F-211-1 SUPPLEMENT (Rev 23MAY19)
LCW–125–11–G–S–300
LCW–115–09–S–S–300–RE
(2.54mm) .100"
LCW SERIES
FRICTION LOCK TERMINAL STRIPS
Mates with:
SSW, SSQ, ESW, ESQ,
IDSS
1
LCW
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
ROW
OPTION
POST
HEIGHT
–S
–XXX
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?LCW
Insulator Material:
Black Glass Filled
Polyester
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27µm) Ni
Insulation Resistance:
5000 MW @ 500 VDC
Operating Temp Range:
-55 °C to 125 °C with Gold
-55 °C to 105 °C with Tin
Withstanding Voltage:
1000 VRMS @ 60 Hz
Current Rating:
3A
RoHS Compliant:
Yes
PROCESSING
= Single
Row
01 thru 36
(36 positions standard)
–L
(5.08)
.200
(2.54)
.100
36
01
(2.54).100 X No. of Spaces
(7.87)
.310
(2.54)
.100
(0.64)
.025
SQ
TYP
Lead–Free Solderable:
No
= Locking
Clip
Removed
From Each
End
–G
=10µ" (0.25µm)
Gold on post,
Gold flash
on balance
(2.54).100 X No. of Positions
(2.54)
.100
TYP
= “C”
–RX
Specify
“230” or
“300”
standard
post length
from chart
below.
–M
= 10µ" (0.25µm)
Gold on post,
Matte Tin on tail
OPTION
= Right Angle
(Specify from
chart)
–LL
= Locking
Lead
(N/A with
Right Angle)
ALSO
AVAILABLE
–S
Two leads
crimped in
opposite
directions
on or near
centerline.
(“A”=.300" or
less) N/A w/1
or 2 positions
Locking
Socket
= 30µ" (0.76µm)
Gold on post,
Matte Tin on tail
–T
–“XX”
see www.samtec.com?SSW
(Body Style -P)
= Matte Tin
= Polarized
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
LEAD
STYLE
FILE NO. E111594
– 07
– 08
– 09
–10
–11
–12
–13
–14
–15
–16
–17
–19
– 20
– 08
– 09
–10
–11
–12
–13
–14
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
Right Angle Versions
Straight Pin Versions
–15
–19
– 20
TAIL
A
(2.54)
.100
(5.08)
.200
(10.16)
.400
(12.70)
.500
(15.24)
.600
(17.78)
.700
(22.86)
.900
(27.94)
1.100
(7.62)
.300
(2.92)
.115
(3.81)
.150
(25.40)
1.000
(20.32)
.800
(3.30)
.130
(8.38)
.330
(10.92)
.430
(13.46)
.530
(16.00)
.630
(21.08)
.830
(16.16)
.636
(5.84)
.230
(23.62)
.930
(18.54)
.730
OAL POST
B
C
(10.92)
.430
(13.46)
.530
(18.54)
.730
(21.08)
.830
(23.62)
.930
(26.16)
1.030
(31.24)
1.230 (5.84)
(36.32) .230
1.430
(16.00)
.630
(11.30)
.445
(12.19)
.480
(33.78)
1.330
(28.70)
1.130
(13.46)
.530
(18.54)
.730
(21.08)
.830
(23.62)
.930
(26.16)
1.030
(31.24) (7.62)
.300
1.230
(36.32)
1.430
(16.00)
.630
(33.78)
1.330
(28.70)
1.130
Specify “LEAD STYLE”
from chart.
-RA
LEAD & -RR
STYLE TAIL
– 09
–10
(5.08)
.200
(2.54)
.100
–11
–12
–13
–14
C
B
–15
–19
– 20
– 09
A
–10
–11
–12
–13
–14
–15
–19
*Available with –LL
(Locking Lead) Option
– 20
-RE
TAIL
A
(4.06)
.160
(6.60)
.260
(9.14)
.360
(11.68)
.460
(16.76)
.660
(21.84)
.860
(1.52)
.060
(19.30)
.760
(14.22)
.560
(2.29)
.090
(4.83)
.190
(7.37)
.290
(9.91)
.390
(14.99)
.590
(20.07)
.790
A
(6.60)
.260
(9.14)
.360
(11.68)
.460
(14.22)
.560
(19.30)
.760
(24.38)
.960
(4.06)
.160
(21.84)
.860
(16.76)
.660
(4.83)
.190
(7.37)
.290
(9.91)
.390
(12.45)
.490
(17.53)
.690
(22.61)
.890
(2.29)
.090
(20.07) (17.53)
.690
.790
(14.99) (12.45)
.490
.590
-RP
TAIL
A
(7.62)
.300
(10.16)
.400
(12.70)
.500
(15.24)
.600
(20.32)
.800
(25.40)
1.000
(5.08)
.200
(22.86)
.900
(17.78)
.700
(5.84)
.230
(8.38)
.330
(10.92)
.430
(13.46)
.530
(18.54)
.730
(23.62)
.930
(3.30)
.130
(21.08)
.830
(16.00)
.630
POST
C
from chart.
(5.08)
.200
(2.54)
.100
(5.84)
.230
C
A
REGULAR
RIGHT ANGLE
X
(7.62)
.300
OPTION
X
OPTION
X
– RA
(1.52)
.060
(4.06)
.160
(0.64)
.025
MAX
– RR
(1.52)
.060
(0.64)
.025
MAX
– RE
– RP
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
REVERSE
RIGHT
ANGLE
REGULAR
RIGHT
ANGLE
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
– PR
很抱歉,暂时无法提供与“LCW-114-08-G-S-300”相匹配的价格&库存,您可以联系我们找货
