TFM-115-22-L-D-A-K-TR 数据手册
RUGGED TIGER EYE™ SYSTEMS
(1.27 mm) .050" PITCH
MAX
8
3.7
A
m
p
G b p s
s
FEATURES & BENEFITS
• S
crew down, locking clip, friction latching and
weld tab ruggedizing options
• Shrouded, polarized and keyed
• Surface mount or through-hole tails
• High-density, four row design (FOLC/MOLC Series)
• Discrete wire assemblies available in single or double row,
28 and 30 AWG PVC or *Teflon™ Fluoropolymer (See pages 238-239).
Contact asp@samtec.com for custom solutions.
• Cable components (ISDF/CC03) and tooling available: samtec.com/tooling
• Severe Environment Testing qualified (SFM/TFM); aligns with MIL-DTL-55302.
Visit samtec.com/set
*Teflon™ is a trademark of The Chemours Company FC, LLC
used under license by Samtec.
KEY SPECIFICATIONS
SERIES
STACK
INSULATOR
HEIGHTS MATERIAL
CONTACT
MATERIAL
BeCu (SFM)
SFM/TFM 6 to 12 mm
Black LCP
SFC/TFC
Black LCP
6 to 12 mm
F-224 (Rev 04APR24)
Phosphor
Bronze (TFM)
Phosphor
Bronze
IDC cable
assemblies with
rugged strain relief
(FFSD/FFMD, FFTP/FMTP)
Locking for
increased
unmating force
(SFML/TFML)
PLATING
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
MAX.
CYCLES
LEAD-FREE
SOLDERABLE
Au or Sn
over 50 µ"
(1.27 µm) Ni
-55 °C to +125 °C
3.7A per pin
(2 pins powered)
275 VAC
10,000
with 30 µ"
(0.76 µm) Au
Yes
Au or Sn
over 50 µ"
(1.27 µm) Ni
-55 °C to +125 °C
3.1 A per pin
(2 pins powered)
350 VAC
(Call Samtec for
E.L.P.™ plating
option)
Yes
samtec.com/127mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MAX
3.7
A
(1.27 mm) .050" • SMT/THROUGH-HOLE HEADER
SERIES
-1
TFM
NO. PINS
PER ROW
03, 04,
06, 08
= Standard
(TFM –01 &
–02 only)
TFML
= Locking
(–01 & –02
lead style
only)
05, 07,
10, 15, 20,
25, 30, 35,
40, 45, 50
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
–L
= 15 µ"
(0.38 µm)
Gold on post,
Matte Tin on tail
(Call Samtec
for E.L.P.™
plating option)
(Standard sizes)
TFM
TFML
Board Mates:
SFML
Cable Mates:
SFSD,
TFSD (-T end option)
1RRI3RVLWLRQV
Specify only –RA,
–RE1 or –RE2
–D
= Right-angle
(Lead style
–01 only)
= Double Row
–DH*
= Double
Horizontal
(TFM lead
style –02 only)
(05 thru 50
positions only)
(–TR or –FR
option only
available)
–RE1
= Right-angle
Elevated for
(1.60 mm) .062" PCB
(Requires TFM
lead style –01,
–D row and –WT)
(9.91) .390
(11.81) .465
LEAD STYLE (T/H)
MATED HEIGHT*
TFM
SFM
-01
(5.97) .235
–03
(5.97) .235
-11
(7.75) .305
-13
(7.75) .305
-01
-21
(9.53) .375
-23
(9.53) .375
-31
(11.43) .450
*Processing conditions will affect mated height.
DOUBLE ROW
LEAD STYLE (SMT)
A
–02
(5.72) .225
–12*
(7.49) .295
–22*
(9.27) .365
–32*
(11.18) .440
* N/A with 07, -DH or -S row option
SURFACE MOUNT
–WT
–RA
(8.13) .320
-02
-32
1RRI3RVLWLRQV
6HHZHEVLWHIRU²5(;
²'+²'6²:72$/
–A
8
G b p s
OPTIONS
–S
= Single Row
(TFM only)
-22
SINGLE ROW
–LC
s
ROW
OPTION
–12
THROUGH-HOLE
p
SMT lead styles only
Specify only –A,
Specify only –K or –P
–LC, –DS or –WT
Not available with –RA,
–RE1 and –RE2 unless
–K
otherwise noted.
= Polyimide Film
Pick & Place Pad
–A
= Alignment Pin
–LC
= Locking Clip
(Manual Placement
required)
–P
= Plastic Pick
& Place Pad
(5 positions min.)
(Not available with
5 position with –WT)
Specify –TR or -FR last
–DS
(Not available with –DS)
= Dual
–RE2
Screw Down
= Right-angle
–TR
for (1.60 mm)
Elevated for
= Tape & Reel
.062" PCB
(2.36 mm) .093" PCB (05, 07, 10, 15, 20,
(Requires TFM lead
25, 30, 35, 40
–FR
style –01, –D row
positions only)
= Full Reel
and –WT)
(TFM lead styles
Tape & Reel
–01 and –02 only)
(must order max.
(Requires –D
quantity per reel;
row option)
contact Samtec for
(Mates with
quantity breaks)
MATED HEIGHTS*
SFM–DS option and
SFSD/SFSDT –SS and
LEAD STYLE (SMT)
–DS option only)
MATED HEIGHT*
TFM
SFM
(Not available with –A,
–LC, –WT, –K, –P, –XR)
-02
(6.35) .250
Board Mates:
SFM, SFMC
Cable Mates:
SFSD, SFSS
m
–DS
LEAD STYLE
(T/H)
–WT
= Weld Tab
(TFM lead styles
–01 and –02 only)
(Required callout
for –RE1 & –RE2)
(Mates to SFSS/SFSD
–SR and –DR
option only)
25, 30, 35, 40, 45, 50
positions only)
B
C
–01
(5.59) .220 (1.97) .078
–03*
(5.59) .220 (2.77) .109
–11*
(7.37) .290 (1.97) .078
–13*
(7.37) .290 (2.77) .109
–21*
(9.14) .360 (1.97) .078
–23*
(9.14) .360 (2.77) .109
–31*
(11.05) .435 (1.97) .078
* Not Available with 07 or -S row option
–DH*
–RA
–RE1 & –RE2
Notes:
(TFM); aligns with MIL-DTL-55302.
Some lengths, styles and options are
non-standard, non-returnable.
View complete specifications at: samtec.com?TFM & samtec.com?TFML
F-224 (Rev 04APR24)
