233-203
233-203
    WAGO(万可电子)
    插件,P=2.5mm
    接线端子 脚间距:2.50mm 每排Pin数:3 排数:1
233-203 数据手册
1 PCB Terminal Strips 0.5 mm2/AWG 20 Pin Spacing 2.5 mm / 0.098 in; Series 233 Pin spacing 2.5 mm/0.098 in 0.08 – 0.5 mm2 ➊ AWG 28 – 20 ➊ 250 V/2.5 kV/2 150 V, 4 A U 2 6A L 5 – 6 mm / 0.22 in * U 2 K S D a : ; [ 5 q ABS 9 Pin spacing 2.5 mm/0.098 in 0.08 – 0.5 mm2 ➊ AWG 28 – 20 ➊ Accessories * U 2 K S D a : ; [ 5 q ABS No. of Item Pack.-unit poles No. pcs Terminal strips without push buttons, standard lengths, other lengths contact factory, 2 solder pins/pole, grey No. of Item Pack.-unit poles No. pcs Terminal strips with push buttons, standard lengths, other lengths contact factory, 2 solder pins/pole, grey 2 3 4 5 6 7 8 9 10 12 16 24 2 3 4 5 6 7 8 9 10 12 16 24 233-102 233-103 233-104 233-105 233-106 233-107 233-108 233-109 233-110 233-112 233-116 233-124 600 (6 x 100) 500 (4 x 125) 400 (4 x 100) 340 (4 x 85) 280 (4 x 70) 240 (4 x 60) 220 (4 x 55) 200 (4 x 50) 180 (4 x 45) 140 (4 x 35) 100 (4 x 25) 80 (4 x 20) 1 250 V/2.5 kV/2 150 V, 4 A U 2 6A L 5 – 6 mm / 0.22 in 233-202 233-203 233-204 233-205 233-206 233-207 233-208 233-209 233-210 233-212 233-216 233-224 600 (6 x 100) 500 (4 x 125) 400 (4 x 100) 340 (4 x 85) 280 (4 x 70) 240 (4 x 60) 220 (4 x 55) 200 (4 x 50) 180 (4 x 45) 140 (4 x 35) 100 (4 x 25) 80 (4 x 20) Item No. Marker cards, 100 self-adhesive strips per card Marking - pin spacing 2.5 mm/0.098 in 1–16 (400 x) 210-331/0250-0202 17–32 (400 x) 210-331/0250-0204 33–48 (400 x) 210-331/0250-0206 For direct printing, please contact factory Terminal strips without push buttons cannot be retrofitted with push buttons! For other colors, please contact factory For other colors, please contact factory Accessories Operating tool, for shop wiring see section 11 Dimensions (in mm) Diameter of drilled hole: 1.1+0.1 mm L = (No. of poles x pin spacing) + 2.3 mm * Approvals with corresponding ratings see pages 12.3 ff. > 4 < > 4 < ➊ in adjacent positions 0.75 mm2/AWG 18 2,7 0,5 __> < > < 2,5 0,75 2,4 5 >
233-203 价格&库存
很抱歉,暂时无法提供与“233-203”相匹配的价格&库存,您可以联系我们找货
  • 1+18.08884
  • 5+17.74518
库存:113
233-203
