TCSD-05-S-22.00-01-N
    SAMTEC(申泰)
    2MM DOUBLE ROW FEMALE IDC ASSEMB
TCSD-05-S-22.00-01-N 数据手册
TIGER ™ IDC EYE TIGER EYE™ IDC SOCKET CABLE (2.00 mm) .0787" PITCH • TCSD SERIES TCSD Mates: TMM, TMMH, STMM, MMT, TW, MTMM, EHT, ETMM (-SR), ZSTMM SPECIFICATIONS Insulator Material: Black Glass Filled Polyester Contact: BeCu Plating: Au or Sn over 50 µ" (1.27 µm) Ni Wire: 28 AWG 7/36 Stranded, Tinned, Copper with Gray PVC Insulator Current Rating (TCSD/STMM): 2.8 A per pin (2 pins powered) Operating Temp Range: -40 °C to +105 °C Lead Size Accepted: (0.48 mm) .019" to (0.53 mm) .021" Insertion Depth: (2.87 mm) .113" to (3.17 mm) .125" ALSO AVAILABLE SERIES TCSD = Socket Strip - NO. PINS PER ROW - –04, –05, –07, –08, –10, –12, –13, –15, –17, –20, –22, –25 END OPTION –S = Single End - OVERALL LENGTH - 01 - –“XX.XX” PLATING OPTION Leave blank for standard plating 30 µ" (0.76 µm) Gold on contact area = Assembled Length –D = Double End - –N = Notch Polarization –F (Standard sizes) OTHER OPTION –P “XX” = Position Polarization (Specify “XX” as position number. Same position will be polarized on both ends) –B “XX” = Gold flash on contact = Breakout (Specify “XX” as number of conductors to be broken out) –RW = Reverse Wiring (Blue or black wire opposite position #1) 01 –D “XX” (4.00) .158 = Daisy Chain –SR No. of positions x (2.00) .0787 + (4.00) .157 = Strain Relief (Not available with –O, –M, –R, –DXX or –BXX) (5.08) .200 –R MOQ Required = Reversed Other sizes Other platings –M = Middle Reversed (Requires –DXX) Assembled Length in INCHES (±1/8") 1 inch minimum –O POLARIZING KEY Specify PK-01-07 for polarizing key (Available in wheels of six each). Also polarizes SMM Series socket strips. - N = Outside Reversed (Requires –DXX) Single End (—S) Double End (—D) Assembled Length (—“XX.XX”) 2" min. 01 5"max. 2"min. Breakout starts with Number 1 lead indicated by brown wire or red stripe. Shown on top side. Breakout (—B “XX”) 1/8" Double Row Connectors “XX” 02 Position Polarization (—P “XX”) “XX” 01 02 Reverse Wiring (—RW) 4" minimum Outer Most (End of assembly) Daisy Chain (—D “XX”) No. of positions x (2.00) .0787 + (7.874) .3100 Note: TCSD Series assemblies are non-standard, non-returnable. F-224 Strain Relief (—SR) Reversed —R) Middle Reversed (—M) Outside Reversed (—O) samtec.com?TCSD Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TCSD-05-S-22.00-01-N 价格&库存
很抱歉,暂时无法提供与“TCSD-05-S-22.00-01-N”相匹配的价格&库存,您可以联系我们找货
