IPT1-115-05-L-D
IPT1-115-05-L-D
    SAMTEC(申泰)
    插件,P=2.54mm
    线对板针座 间距P=2.54mm 30Pin(2x15P) 直插
IPT1-115-05-L-D 数据手册
F-215 (Rev 25JUN15) IPT1–110–04–L–D IPT1–110–01–L–D (2,54 mm) .100" IPT1–125–01–L–D–RA IPT1–105–01–L–D–VS IPT1 SERIES SHROUDED POWER CONNECTOR SET SPECIFICATIONS Mates with: IPS1 Each pin individually shrouded for electrical and mechanical protection For complete specifications see www.samtec.com?IPT1 Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1.27 µm) Ni Operating Temp Range: -55°C to +105°C with Tin; -55°C to +125°C with Gold Insertion Depth: (3.81 mm) .150" to (6.48 mm) .255" PINS Wiping Distance: (0.38 mm) .015" 1 Insertion Force (SMT): 2 3.0 oz (0.83 N) avg. 3 Withdrawal Force (SMT): 2.6 oz (0.72 N) avg. 4 Insertion Force (T/H): ALL 6.0 oz (1.67 N) avg. Withdrawal Force (T/H): 5.0 oz (1.39 N) avg. Voltage Rating: 775 VAC/1095 VDC RoHS Compliant: Yes Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.13 mm) .005" max (05-10) (0.15 mm) .006" max (15-25) (6.35 mm) .250" IPT1/IPS1 CURRENT RATING (PER CONTACT) 5.9 A 4.8 A 4.1 A 3.6 A 2.3 A Choice of Through-Hole, Right Angle or Surface Mount • Locking clip option IPT1 1 NO. PINS PER ROW RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality 05, 10, 15, 20, 25 (Standard sizes) LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart = 10µ" (0.25 µm) Gold on contact, Matte Tin on tail –02 IPS1 –03 No. of positions x (2.54) .100 + (0.51) .020 IPT1 02 –04 –05 50 (5.08) .200 (2.54) 01 .100 (MOQ Required) • Other sizes • Other platings • Latching feature • No. 1 position polarized Contact Samtec. Requires –01 Lead Style (Leave blank for Through-Hole) LEAD MATED B STYLE HEIGHT A (11.05) (6.35) (2.16) –01 .435 .250 .085 (6.35) N/A -01-VS (13.59) .535 .250 MATED HEIGHT Through-hole –06 –07 –08 (2.54) .100 49 –09 Surface Mount (14.00) .551 (16.00) .630 (17.00) .669 (19.00) .748 (20.00) .787 (25.00) .984 (30.00) 1.181 (35.00) 1.378 (9.30) (2.64) .366 .104 (11.30) (2.16) .445 .085 (12.30) (2.69) .484 .106 (14.30) (2.46) .563 .097 (15.30) (2.35) .602 .093 (20.30) (2.31) .799 .091 (25.30) (2.39) .996 .094 (30.30) (2.46) 1.193 .097 A (1.27) .050 (0.51) .020 –RA = Right Angle –VS = Surface Mount –A = Alignment Pin (–VS only) (N/A with -LC) –LC = Locking Clip (Manual placement required) (–VS only) (N/A with -A) –K –TR (1.50) .060 –VS (2.54) .100 (0.64) .025 SQ –RA Note: Some sizes, styles and options are non-standard, non-returnable. OTHER OPTION = (6.00 mm) .236" DIA Polyimide film Pick & Place Pad (–VS only) (2.30) .090 (7.16) .282 A B TAIL OPTION D –L APPLICATION ALSO AVAILABLE • Individually shrouded contacts WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. = Tape & Reel Packaging (–VS only)
IPT1-115-05-L-D 价格&库存
很抱歉,暂时无法提供与“IPT1-115-05-L-D”相匹配的价格&库存,您可以联系我们找货
