TW-25-06-F-D-428-SM
TW-25-06-F-D-428-SM
    SAMTEC(申泰)
TW-25-06-F-D-428-SM 数据手册
SMT & THROUGH-HOLE BOARD STACKERS 8 4 CLT or MMS SQT G b p s G b p s (2.00 mm) .0787" PITCH • TW SERIES TW Board Mates: CLT, SQT, SQW, ESQT, TLE, SMM, MMS Cable Mates: TCSD TW - - 02 thru 36 SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating: TW-SM = 4.9 A per pin (2 pins powered) TW-TH = 5.2 A per pin (2 pins powered) Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold NO. PINS PER ROW LEAD STYLE 1RRISRVLWLRQV [   ALSO AVAILABLE PLATING OPTION   MOQ Required - NO. PINS PER ROW 02 thru 50 Other Platings End shrouds with or without guide post - —S, —D*, —Q Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. This Series is non-standard, non-returnable. F-224 –S (5.08) .200 –D (6.35) .250 –02 (7.85) .309 –03 (11.86) .467 –04 (12.37) .487 –06 (15.37) .605 –07 (17.35) .683 –09 (9.86) .388 - = Gold flash on post, Matte Tin on tail –L —A OPTION ROW OPTION –S = Single Row –D = Double Row –T = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Triple Row –T = Five Row –Q = Four Row –5 –6 = Six Row (1.27) .050 MIN POST STACKER HEIGHT See OAL Chart ROW OPTION (0.00) .000 MIN —S, —D*, —Q —T, —5, —6 STACKER HEIGHT –S, –D*, –Q (3.05) .120 MIN –T, –5, –6 TAIL –P A = Matte Tin —T, —5, —6 Example: –250 = (6.35 mm) .250" = Pick & Place Pad (1.91 mm) .075" min. post height (04-36 only) –“X”R OAL PLATING OPTION No. of rows x (2.00) .0787 –A = Alignment Pin (Metal or plastic at Samtec discretion) (4.83 mm) .190" min. board space (–D only) ROW OPTION –F Specify LEAD STYLE from chart = Polarized Position $ LEAD STYLE OTHER OPTION –“XXX” = Stacker Height in inches (0.13 mm) .005" increments –D –T LEAD STYLE - SM - STACKER HEIGHT –“XXX” = Double Row = Matte Tin   - –S –L   0,1 - = Single Row = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail 67$&.(5 +(,*+7 2$/   0,1 TW ROW OPTION = Gold flash on post, Matte Tin on tail      - –F Specify LEAD STYLE from chart PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com) - (4.06) .160 MIN *–D with stacker height greater than (4.06 mm) .160" will not have standoffs. - —P OPTION Specify “T” for Tape & Reel Specify “F” for Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (–07 lead style N/A) (–06 lead style with –P option N/A as standard) - STACKER HEIGHT –“XXX” = Stacker Height in inches (0.13 mm) .005" increments Example: –250 = (6.35 mm) .250" LEAD STYLE OAL –01 (8.20) .323 –02 (9.60) .377 –03 (13.60) .535 –04 (14.10) .555 –05 (15.10) .594 –06 (17.10) .673 –07 (19.10) .751 –08* (21.10) .830 –09 (11.60) .456 –10 (15.60) .614 –11 (10.08) .397 –12* (28.19)1.110 TAIL SPEC –“XXX” = Tail Length in inches (0.13 mm) .005" increments Example: -150 = (3.81 mm) .150" –“XXX” = Polarized Position (Specify position to be removed) *Style –08 & –12 = S & D only samtec.com?TW-SM or samtec.com?TW-TH Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TW-25-06-F-D-428-SM 价格&库存
很抱歉,暂时无法提供与“TW-25-06-F-D-428-SM”相匹配的价格&库存,您可以联系我们找货
