T2M-115-01-S-D-SM
T2M-115-01-S-D-SM
    SAMTEC(申泰)
    CONN HEADER SMD 30POS 2MM
T2M-115-01-S-D-SM 数据手册
F-215 T2M–110–01–L–D–TH–WT–DS T2M–105–01–L–D–TH–WT ™ SYSTEM T2M–105–01–L–D–RA–WT (2,00 mm) .0787" T2M–105–01–L–D–SM–WT T2M SERIES HIGH RELIABILITY CABLE HEADER SPECIFICATIONS Mates with Tiger Eye™ discrete wire cable assemblies Mates with: S2SD, S2M, S2SDT Up to 30 positions per row For complete specifications and recommended PCB layouts see www.samtec.com?T2M Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1,27 µm) Ni Current Rating (T2M/S2SD): 3.8 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +105°C with Tin; -55°C to +125°C with Gold RoHS Compliant: Yes • Weld tabs MATED HEIGHT S2M Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max Optional weld tab SM= (7,06 mm) .278" TH= (6,17 mm) .243" Choice of Surface Mount, Through-hole or Right Angle T2M RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality T2M 1 NO. OF POSITIONS PLATING OPTION 01 = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail (Per Row) OPTION –TH –L 05, 07, 10, 15, 20, 25, 30 OTHER SOLUTIONS D = Through-hole –RA = Right Angle –SM (6,00) .236 No. of positions x (2,00) .0787 + (14,38) .566 = Surface Mount (3,98) .157 See S2SD in the discrete wire section or contact Samtec. (0,64) .025 SQ (3,81) .150 No. of positions x (2,00) .0787 + (5,67) .223 ALSO AVAILABLE (MOQ Required) (1,98) .078 (1,77) (2,26) .070 .089 01 –RA–WT • Other platings Contact Samtec. Note: Some lengths, styles and options are non-standard, non-returnable. –TR (2,00) .0787 (1,52) .060 (6,55) .258 (8,76) .345 (2,41) .095 (2,00) .0787 (0,50) .020 SQ –DS = Screw Down (N/A with –RA) (mates with –S2M–DS, S2SD/S2SDT –SS/–DS option) = (7,50 mm) .295" DIA Polyimide film Pick & Place Pad (–SM only) (7,44) .293 (2,00) .0787 –WT = Weld Tab (S2SD & S2SDT, –SR/–DR required mate) –K –DS (2,29) .090 02 OTHER OPTION (0,64) .025 –TH–WT (8,63) .340 –SM–WT WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (1,64) .065 = Tape & Reel (–SM only)
T2M-115-01-S-D-SM 价格&库存
很抱歉,暂时无法提供与“T2M-115-01-S-D-SM”相匹配的价格&库存,您可以联系我们找货
