HTST-108-01-S-DV-A-TR
    SAMTEC(申泰)
    SMD
    线对板针座 立贴
HTST-108-01-S-DV-A-TR 数据手册
REVISION Y DO NOT SCALE FROM THIS PRINT HTST-1XX-01-XX-DV-XX-XX NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. ASSEMBLE GOLD PLATED END AS SHOWN. 3. TERMINAL PUSHOUT FORCE: 2 lbs BEFORE HEAT. 4. TERMINALS TO BE FLUSH TO .010[.25] BELOW TOP OF SHROUD. PACKAGING OPTION -TR: TAPE & REEL (POSITIONS -02 THRU -25 ONLY) No OF POSITIONS -02 THRU -36 (PER ROW) LEAD STYLE -01: SURFACE MOUNT (USE T-1S6-08-X-2) PLATING SPECIFICATION (VALUES GIVEN ARE IN MICRO-INCHES) -T: MATTE TIN, CONTACT AND TAIL -S: SELECTIVE, 30 Au / 50 NI MIN ON CONTACT, MATTE TIN TAIL -L: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL -H: HEAVY GOLD, 30 Au / 50 Ni MIN ON CONTACT, 3 Au / 50 NI MIN ON TAIL -F: FLASH SELECTIVE, 3 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL -TM: MATTE TIN CONTACT AND TAIL -SM: SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL -FM: FLASH SELECTIVE, 3 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL -LM: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON CONTACT, MATTE TIN TAIL {(No OF POS x .100[2.54]) + .300[7.62]} REF .100 2.54 REF {(No OF POS x .100[2.54]) + .200[5.08] REF 02 "A" 04 .365 9.27 REF OPTION -A: ALIGNMENT PIN (* ASO OPTION) (SEE FIG. 3 SHT. 2) -P: PICK & PLACE PAD (USE PPP-22) -XX: POLARIZATION OPTION (INDICATES POSITION OMITTED) ROW SPECIFICATION -DV: DOUBLE VERTICAL (USE HTST-XX-D) .250 6.35 REF 01 03 "A" .075 1.91 REF .100 2.54 REF FIG. 1 2° MAX SWAY (EITHER DIRECTION) HTST-XX-D FIRST POSITION INDICATOR SEE NOTE 4 HTST-120-01-X-DV SHOWN 2 MAX SWAY (EITHER DIRECTION) .200 5.08 REF Y +4° 90° - 2° .450 11.43 .250 6.35 REF .350 8.89 REF .400±.010 10.16±0.25 .165 4.19 REF (SEE NOTE 2) CL .025 0.64 SQ REF (TYP) IN-PROCESS VIEW 2 IN-PROCESS VIEW 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: +5° 90° - 0° .530 13.46 REF .635 16.13 .015 0.38 REF T-1S6-08-XX-2 .500 12.70 DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: .170 4.32 C1 .440±.010 11.18±0.25 SECTION "A"-"A" PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1.5:1 INSULATOR: LCP, UL 94 VO COLOR: NATURAL .440±.010 11.18±0.25 SEE TABLE 1 TERMINAL: PHOS BRONZE c:\enterprisevault\DWG\MISC\MKTG\HTST-1XX-01-XX-DV-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: HIGH TEMP TOP SHROUD DWG. NO. HTST-1XX-01-XX-DV-XX-XX BY: T. WERNE 07/11/2001 SHEET 1 OF 3 REVISION Y (((NO POS X .100) +.300) / 2 - .1875) +/- .020 .390 9.91 REF .375 9.53 REF .400 10.16 REF .450 11.43 FIG. 2 -P: PICK & PLACE PAD OPTION (SAME AS FIG. 1 UNLESS OTHERWISE STATED) .050 1.27 .100 2.54 REF (NO OF POS. x .100 [2.54]) -.200 [5.08] FULL R (TYP) .060 1.52 DIA REF FIG. 3 -A: ALIGNMENT PIN OPTION (SAME AS FIG. 1 UNLESS OTHERWISE STATED) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 c:\enterprisevault\DWG\MISC\MKTG\HTST-1XX-01-XX-DV-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: HIGH TEMP TOP SHROUD DWG. NO. HTST-1XX-01-XX-DV-XX-XX BY: T. WERNE 07/11/2001 SHEET 2 OF 3 REVISION Y POS. 1 ROUND HOLES "B" "B" OBLONG HOLES SECTION "B"-"B" SCALE 1 : 1 USER DIRECTION OF REELING POCKET NOT DETAILED TUBE VIEW TAPE & REEL VIEW TUBE: PT-1-24-02-08 PLUG: TP-13 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 c:\enterprisevault\DWG\MISC\MKTG\HTST-1XX-01-XX-DV-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: HIGH TEMP TOP SHROUD DWG. NO. HTST-1XX-01-XX-DV-XX-XX BY: T. WERNE 07/11/2001 SHEET 3 OF 3
HTST-108-01-S-DV-A-TR 价格&库存
很抱歉,暂时无法提供与“HTST-108-01-S-DV-A-TR”相匹配的价格&库存,您可以联系我们找货
