TLW-104-05-F-S
TLW-104-05-F-S
    SAMTEC(申泰)
    LOW PROFILE .025 SQ STRIPS
TLW-104-05-F-S 数据手册
F-219 MTLW–130–05–G–S–110 TLW–118–06–T–D (2.54 mm) .100" TLW, MTLW SERIES LOW-PROFILE .025" SQ POST HEADERS Board Mates: BSW, CES, SLW, HLE 1 TLW NO. PINS PER ROW ROW OPTION LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart = Gold flash on post, Matte Tin on tail = Single Row –G = Double Row OTHER OPTION FEATURES These headers provide the ultimate low-profile (0.64 mm) .025" square post board stacking = Single Row system. The high quality Phosphor Bronze (2.54) .100 x No. of Positions terminals are available with a standard 40 01 (2.54) short post height .100 (TLW Series) TYP for mating TLW (6.60) with lowCES = .260 profile SLW = (6.09) .240 sockets, = Double Row or the post 02 72 height can be Modified (MTLW (2.54) Series) to accommodate .100 IDC assemblies and other 01 71 applications. –F 01 thru 40 (1.52) .060 (2.48) .098 01 thru 36 C (1.52) .060 A (0.64) .025 –01 –05 & –06 (5.03) .198 C (3.05) .120 LEAD STYLE A C – 01 N/A – 05 (4.32) .170 (3.43) .135 (5.84) .230 (2.67) .105 (2.67) .105 – 06 = 10 µ" (0.25 µm) Gold on post, Gold flash on tail –S –D –RA = Right-angle (–01 Lead Style only) –“XX” = Polarized Position Specify position for omitted pin. –T = Matte Tin ALSO AVAILABLE (MOQ Required) SPECIFICATIONS • Other platings For complete specifications see www.samtec.com?TLW or www.samtec.com?MTLW MTLW Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (TLW/SLW): 5.2 A per pin (2 pins powered) Operating Temp Range: -55 °C to +105 °C with Tin -55 °C to +125 °C with Gold RoHS Compliant: Yes Lead–Free Solderable: Yes 1 NO. PINS PER ROW 01 thru 40 LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart = Single Row ROW OPTION POST HEIGHT –S –“XXX” = Single Row –D = Post Height Dimension (In inches) = Double Row (2.54) .100 x No. of Positions POST (0.00) .000 MIN 40 RECOGNITIONS (2.54) .100 TYP 01 (2.48) .098 01 thru 36 For complete scope of recognitions see www.samtec.com/quality 72 FILE NO. E111594 –06 (5.03) .198 (2.54) .100 Note: Some lengths, styles and options are non-standard, non-returnable. MTLW Series is non-standard, non-returnable. 01 (0.64) .025 SQ TAIL (0.00) .000 MIN LEAD STYLE – 05 = Double Row 02 (OAL) 71 –07 –08 –09 (1.52) .060 –10 –22 –23 –24 OAL (8.51) .335 (7.62) .300 (10.92) .430 (13.46) .530 (18.54) .730 (21.08) .830 (16.00) .630 (11.30) .445 (12.19) .480 –F = Gold flash on post, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –G = 10 µ" (0.25 µm) Gold on post, Gold flash on tail –T = Matte Tin Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
TLW-104-05-F-S 价格&库存
很抱歉,暂时无法提供与“TLW-104-05-F-S”相匹配的价格&库存,您可以联系我们找货
TLW-104-05-F-S
    • 300+4.30924
    库存:331
