SCPU-10-G-02.00-MBS-MBS
    SAMTEC(申泰)
SCPU-10-G-02.00-MBS-MBS 数据手册
F-224 SUPPLEMENT SCPE–G–02.00–S–O–NP SCPE, SCPU, SCPFE SERIES SCPU–17–G–02.00–AMS–AM IP68 SEALED USB & ETHERNET PLUGS Mates with: SCRES SPECIFICATIONS For complete specifications see www.samtec.com?SCPE Insulator Material: Polycarbonate Contact Material: Phosphor Bronze Shield Material: Phosphor Bronze Wire: 24 AWG Overmold: PA66 GF13 FR Current Rating: 3.8 A per pin (1 pin powered) Operating Temp Range: -40 °C to +70 °C RoHS Compliant: Yes –G SCPE = 50 µ" (1.27 µm) Gold on Contact, Nickel on Shell = Sealed Circular Ethernet Cable Plug END OPTION WIRE LENGTH PLATING TYPE –D –01.00 Note: Some lengths, styles and options are non-standard, non-returnable. Mates with: SCRUS SPECIFICATIONS For complete specifications see www.samtec.com?SCPU Insulator Material: Glass Filled Thermoplastic Contact Material: Copper Alloy Shield Material: CRS Wire: 20 AWG (Power) 25 AWG (Signal) 28 AWG (Drain) Sealed Overmold: PA66 GF13 FR Operating Temp Range: -20 °C to +75 °C RoHS Compliant: Yes –O = Double Ended (Both Ends Sealed) = (1 m) 39" Cable –02.00 = Outdoor Rated –S = (2 m) 79" Cable NP –NP = Cat 5e (No polarization mates with SCRES –C5E) = Single Ended (End No. 1 Sealed) Standard lengths Assembled Length = Wire Length + (3.0) .12 (42.00) 1.65 DUST CAP • DCA-17-02 O END NO. 2 (–S) –S SHOWN END NO. 1 FIELD TERMINATION KIT • Ethernet Field Termination Kit available for long cable run and small-opening applications so housings can be customer-installed after the runs are complete. • SCPFE-17-G-01 Series (For cable outside diameter range of 5.00-5.75 mm) • SCPFE-17-G-02 Series (For cable outside diameter range of 5.75-6.50 mm) SHELL SIZE SCPU PLATING –G –17 (Standard USB only) = 30 µ" (0.76 µm) Gold on Contact, Nickel on Shell WIRE LENGTH –01.00 = (1 m) 40" Cable –02.00 = (2 m) 79" Cable Standard lengths (Assembled Length = Wire Length + (19.5 mm) .77") (42.00) 1.65 END 1 OPTION –AMS = USB A Type, Sealed ALSO AVAILABLE (MOQ REQUIRED) • Other wire lengths END 2 OPTION –AM = USB A Type, Not Sealed –BMS = USB B Type, Sealed ALSO AVAILABLE (MOQ REQUIRED) • Other wire lengths • Other end options –AMS –BMS DUST CAPS & PANEL PLUG Note: Some lengths, styles and options are non-standard, non-returnable. • Dust Caps: DCA-17-01 or DCA-10-01 • Panel Plug: SCPPA-17-01 –AM WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SCPU-10-G-02.00-MBS-MBS 价格&库存
很抱歉,暂时无法提供与“SCPU-10-G-02.00-MBS-MBS”相匹配的价格&库存,您可以联系我们找货
