F-215 (Rev 26AUG15)
HTSW–116–11–G–S
TSW–209–09–F–S–RA
HTSW–115–05–L–Q
(2.54 mm) .100"
THROUGH-HOLE .025" SQ POST HEADER
Mates with:
SSW, SSQ, SSM, ESW, ESQ,
BCS, BSW, CES, SLW, IDSD,
IDSS, SMSD, SMSS
SPECIFICATIONS
For complete specifications
see www.samtec.com?TSW
or www.samtec.com?HTSW
Insulator Material:
TSW: Black Glass Filled Polyester
HTSW: Natural Liquid
Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over 50µ" (1.27 µm) Ni
Operating Temp Range:
-55°C to +125°C with Gold
-55°C to +105°C with Tin
Voltage Rating:
550 VAC mated with SSW;
500 VAC mated with
BCS or ESQ;
450 VAC -RA/-RE mated with
BCS or SSM
400 VAC mated with CES
RoHS Compliant: Yes
Lead–Free Solderable:
HTSW: Yes
TSW: Wave Only
TYPE STRIP
(2.54 mm) Centers,
–1 = .100"
All Positions Filled
TSW = Standard
Strip
HTSW
(5.08)
.200
(2.54)
.100
(2.54)
.100
50
02
(2.54)
.100
100
(2.54) (5.02)
.100 .198
–D
99
150
(2.54)
(7.62) .100
.300
(5.08) (7.56)
.200 .298
01
03
–T
148
150
(5.08) (7.56)
.200 .298
(7.62)
.300
–Q
5.2 A 5.7 A 5.2 A 6.3 A 5.2 A 4.6 A 4.3 A
1 POSITION POWERED PER ROW
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
FILE NO: 090871_0_000
01
Right
Angle
Versions
–S
01
01
03
CURRENT RATING
(PER PIN)
TSW mated with
(2.54)
.100
(2.48)
.098
(5.08)
.200
ESW SSW SLW SSQ SSM BCS SNT
(5.08 mm) Centers,
– 2 = .200"
Every Other Position Filled
= Hi-Temp
Strip
(2.54) .100 x No. of Positions
Straight
Pin
Versions
NO. PINS
PER ROW
PIN CENTERS
TSW
148
= .100" (2.54 mm)
Center Version
HTSW
(2.54)
.100
(3.02)
.119 (1.78)
.070
(3.09)
(1.78) .122
.070
–S
01
BCS
TSW
HORIZONTAL
ALSO AVAILABLE
50
(2.54)
.100
(6.10)
.240
(1.78)
.070
(5.56)
.219
(1.78)
.070
(8.12)
.320
01
99
03
150
(2.54)
.100
(5.08)
.200
01
148
03
150
(5.08)
.200
(8.12)
.320
(8.10)
.319
01
TSW
HTSW
02
thru
25
= .200" (5.08 mm)
Center Version
–T
–Q
(1.78)
.070
(1.78)
.070
Note: Some lengths,
styles and options are
non-standard, non-returnable.
(8.10)
.319
–D
(1.78)
.070
(1.78)
.070
(MOQ Required)
• Other platings
Contact Samtec.
100
02
APPLICATIONS
01
thru
50
148
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
TSW–109–10–F–D–RA
TSW–114–16–G–S–RE
HTSW–120–13–T–D
TSW–112–07–G–T
TSW, HTSW SERIES
PLATING
OPTION
LEAD
STYLE
ROW
OPTION
OTHER OPTIONS
–S
–F
–L
–NA
= Right Angle
(using straight body for coplanar
mating with SSW-RA series)
= Double
Row
–G
= 10µ" (0.25 µm) Gold on post, Gold flash on balance
–T
–T
= Triple
Row
= Locking Clip
(Styles –08 thru
–13 & –22 only)
= Right Angle
–D
= 10µ" (0.25 µm) Gold on post, Matte Tin on tail
–LC
– RA or –RE
= Single
Row
= Gold flash on post, Matte Tin on tail
IDSS or IDSD
STRIP ASSEMBLY
LOCKING
CLIP
.025" SQ
TERMINAL
STRIP (TSW)
PC
BOARD
Requires 4 pin minimum
(NA with -T,-Q,-RA or -RE)
(1.27)
.050
= Matte Tin
Straight Pin Versions
A
B
C
STYLE
– 05
(3.30)
.130
(2.41)
.095
(2.54)
.100
(5.08)
.200
(10.16)
.400
(12.70)
.500
(15.24)
.600
(17.78)
.700
(22.86)
.900
(8.51)
.335
(7.62)
.300
(10.92)
