QRM8-026-05.0-L-D-A-GP
    SAMTEC(申泰)
    52 位置 连接器 公引脚阵列 表面贴装型 镀金
QRM8-026-05.0-L-D-A-GP 数据手册
F-217 QRM8–036–05.0–L–D–DP–A–K QRM8–078–05.0–L–D–A (0.80 mm) .0315" QRM8 SERIES QRM8–026–02.0–L–D–A SLIM BODY GROUND PLANE HEADER SPECIFICATIONS Board Mates: QRF8 For complete specifications and recommended PCB layouts see www.samtec.com?QRM8 Cable Mates: EQRD Insulator Material: Black LCP Terminal & Ground Plane Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Contact: 2.2 A per pin (1 pin powered per row) Ground: 8.5 A per ground plane (1 ground plane powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 215 VAC RoHS Compliant: Yes Integral ground/power plane (1.20 mm) .047" NOMINAL WIPE Choice of stack heights HIGH-SPEED CHANNEL PERFORMANCE QRM8-DP/QRF8-DP @ 10 mm Mated Stack Height Rating based on Samtec reference channel. For full SI performance data visit Samtec.com or contact SIG@samtec.com 31 10 YEAR MFG WITH 30 µ" GOLD Increased wipe for rugged applications EXTENDED LIFE PRODUCT HIGH MATING CYCLES G b p s PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (018-026) (0.15 mm) .006" max (036-078) QRM8 RECOGNITIONS PINS PER ROW NO. OF PAIRS –026, –052, –078 For complete scope of recognitions see www.samtec.com/quality (52 total pins per bank = –D) –018, –036, –054 (18 pairs per bank = –D–DP) FILE NO. E111594 PROTOCOLS = 2 mm Body Height (Not available with –054 & –078 positions) –05.0 –L (MOQ Required) No. of Banks x (24.80) .976 + (1.77) .070 MATED HEIGHT* –05.0 –07.0 –02.0 (7.00) .276 (10.00) .394 (12.00) .472 (9.00) .354 (12.00) .472 (14.00) .551 *Processing conditions will affect mated height. See SO Series for board space tolerances. Note: Patented Note: Some lengths, styles and options are non-standard, non-returnable. –D–DP = Differential Pair 02 B (6.12) .241 (9.12) .359 (11.12) .438 A OTHER OPTION –GP = Guide Post (Requires –GP on mating connector) –K = (5.00 mm) .197" DIA Polyimide Film Pick & Place Pad –TR = Tape & Reel (–018, –026, –036, –052 only) (4.60) .181 (0.80) .0315 (1.32) .052 (1.00) .039 DIA A –02.0 (4.81) .189 –05.0 (7.81) .307 –07.0 (9.78) .385 01 QRF8 LEAD STYLE –D = SingleEnded LEAD STYLE = 7 mm Body Height • Other platings Contact Samtec. QRM8 LEAD STYLE TYPE = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –07.0 ALSO AVAILABLE –07.0 –02.0 PLATING OPTION = 5 mm Body Height • 100 GbE –05.0 LEAD STYLE (2.20) .087 A (3.67) .145 No. of Banks x (24.80) .976 - (1.10) .043 (1.89) .074 (3.18) .125 • Edge Rate® contacts B • Increased contact wipe • 10 year MFG No. of Banks x (24.80) .976 + (3.55) .140 • Guide post option –GP OPTION WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
QRM8-026-05.0-L-D-A-GP 价格&库存
很抱歉,暂时无法提供与“QRM8-026-05.0-L-D-A-GP”相匹配的价格&库存,您可以联系我们找货
