TFML-135-02-S-D-A
TFML-135-02-S-D-A
    SAMTEC(申泰)
    CONN HEADER SMD 70POS 1.27MM
TFML-135-02-S-D-A 数据手册
F-215 TFM–115–02–L–S TFM–110–02–L–D–LC ™ SYSTEM TFM–110–01–L–D–RE1–WT TFML–115–02–L–D–K (1,27 mm) .050" SMT & THROUGH-HOLE HEADER SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?TFM or www.samtec.com?TFML Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating (TFM/SFM): 3.2 A per pin (1 pin powered per row) Voltage Rating: 250 VAC mated with SFM Operating Temp Range: -55°C to +125°C RoHS Compliant: Yes Shrouded body for blind mating TFM Mates with: SFM, SFMC, SFSD (1,27 mm x 1,27 mm) .050" x .050" micro pitch TFML Mates with: SFML TFM-DH Mates with: SFM (-DH), SFMC, SFSDX (–S, -D, -SR, -DR) APPLICATIONS TFM-DH to SFM-DH SHOWN Processing: Surface mount or Through-hole tails Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (05-25) (0,15 mm) .006" max (30-50) TFM to SFM-SH SHOWN RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality TYPE STRIP NO. PINS PER ROW 1 MATED HEIGHT LEAD STYLE TFM –02 –12 –22 –32 SFM –02 (8,13) .320 (9,91) .390 TFML 05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 = Locking (–01 & –02 lead style only) (1,27) .050 x No. of Positions + (3,18) .125 MATED HEIGHT* (5,97) .235 (5,97) .235 (7,75) .305 –01 (7,75) .305 (9,53) .375 (9,53) .375 (11,43) .450 *Processing conditions will affect mated height. OTHER SOLUTIONS • Lower cost plating options. See TFC Series. LEAD STYLE (T/H) B C (5,59) (1,97) .220 .078 (2,77) –03* (5,59) .220 .109 (1,97) –11* (7,37) .290 .078 (2,77) –13* (7,37) .290 .109 (9,14) (1,97) –21* .360 .078 (2,77) –23* (9,14) .360 .109 (1,97) –31* (11,05) .435 .078 * N/A with 07 or -S row option (2,79) .110 (4,45) .175 LEAD STYLE 01 (SMT) (See website for –DS & –WT OAL) –REX = (1,27) .050 x No. of Positions + (6,68) .263 –02 –12* –22* –32* SINGLE ROW –01 (1,27) .050 02 01 DOUBLE ROW A (1,14) .045 (5,72) .225 (7,49) .295 (9,27) .365 (11,18) .440 * N/A with 07, -DH or -S row option (5,72) .225 (1,27) .050 DIA –A (SMT or TH) (1,27) .050 (0,46) .018 DIA B (1,40) .055 A C Note: Some sizes, styles and options are non-standard, non-returnable. = 15µ" (0,38 µm) Gold on post, Matte Tin on tail (Call Samtec for E.L.P.™ plating option) (Standard sizes) (11,81) .465 LEAD STYLE TFM SFM –01 –03 –11 –13 –21 –23 –31 = Standard MATED HEIGHT* (6,35) .250 (TFM –01 & –02 only) TFM –L Specify LEAD STYLE from chart 03, 04, 06, 08 FILE NO: 090871_0_000 PLATING OPTION LEAD STYLE (0,36) .014 THROUGH-HOLE SURFACE MOUNT (1,42) .056 –LC (SMT or TH) WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (2,35) (0,64) .093 .025 –WT (–01 & –02 ONLY) TFM–105–01–L–D–RA TFML–150–01–L–D–LC TFM–125–01–L–D–WT TFM–110–02–L–DH TFM–110–02–L–D–DS TFM, TFML SERIES Shrouded body for blind mating (1,27 mm) .050" pitch • Passes 10 Year MFG • Locking option Surface mount or Through-hole tails • Locking clip option • Weld tab option Screw down option ROW OPTION Weld tab option • Screw Down option OPTION –S Specify only –RA, –RE1 or –RE2 –RA = Single Row (TFM only) = Right Angle (Lead style –01 only) –D Specify only –A, –LC, –DS or –WT Not available with –RA, –RE1 and –RE2 unless otherwise noted. –A SMT lead styles only Specify only –K or –P –K = Polyimide Film Pick & Place Pad = Alignment Pin = Double Row –RE1 –DH* = Right Angle Elevated for (1,58 mm) .062" PCB (Requires TFM lead style –01, –D row and –WT) = Double Horizontal (TFM lead style –02 only) (05 thru 50 positions only) (–TR option only available) (0,76) .030 (2,26) .089 (1,91) .075 (0,51) .020 –RA (6,48) .255 (1,99) .079 –DS (–D, –01 & –02 ONLY) –LC = Locking Clip (Manual Placement required) –RE2 = Right Angle Elevated for (2,36 mm) .093" PCB (Requires TFM lead style –01, –D row and –WT) –DH* (3,81) .150 Mates with SFM for coplanar mating –RE1 & –RE2 (1,27) .050 –DS = Dual Screw Down for (1,60 mm) .062" PCB (05, 07, 10, 15, 20, 25, 30, 35, 40 positions only) (TFM lead styles –01 and –02 only) (Requires –D row option) (Mates with SFM–DS option and SFSD/SFSDT –SS and –DS option only) (Not available with –A, –LC, –WT, –K, –P, –TR) –WT = Weld Tab (TFM lead styles –01 and –02 only) (Required callout for –RE1 & –RE2) (Mates to SFSS/SFSD –SR and –DR option only) (05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 positions only) * Note: Weld tab is standard on –DH option. No need to specify –WT. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –P = Plastic Pick & Place Pad (5 positions minimum) (Not available with 5 position with –WT) Specify –TR last –TR = Tape & Reel (Not available with –DS) ALSO AVAILABLE (MOQ Required) • Solder nail option • Other sizes • Other platings Contact Samtec.
TFML-135-02-S-D-A 价格&库存
很抱歉,暂时无法提供与“TFML-135-02-S-D-A”相匹配的价格&库存,您可以联系我们找货
