SSQ-104-23-F-S
SSQ-104-23-F-S
    SAMTEC(申泰)
    2MM SOCKET STRIPS
SSQ-104-23-F-S 数据手册
SSW–125–01–G–P F-212-1 (2,54 mm) .100" SSQ–115–04–L–T SSW, SSQ SERIES THROUGH-HOLE .025" SQ POST SOCKET SPECIFICATIONS For complete specifications see www.samtec.com?SSW or www.samtec.com?SSQ Mates With: TSW, MTSW, MTLW, LCW, EW, ZW, TSS, ZSS, TSM, TSSH, HTSS Insulator Material: Black Liquid Crystal Polymer (-S & -D) or Black High Temperature Thermoplastic (-T) Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Contact Resistance: 10 mΩ max Insertion Depth: (3,68 mm) .145" to (6,35 mm) .250" Insertion Force: (Single contact only) (–S plating) Standard= 6 oz (1,67 N) avg ((0,64 mm) .025" SQ pin); SSW Low Inser tion Force= 3 oz (0,83 N) avg SSQ Low Insertion Force= 3.3 oz (0,92 N) avg Normal Force: Standard= 125 grams (4.4 N) Withdrawal Force: (Single contact only) (–S plating) Standard= 5 oz (1,39 N) avg ((0,64 mm) .025" SQ pin); SSW Low Inser tion Force= 2.6 oz (0,72 N) avg SSQ Low Insertion Force= 2.9 oz (0,81 N) avg Max Cycles: 100 with 10µ" (0,25 µm) Au Voltage Rating: 550 VAC mated with TSW RoHS Compliant: Yes Lead-Free Solderable: Yes 1 TYPE STRIP PIN CENTERS SSW = Solder Tail –1 = (2,54 mm) .100" Centers SSQ = Square Tail (2,54) .100 2 49 50 (2,41) .095 –S (2,54) .100 x No. of Positions + (0,51) .020 100 98 4 2 (2,54) (4,95) .100 .195 –D 99 97 150 147 3 (2,54) .100 6 1 3 (2,54) .100 (5,08) .200 –T 148 145 150 147 1 4 6 3 (5,08) .200 –Q 148 145 4 1 CURRENT RATING (PER CONTACT) AMBIENT TSW mated TSW mated TEMP with SSQ with SSW 20°C 7.6A 6.9A 40°C 6.9A 6.1A 60°C 5.9A 5.3A 95°C 3.9A 3.5A 6 POSITIONS (2x3) POWERED Note: Some lengths, styles and options are non-standard, non-returnable. (7,49) .295 (8.51) .335 (2,54) .100 x No. of Spaces –RA WWW.SAMTEC.COM (7,49) .295 01 thru 50 NO. PINS PER ROW SSW–130–02–G–D–RA SSQ–130–02–L–S SSW–122–03–L–T SSW–115–02–T–Q–RA LEAD STYLE ROW OPTION PLATING OPTION TAIL OPTION –S –F –L = Locking Lead = Right Angle (Leave blank for straight pin version) –P = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail –LL –RA = Single Row = Gold flash on contact, Matte Tin on tail OTHER OPTION Two leads per strip crimped in opposite directions on or near centerline. Available on tails from (2,29 mm) .090" to (7,87 mm) .310" only. N/A with single row 1 or 2 positions. = Single Row (Notched to mate with LCW) 36 pins max –D –G –“XXX” = Double Row = 20µ" (0,51 µm) Gold on contact, Gold flash on tail = Polarized (Specify “XXX” as position number) –T –T = Triple Row = Matte Tin (-T N/A on LIF contacts) Note: Other Gold plating options available. Contact Samtec. –Q APPLICATION SPECIFIC OPTION = Double Row .200" (5,08 mm) row space (Outer rows filled only) Notch available. Call Samtec. Straight Pin Versions (Specify “LEAD STYLE” from chart) SINGLE DOUBLE OR TRIPLE LEAD STYLE –S & –P Standard Insertion Force Low Insertion Force* –01 –21 –02 –22 (4,93) .194 –03 –23 (10,00) .394 –04 –24 (14,83) .584 –06** N/A (3,15) .124 –T –D –Q A (2,64) .104 A (2,54) .100 SSW (0,41) x (0,79) .016 .031 * LIF N/A with Tin Plating **Style –06 N/A with SSQ (5,08) .200 (2,54) .100 SSQ (0,64) SQ .025 (5,08) .200 Right Angle Versions (Specify “LEAD STYLE” from chart) – 22 – 03 – 23 – 04 –24 –Q SINGLE DOUBLE TRIPLE (–S & –P) Standard Low Insertion Insertion A Force Force* – 02 –T –D –S & –P LEAD STYLE (2,54) .100 (7,62) .300 (12,45) .490 (–D) (–T & –Q) A A (2,54) .100 (7,62) .300 (2,54) .100 N/A N/A (1,52) .060 A A A A N/A SSW SSQ (0,41) x (0,79) (0,64) .016 .031 .025 SQ (2,54) .100 *LIF N/A with Tin Plating WWW.SAMTEC.COM (2,54) .100 (5,08) .200
SSQ-104-23-F-S 价格&库存
很抱歉,暂时无法提供与“SSQ-104-23-F-S”相匹配的价格&库存,您可以联系我们找货
