HW SSW -1 NO. PINS PER ROW - 22 02 thru 36 SPECIFICATIONS - - PLATING OPTION –F = Gold flash on contact, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (SSW/TSM): 4.7 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" Max Cycles: 100 with 10 µ" (0.25 µm) Au Voltage Rating: 465 VAC / 655 VDC ROW OPTION - VS OTHER OPTION –S –“XX” = Single Row = Polarized Position –K –D = –S: (3.50 mm) .138" DIA, –D: (6.50 mm) .256" DIA Polyimide film Pick & Place Pad (03 positions min.) = Double Row –G = 20 µ" (0.51 µm) Gold on contact, Gold flash on tail –P = Pick & Place Pad (05 positions min.) –TR = Tape & Reel (–02 thru –28) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–02 thru –28) PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max -  [1RRI3RVLWLRQV       ALSO AVAILABLE —P OPTION MOQ Required Other platings Notch option            —S   —D Note: Some lengths, styles and options are non-standard, non-returnable. samtec.com?SSW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
SSW-118-22-F-T 价格&库存
很抱歉,暂时无法提供与“SSW-118-22-F-T”相匹配的价格&库存,您可以联系我们找货
