RF316-04SP3-02SP1-0500 数据手册
RF-18
RF316–07SP1–01BJ1–0300
RF316–01RP1–02RP1–0200
50 W RG 316 CABLE ASSEMBLIES
SPECIFICATIONS
For complete specifications see
www.samtec.com?RF316
Mates with:
MCX, MMCX, MMCXV,
SMA, SMB5, BNC5, TNC
High performance 26 AWG
RG 316 coax cable
Plugs and
Jacks
RF Connector:
Outer Contact Material:
Ni plated Brass (BNC)
Au plated Brass (SMB & SMA)
Au plated BeCu (MCX & MMCX)
Center Contact Material:
Au plated Brass (BNC-P, MCX-P,
MMCX-P & SMA-P)
Au plated BeCu
(SMB-P & SMA-J)
Au plated Phos. Bronze (BNC-J)
Insulator Material:
PTFE
Operating Temperature:
-50 °C to +165 °C
Impedance:
50 W
Frequency Range:
0~6 GHz
(Cable & connector dependent)
RoHS Compliant:
Yes
Double shielded
RG 316 cable
also available
(RS316 Series)
Solutionator
DESIGN IN A MINUTE
• Create a full system:
cable assembly and board level mates,
50 Ω and 75 Ω solutions
• 24-hour samples on standard products
• Visit: rf.samtec.com
Straight or
Right-angle
RG 316 Cable:
Impedance:
50 W
Capacitance:
96.432 pF/meter
Max Attenuation
(cable only):
1.25 dB @ 1 GHz for 1 meter
Conductor Size:
26 AWG, (0.51 mm) .020" dia.
Conductor Material:
Silver Plated Copper
Insulator Material:
PTFE
Shield Material:
Silver Plated Copper Clad Steel
Jacket Material:
FEP
Jacket Diameter:
(2.54 mm) .100"
Jacket Color:
Amber
Bend Radius:
12.7 mm
RoHS Compliant:
Yes
OTHER
SOLUTIONS
• Double shielded
RG 316 cable available,
see RS316 Series
• Cable connector kits
(see cable components
catalog pages)
END 1
CONNECTOR
CABLE TYPE
END 2
CONNECTOR
Specify END OPTIONS from chart
RF316
= RG 316 Cable,
Single Braid Shield
–01SP1–02RP1 SHOWN
XXXX = OAL (millimeters)
END OPTIONS
–01SP1 = SMA
Straight Plug
(30 µ" (0.76 µm)
Gold on Center Contact,
Gold Flash on Shell)
END OPTIONS
–02RP1 = MCX
Right-angle Plug
(30 µ" (0.76 µm) Gold on Center
Contact, Gold Flash on Shell)
–02SP1 = MCX
Straight Plug
–03SP1 = MMCX
Straight Plug
–03RP1 = MMCX
Right-angle Plug
–V3SP1 = MMCXV
Straight Plug, High Vibration
Contact, Nickel on Shell)
–V3RP1 = MMCXV
Right-angle Plug, High Vibration
–V3SJ1 = MMCXV
Straight Jack, High Vibration
–01RP1 = SMA
Right-angle Plug
(30 µ" (0.76 µm)
–07SP1 = SMB
Straight Plug
(30 µ" (0.76 µm)
–07RP1 = SMB
Right-angle Plug
(30µ" (0.76 µm)
–02SJ1 = MCX
Straight Jack
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
RF316–02RP1–02SP1–0200
RF316–03RP1–07RP1–0200
RF316–04BJ2–07SP1–0100
RF316 SERIES
Single or
Double ended
Standard heat
shrink wraps
Variety of
Bulkhead Jacks
ALSO AVAILABLE
Heavy Gold
plated
(MOQ Required)
• Additional stripping and tinning options
• IP68 Sealed AccliMate™ end options
• IP67 TNC option
• Additional plating options
• Additional end connector combinations
• Knurled nuts with BNC option
Contact Samtec.
Choice of RF
connector styles
OVERALL LENGTH
–“XXXX”
= Overall Length in millimeters –0100 (100 mm) minimum
(Cable lengths larger than 1000 millimeters are not supported by S.I. Test data)
END OPTIONS
END OPTIONS
–04SP3 = BNC
Straight Plug
(10 µ" (0.25 µm)
Nickel on Shell)
–01PN1 = SMA
4-Hole Panel Mount Jack
(30 µ" (0.76 µm)
–05SP3 = TNC
Straight Plug
(10 µ" (0.25 µm)
Nickel on Shell)
–04BJ2 = BNC
Bulkhead Jack
(30 µ" (0.76 µm)
Nickel on Shell)
–07BJ1 = SMB
Bulkhead Jack (30 µ" (0.76 µm)
–01BJ1 = SMA
Straight Bulkhead Jack
–01SB1 = SMA
Straight Bulkhead Jack, Sealed
–01SR1 = SMA
Straight Bulkhead Jack, Sealed,
Reversed Polarity
–01BR1 = SMA
Reversed Polarity
END OPTIONS
–SING = Single Ended
(End 2 Callout)
XXXXXX = Stripped & Tinned
(End 2 Callout)
B
A
C
STRIPPED & TINNED
(Dimensions in mm)
–05BJ3 = TNC
Bulkhead Jack
(10 µ" (0.25 µm)
Nickel on Shell)
–06BJ2 = N Type
Bulkhead Jack
(30 µ" (0.76 µm)
Nickel on Shell)
WWW.SAMTEC.COM
CALLOUT
–303030
–303040
–403030
–403040
–404040
A
3.0
3.0
4.0
4.0
4.0
B
3.0
3.0
3.0
3.0
4.0
C
3.0
4.0
3.0
4.0
4.0
Both center conductor and
braid shield are stripped,
only the center
conductor is tinned.
RF316-04SP3-02SP1-0500 价格&库存
很抱歉,暂时无法提供与“RF316-04SP3-02SP1-0500”相匹配的价格&库存,您可以联系我们找货
