SEAF-40-01-L-04-2-RA-TR
    SAMTEC(申泰)
    SMD,P=1.27mm,卧贴
    板对板连接器 卧贴 针脚数:160Pin 间距:1.27mm 排数:4
SEAF-40-01-L-04-2-RA-TR 数据手册
F-214 (Rev 07AUG14) SEAF–20–01–L–06–2–RA–GP–TR SEAF–20–01–L–04–2–RA–GP–TR (1,27 mm) .050" SEAF-RA SERIES HI-DENSITY RIGHT ANGLE OPEN PIN FIELD SPECIFICATIONS Up to 500 Pins Mates with: SEAM, SEAMP, SEAC For complete specifications and recommended PCB layouts see www.samtec.com?SEAF-RA OTHER SOLUTIONS Insulator Material: Black LCP Contact Material: Copper Alloy Current Rating: 2.1 A per pin (4 adjacent pins powered) Operating Temp Range: -55°C to +125°C Plating: Au or Sn over 50µ" (1,27 µm) Ni Contact Resistance: 17.1 mΩ max Working Voltage: 280 VAC Mated Cycles: 100 RoHS Compliant: Yes Lead-Free Solderable: Yes GPSK–01–01 Solder Charge Terminations Guide post field termination kits also available. Contact Samtec. Low Insertion/ Extraction Forces RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality Optional Guide Post holes GPPK–01–01 NO. PINS PER ROW SEAF 01 PLATING OPTION NO. OF ROWS SOLDER TYPE RA OPTION TR ALSO AVAILABLE (MOQ Required) NO. OF ROWS –04 –06 –08 –10 TEST SEAF-RA/ SEAF-RA/ DATA* SEAM-02 SEAM-RA Single25 Gbps 24 Gbps Ended Differential 26 Gbps 22 Gbps Pair *@ 3dB insertion loss. Test board losses de-embedded from performance data. Complete test data available at www.samtec.com?SEAF-RA or contact sig@samtec.com A B = Four Rows = 10µ” (0,25 µm) Gold on contact area, Matte Tin on solder tail C – 06 – 08* = 30µ” (0,76 µm) Gold on contact area, Matte Tin on solder tail (15,80) .622 (16,31) .642 (10,45) .411 (18,34) .722 (18,85) .742 (12,99) .511 = Tin/Lead Alloy Solder Charge = Six Rows –S (13,26) .522 (13,77) .542 (7,91) .311 –1 – 04 –L – 20, – 30, –40, –50 • Other platings Contact Samtec. –2 = Lead-Free Solder Charge = Eight Rows – 10* (20,88) .822 (21,39) .842 (15,53) .611 – GP = Guide Post Hole – LP = Latch Post (06 row 30 positions only) (Mates to SEAC Series) = Ten Rows * Note: Fixturing required to process eight and ten row options, see www.samtec.com/searayfixture (27,25) 1.073 B A –K = Polyimide film Pick & Place Pad (3,56) .140 –GP= No. of positions x (1,27) .050 + (19,56) 0.77 Without –GP= No. of positions x (1,27) .050 + (9,40) 0.37 –LP (6 ROW) SHOWN C Note: Some sizes, styles and options are non-standard, non-returnable. –GP (6 ROW) SHOWN (1,27) .050 (0,64) .025 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. – TR =Tape & Reel
SEAF-40-01-L-04-2-RA-TR 价格&库存
很抱歉,暂时无法提供与“SEAF-40-01-L-04-2-RA-TR”相匹配的价格&库存,您可以联系我们找货
