MEC5-080-01-L-RA-W1-TR
    SAMTEC(申泰)
    SAMTEC - MEC5-080-01-L-RA-W1-TR - Card Edge Connector, Dual Side, 1.57 mm, 160 Contacts, Through Hol...
MEC5-080-01-L-RA-W1-TR 数据手册
F-218 (Rev 10JAN18) MEC5–040–01–L–RA–W2 MEC5–050–01–L–DV–W1–K–TR (0.50 mm) .0197" MEC5-DV, MEC5-RA SERIES VERTICAL /RIGHT-ANGLE CARD SOCKET Mates with: (1.60 mm) .062" thick card with standard board tolerance POSITIONS PER ROW MEC5 CARD THICKNESS SPECIFICATIONS PROCESSING A (4.60) .181 01 (3.00) .118 (0.50) .0197 (5.85) .230 (10.25) .404 (1.50) .059 (0.25) .010 (1.12) .044 DIA Note: Some sizes, styles and options are non-standard, non-returnable. (0.35) .014 (0.18) .007 POSITIONS PER ROW SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?MEC5-RA Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C Current Rating: 1.5 A per pin (2 pins powered) Voltage Rating: 125 VAC/175 VDC RoHS Compliant: Yes Note: Some sizes, styles and options are non-standard, non-returnable. CARD THICKNESS PLATING OPTION –01 –030, –040, –050, –060, –070, –080 A B (1.60) .063 DIA 01 (0.50) .0197 (1.65) .065 D (3.00) .118 E = Weld Tab Through-hole = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (1.58).062 C –W1 –L = (1.60 mm) .062" thick card (10.25) .404 (1.80) .071 02 WELD TAB RA –W2 = Weld Tab POSITION A B C Surface PER ROW Mount (23.38) .920 (17.10) .673 N/A –30 (28.38) 1.117 (22.10) .870 N/A –40 (35.88) 1.413 (29.60) 1.165 (15.44) .608 –50 (40.88) 1.609 (34.60) 1.362 (17.94) .706 –60 (45.88) 1.806 (39.60) 1.559 (20.44) .805 –70 (50.88) 2.003 (44.60) 1.756 (22.94) .903 –80 Note: Polarization rib is not present on –030 & -040 postions PROCESSING Lead-Free Solderable: Yes MEC5-DV Rating based on Samtec reference channel. For full SI performance data visit Samtec.com or contact SIG@samtec.com (0.50) .020 C –W1 SHOWN MEC5 HIGH-SPEED CHANNEL PERFORMANCE (1.90) .075 (0.64) .025 TR POSITION A B C PER ROW (17.10) .673 N/A (21.63) .852 –30 (22.10) .870 N/A (26.63) 1.048 –40 (29.60) 1.165 (15.48) .609 (34.13) 1.344 –50 (34.60) 1.362 (17.98) .708 (39.13) 1.541 –60 (39.60) 1.559 (20.48) .806 (44.13) 1.737 –70 (44.60) 1.756 (22.98) .905 (49.13) 1.934 –80 (49.60) 1.953 (25.48) 1.003 (54.13) 2.131 –90 –100 (54.60) 2.150 (27.98) 1.102 (59.13) 2.328 Note: Polarization rib is not present on –030 & -040 postions (1.50) .059 B K = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail No. of Positions x (0.50) .0197 + (10.38) .409 (1.80) .071 02 W1 –L = (1.60 mm) .062" thick card –030, –040, –050, –060, –070, –080, –090, –100 Lead-Free Solderable: Yes Mates with: (1.60 mm) .062" thick card with standard board tolerance DV –01 For complete specifications and recommended PCB layouts see www.samtec.com?MEC5-DV Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C Current Rating: 1.5 A per pin (2 pins powered) Voltage Rating: 125 VAC/175 VDC RoHS Compliant: Yes PLATING OPTION F –W2 SHOWN (1.25) .049 (11.38) .448 (13.53) .532 POSITION PER ROW –30 –40 –50 (0.60) –60 .024 –70 –80 D E F N/A N/A (13.50) .531 (16.00) .630 (18.50) 728 (21.00) 2.003 (14.50) .571 (19.50) .768 (27.00) 1.063 (32.00) 1.260 (37.00) 1.457 (42.00) 1.654 (18.16) .715 (23.16) .912 (30.66) 1.207 (35.66) 1.404 (40.66) 1.601 (45.66) 1.798 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
MEC5-080-01-L-RA-W1-TR 价格&库存
很抱歉,暂时无法提供与“MEC5-080-01-L-RA-W1-TR”相匹配的价格&库存,您可以联系我们找货