.430
(13.46)
.530
(18.54)
.730
(21.08)
.830
(23.62)
.930
(26.16)
1.030
(31.24)
1.230
(13.46)
.530
(2.67)
.105
(2.67)
.105
–18
– 06
– 07
– 08
– 09
–10
–11
–12
–13
–14
–15
–16
–17
(2.79)
.110
(7.87)
.310
(2.79)
.110
(18.54)
.730
(21.08)
.830
(5.84)
.230
(8.13)
.320
(13.21)
.520
(8.13)
.320
(15.74)
.620
–19
– 20
– 21
– 22
– 24
– 25
– 26
– 27
– 28
– 29
– 30
* Available with – LL
(Locking Lead) Option
(0.64) .025 SQ Post
(7.62)
.300
– 23
– 41
– 42
(2.92)
.115
(5.33)
.210
(3.20)
.126
(25.40)
1.000
(20.32)
.800
(23.11)
.910
(18.03)
.710
(0.89)
.035
(1.27)
.050
B
C
(23.62)
.930
(26.16)
1.030
(31.24)
1.230
(36.32)
1.430
(16.00)
.630
(11.30)
.445
(12.15)
.480
(16.00)
.630
(11.58)
.456
(33.78)
1.330
(28.70)
1.130
(33.78)
1.330
(28.70)
1.130
(9.27)
.365
(11.94)
.470
(18.29)
.720
(20.83)
.820
(25.91)
1.020
(30.99)
1.220
– 08
– 09
–10
–11
(5.84)
.230
(6.73)
.265
(8.13)
.320
(5.84)
.230
(8.13)
.320
(5.84)
.230
(8.13)
.320
SINGLE (– S)
–RA LEAD
STYLE
–12
–13
–16
– 21
– 22
– 25
– 27
– 28
– 29
– 30
A
(2.29)
.090
(7.37)
.290
(9.91)
.390
(12.45)
.490
(14.99)
.590
(20.07)
.790
(5.08)
.200
(25.15)
.990
(4.83)
.190
(2.54)
.100
(22.61)
.890
(17.53)
.690
(20.32)
.800
(15.24)
.600
DOUBLE (– D)
TRIPLE (–T & – Q)
A
A
(2.29)
.090
(7.37)
.290
(9.91)
.390
(12.45)
.490
(14.99)
.590
(20.07)
.790
(5.08)
.200
(2.29)
.090
(7.37)
.290
(9.91)
.390
(12.45)
.490
(14.99)
.590
C
(5.84)
.230
(8.13)
.320
(5.84)
.230
(8.13)
.320
(5.84)
.230
(8.13)
.320
with HTSW only.
B
(2.54)
.100
LEAD
STYLE
A
B
– RA (1.52)
.060
(0.64) .025 SQ Tail ▲
– RE
Specify -07 for best mate with IDXX Series IDC Cable
– 09
(4.83)
.190
(7.37)
.290
(9.91)
.390
(12.45)
.490
(17.53)
.690
(2.54)
.100
(22.61)
.890
(2.29)
.090
(20.07)
.790
(14.99)
.590
–10
–11
–12
–13
–16
– 21
N/A
N/A
– 22
(4.83)
.190
(2.54)
.100
(4.83)
.190
(2.54)
.100
– 27
– 28
N/A
A
C
(5.84)
.230
(8.13)
.320
(5.84)
.230
*Available with – LA
(17.53)
.690
N/A
N/A
(15.24)
.600
A
(0.46) .018 DIA Tail
SINGLE
(5.08)
.200
C
▲Except: Style –26
– RE LEAD
STYLE
N/A
+ Style –41 & –42 available
C
–“XXX”
= Polarized Position
(Specify “LEAD STYLE” from chart and select –RA or –RE from other options)
A
(2.79)
.110
Two leads per strip crimped in
opposite directions on or near
centerline. See charts for available
styles. N/A with single row 1 or 2
positions. Recommended hole size
(1.02 mm ± 0.03 mm) .040" ± .001"
Right Angle Versions
(Specify “LEAD STYLE” from chart)
STYLE
= –RA Option
with –LL Option
= Locking Lead
= Double
Row
(5.08 mm)
.200"
row
space
• Elevated Right Angle option
• Shunts
Contact Samtec
–LA
–LL
–Q
OTHER SOLUTIONS
(1.78)
.070
C
A
(2.54)
.100
B
(2.54)
.100
(4.06)
.160
WWW.SAMTEC.COM
(2.54)
.100
很抱歉,暂时无法提供与“TSW-101-23-T-D-LL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.831521+0.36630
- 50+2.3510250+0.30414
- 100+2.14509100+0.27750
- 500+2.03355500+0.26307
- 1000+1.621691000+0.20979
- 2000+1.553052000+0.20091
- 5000+1.441505000+0.18648
- 25000+1.4071825000+0.18204
