IDSS-14-D-10.00-G
IDSS-14-D-10.00-G
    SAMTEC(申泰)
    INSULATION DISPLACEMENT SOCKET C
IDSS-14-D-10.00-G 数据手册
F-215 IDMD–24–D–12.00–G (2,54 mm) .100" SLIM BODY FLAT RIBBON IDC CABLES SPECIFICATIONS For complete specifications see www.samtec.com?IDSS, www.samtec.com?IDSD, www.samtec.com?IDMS or www.samtec.com?IDMD Insulator Material: Black Glass Filled Polyester Plating: Au over 50µ" (1,27 µm) Ni or Sn over 100µ" (2,54 µm) Cu or 50µ" (1,27 µm) Ni Wire: 28 AWG 7/36 stranded Tinned Copper Temperature Range: -20°C to +105°C (Rainbow Cable) -40°C to +105°C (Gray Cable) Contact (IDSS/IDSD): BeCu Terminal (IDMS/IDMD): Phosphor Bronze Current Rating (IDSD/TST): 3.4 A per pin (1 position powered per row) Current Rating (IDMD): 3 A per pin (1 position powered per row) Contact Resistance: 15 mΩ Lead Size Range: (0,56 mm) .022" SQ to (0,71 mm) .028" SQ Lead Insertion Depth: (5,59 mm) .220" to (6,22 mm) .245" Insertion Force: (Single contact only) 4 oz (1,11 N) avg. ((0,64 mm) .025" SQ probe) Withdrawal Force: (Single contact only) 3 oz (0,83 N) avg. ((0,64 mm) .025" SQ probe) RoHS Compliant: Yes Mates with: TSW, MTSW, TSM, EJH, PHT, HMTSW, HTSW, HW, DW, EW, ZW, MTLW TYPE STRIP IDSD Mates with: TST, HTST, ZST, BST, EJH ROW OPTION NO. PINS PER ROW END ASSEMBLY S –S = Single End = Single D = Double (Color coded cable N/A for 31 thru 36 pins/row. See –G option.) IDM = Standard Tail Male Plug IDS = Socket Socket or Male Plug on one end –D = Double End –02 thru –32 DOUBLE Full size (64 positions): (82,55) 3.250 Less than 64 positions: No. Positions/row X (2,54) .100 + (1,68) .066 IDMD (Double) IDMS (Single) Socket or Male Plug on each end SINGLE Full size (32 positions): (81,53) 3.210 Less than 32 positions: No. Positions/row X (2,54) .100 + (0,71) .028 (2,54) .100 –T = Transfer End (5,08) .200 (6,10) .240 MAX (0,48) .019 (0,46) .018 x (0,48) .019 (3,18) .125 (2,54) .100 (2,54) .100 Male Plug on one end with socket on other. Begin part number with IDM. (For square or long tail see HCMX Series) OTHER SOLUTIONS RECOGNITIONS –02 thru –36 For complete scope of recognitions see www.samtec.com/quality DOUBLE Full size (72 positions): (92,71) 3.650 Less than 72 positions: No. Positions/row x (2,54) .100 + (1,50) .059 SINGLE Full size (36 positions): (91,69) 3.610 Less than 36 positions: No. Positions/row x (2,54) .100 + (0,48) .019 IDSS (Single) Molded-To-Position IDC Assemblies IDSD (Double) (5,08) .200 (9,27) .365 REF (2,54) .100 (0,76) .030 SQ (2,54) .100 Note: This Series is non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. • • • • • Low profile Skinny side locks Dual beam contacts Single and double row (3,05 mm) .120" and (5,84 mm) .230" length tail available Call Samtec for HCXX Series. IDSD–05–D–04.25–S02 IDSD–24–S–05.00 IDSS, IDSD, IDMS, IDMD SERIES ASSEMBLED LENGTH EJECTOR HEADERS & LOCKING CLIPS OPTION IDSS or IDSD STRIP ASSEMBLY – “XX.XX” • Locking clips POLARIZING KEY = Assembled Length (0,64) .025 SQ Assembled Length in INCHES (±1/8" ) (2 inches minimum) (5,84) .230 LOCKING CLIP Optional polarizing key for use with IDSS & IDSD Series. Also polarizes SSW, SSQ, ESW & ESQ Series. Black High Temperature Thermoplastic .025" SQ TERMINAL STRIP (TSW) PC BOARD See TSW Series. Order: Part Number PK-01-06 (Available in wheels of six each) Plating –T = Tin (Both ends) Tin IDM (0,25 µm) Gold IDS –C = 10µ" (-T End Assembly Required) • Ejector headers See EJH Series. –ST “X” –S “XX” –R = Stripped & Tinned = Daisy Chain Single = Reversed Specify Suffix from table. All dimensions are ± 1/16". Not available in 28 positions and higher. “XX” ± 1⁄8" 2" min. Single Row Connectors (IDSS) (0,25 µm) Gold IDM –A = 10µ" Tin IDS (-T End Assembly Required) Standard plating is selective gold over BeCu contact for IDS; Selective gold over phosphor bronze for IDM. Outer Most 4" minimum 1 –P “XX” =Polarized 72 04 –ST8 –ST4 –ST2 –ST3 1/8" (3,18) 1/4" (6,35) 1/2" (12,70) 3/8" (9,53) 4 –M = Middle Reversed 7 –D “XX” = Daisy Chain, Double = Breakout 03 8 02 –B “XX” 71 When mating double row connector with two single row connectors, the outer most single will be connected to Conductor #1 and the inside single to Conductor #2. 01 Specify “XX” as number of conductors to be broken out. Specify “XX” as position. For Double the same position will be polarized on both ends. (Not available on IDM unless transfer, then only the socket is polarized.) “XX” ± 1⁄8" 2" min. Double Row Connectors (IDSD or IDMD) Requires –SXX, –WXX or –DXX 8 –O Outer Most 2 = Outside Reversed “XX” 4" minimum –G 5"max. 2"min. = Gray Cable Specify –G for Gray cable. Gray cable has one red edge. IDSS and IDMS uses .100" centerline cable. IDSD and IDMD uses .050" centerline cable. Cable is 28 AWG 7/36 copper wire. Standard cable is same as above except color coded. Breakout starts with Number 1 lead indicated by brown wire or red stripe. Shown on top side. 7 –W “XX” –RW Same as –S “XX” except outer strip connected to Conductor #2 and inside strip connected to Conductor #1. = Reversed Wiring #1 wire opposite position #1. 3 = Wiring Reversed Daisy Chain, Single 5 6 Requires –SXX, –WXX or –DXX 7 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. 8
IDSS-14-D-10.00-G 价格&库存
很抱歉,暂时无法提供与“IDSS-14-D-10.00-G”相匹配的价格&库存,您可以联系我们找货
IDSS-14-D-10.00-G
  • 1+80.839501+10.49150
  • 10+76.0124010+9.86510
  • 25+73.3892025+9.52460
  • 50+70.8499050+9.19510
  • 100+65.84310100+8.54530
  • 500+62.86050500+8.15820
  • 1000+58.656301000+7.61260
库存:4
