F-224 SUPPLEMENT
PSS–08–01–T–S
PSS–13–01–T–S
(5.08 mm) .200"
PSS SERIES
POWER SOCKET STRIP
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?PSS
Mates with:
FWS, HFWS,
SW, HPM, HPW
Insulator Material:
Black LCP
Contact Material:
BeCu
Plating:
Sn over 50 µ" (1.27 µm) Ni
Current Rating (PSS/FWS):
11.4 A per pin
(1 pin powered)
Insertion Depth:
(2.62 mm) .103" to
(5.03 mm) .198"
Voltage Rating:
500 VAC mated with FWS
RoHS Compliant:
Yes
(6.35 mm)
.250"
(5.08 mm)
.200"
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max (02-14)*
(0.20 mm) .008" max (15-20)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
NO. PINS
PER ROW
PSS
LEAD
STYLE
PLATING
OPTION
OTHER
OPTION
S
RECOGNITIONS
–01
For complete scope of
recognitions see
www.samtec.com/quality
= Throughhole
02 thru 20
–T
= Matte Tin
–02
FILE NO. E111594
–K
= (5.00 mm)
.196" DIA Polyimide
Film Pick & Place Pad
(–02 only)
= Surface
Mount
–TR
= Tape & Reel
(–02 thru –14 positions only)
(–02 only)
–FR
No. of Positions x (5.08) .200
01
(3.99)
.157
(5.08)
.200
= Full Reel Tape & Reel
(must order max. quantity
per reel; contact Samtec
for quantity breaks)
(-02 thu –14 positions only)
(–02 only)
(2.29)
.090 (6.35)
.250
(0.64)
.025
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(2.68)
.105
–01
(1.14)
.045
(8.00)
.315
–02
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“PSS-03-01-TM-S”相匹配的价格&库存,您可以联系我们找货
