SFM-130-02-H-D-DS
SFM-130-02-H-D-DS
    SAMTEC(申泰)
    .050'' X .050
SFM-130-02-H-D-DS 数据手册
RUGGED TIGER EYE™ SYSTEMS (1.27 mm) .050" PITCH MAX 8 3.7 A m p G b p s s FEATURES & BENEFITS • S crew down, locking clip, friction latching and weld tab ruggedizing options • Shrouded, polarized and keyed • Surface mount or through-hole tails • High-density, four row design (FOLC/MOLC Series) • Discrete wire assemblies available in single or double row, 28 and 30 AWG PVC or *Teflon™ Fluoropolymer (See pages 238-239). Contact asp@samtec.com for custom solutions. • Cable components (ISDF/CC03) and tooling available: samtec.com/tooling • Severe Environment Testing qualified (SFM/TFM); aligns with MIL-DTL-55302. Visit samtec.com/set *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. KEY SPECIFICATIONS SERIES STACK INSULATOR HEIGHTS MATERIAL CONTACT MATERIAL BeCu (SFM) SFM/TFM 6 to 12 mm Black LCP SFC/TFC Black LCP 6 to 12 mm F-224 (Rev 04APR24) Phosphor Bronze (TFM) Phosphor Bronze IDC cable assemblies with rugged strain relief (FFSD/FFMD, FFTP/FMTP) Locking for increased unmating force (SFML/TFML) PLATING OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING MAX. CYCLES LEAD-FREE SOLDERABLE Au or Sn over 50 µ" (1.27 µm) Ni -55 °C to +125 °C 3.7A per pin (2 pins powered) 275 VAC 10,000 with 30 µ" (0.76 µm) Au Yes Au or Sn over 50 µ" (1.27 µm) Ni -55 °C to +125 °C 3.1 A per pin (2 pins powered) 350 VAC (Call Samtec for E.L.P.™ plating option) Yes samtec.com/127mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. MAX 3.7 A (1.27 mm) .050" PITCH • SMT/THROUGH-HOLE SOCKET SERIES - - NO. PINS PER ROW 1 SFM 03, 04, 06, 08 SFML 05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 = Standard = Locking (SFM only) (Surface Mount) (Through-hole) –02 = Tiger Eye™ Contact (BeCu) –L2 –L1, –L3 = Low Insertion Force Tiger Eye™ Contact (BeCu) –T2 = Low Insertion Force Tiger Eye™ Contact (BeCu) = Tiger Eye™ LITE Contact (Phosphor Bronze) Board Mates: TFM Cable Mates: TFSD, TFSS –01, –03 = Tiger Eye™ Contact (BeCu) (Standard sizes) SFM - LEAD STYLE - PLATING OPTION –L m p ROW OPTION s - –S = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (Call Samtec for E.L.P.™ plating option) = Single Row (SFM only) –D = Double Row –SH = Single Horizontal (05 thru 30 positions only) (SFM only) (Lead style –02 only) –T1 –DH = Tiger Eye™ LITE Contact (Phosphor Bronze) = Double Horizontal (05 thru 30 positions only) (SFM only) (Lead style –02 only) SFML Board Mates: TFML Cable Mates: TFSD    [1RRI3RVLWLRQV   8 G b p s   OPTIONS Specify only –A, –LC or –DS (Not available with –DH, –SH) Specify only –K or –P (Lead styles –02, –L2, –T2 only) –A –K = Alignment Pin –LC = Polyimide film Pick & Place Pad (Not available with –DH, –SH) –DS = Plastic Pick & Place Pad (Not available with –DH, –SH) = Locking Clip (Manual placement required) –P = Dual Screw Down for Specify –TR or (1.60 mm) .062" PCB (05 thru 40 –FR last; Required for –DH & –SH. positions only) (Lead styles –02, (Lead styles –01, –L2 & –T2 only) –02 & –03 only) (Requires –D row option) –TR (Not available with = Tape & Reel SFML) (Mates with TFM-DS option) –FR (Not available = Full Reel with –A, –LC, Tape & Reel –K, –P, –XR) (must order max. quantity per reel; contact Samtec for quantity breaks) SINGLE ROW  [1RRI3RVLWLRQV   H[FHSWIRUDOLJQPHQWSLQRSWLRQ  [1RRI3RVLWLRQV   LEAD STYLE   –01, –L1, –T1   A B (3.05) .120 (0.51) .020 –03, –L3 (1.91) .075 (0.41) .016 DOUBLE ROW                   $ SURFACE MOUNT % THROUGH-HOLE         Notes: Severe Environment Testing qualified (SFM); aligns with MIL-DTL-55302. Visit samtec.com/set Some lengths, styles and options are non-standard, non-returnable. –SH   –DH –A   –LC       –DS View complete specifications at: samtec.com?SFM & samtec.com?SFML samtec.com/127mm-TigerEye A-224 (Rev 04APR24) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SFM-130-02-H-D-DS 价格&库存
很抱歉,暂时无法提供与“SFM-130-02-H-D-DS”相匹配的价格&库存,您可以联系我们找货
