731-138/048-000
731-138/048-000
    WAGO(万可电子)
    插件
    接线端子 间距:5.00mm
731-138/048-000 数据手册
Printview: 1-conductor feedthrough terminal strip; with fixing flanges; 8-pole; pin spacing 5 mm / 0.197 in; Wire-wrap pin 1 x 1 mm; for flush-mounting - Item No.: 731-138/048-000 . 1-conductor feedthrough terminal strip; with fixing flanges; 8-pole; pin spacing 5 mm / 0.197 in; Wire-wrap pin 1 x 1 mm; for flushmounting Item No.: 731-138/048-000 . 1-conductor feedthrough terminal strip; with fixing flanges; 8-pole; pin spacing 5 mm / 0.197 in; Wire-wrap pin 1 x 1 mm; for flush-mounting . Marking . Business data Supplier WAGO Item no. 731-138/048-000 EAN 4044918269841 Content 1 Order amount 25 Customer item number . Notes Feedthrough terminal blocks with screwdriver-actuated CAGE CLAMP®Fixing flanges for mounting on the PCB or at the front panel – either flush with enclosure or protrudingVersions without fixing flange available upon request Technical data Miscellaneous No. of Poles 8 Total number of connection points 8 Total number of potentials 8 Color gray Ratings according to 1 IEC/EN 60664-1 Overvoltage category EN 1 III Pollution degree (1) 2 WAGO Kontakttechnik GmbH & Co. KG 1 Printview: 1-conductor feedthrough terminal strip; with fixing flanges; 8-pole; pin spacing 5 mm / 0.197 in; Wire-wrap pin 1 x 1 mm; for flush-mounting - Item No.: 731-138/048-000 Technical data Rated voltage EN (1) [V] 320 [V] Rated surge voltage (1) [kV] 4 [kV] Nominal current [A] 5 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 630 [V] Bemessungsstossspannung (2) [kV] 4 [kV] Nominal current (2) [A] 5 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 320 [V] Rated surge voltage (3) [kV] 4 [kV] Nominal current (3) [A] 5 [A] Connection technology (1) CAGE CLAMP® Conductor type (1) solid Cross section from (1) [mm²] 0.08 [mm²] Cross section up to (1) [mm²] 2.5 [mm²] Cross section from (1) [AWG] 28 [AWG] Cross section up to (1) [AWG] 14 [AWG] Conductor type (2) fine-stranded Cross section from (2) [mm²] 0.08 [mm²] Cross section up to (2) [mm²] 2.5 [mm²] Conductor type (3) fine-stranded (with insulated ferrule) Cross section from (3) [mm²] 0.25 [mm²] Cross section up to (3) [mm²] 1.5 [mm²] Conductor type (4) fine-stranded (with uninsulated ferrule) Cross section from (4) [mm²] 0.25 [mm²] Cross section up to (4) [mm²] 2.5 [mm²] Stripped length from (1) [mm] 8 [mm] Stripped length up to (1) [mm] 9 [mm] Strip length from [inch] [in] 0.31 [in] Strip length up to [inch] [in] 0.35 [in] Stripped length (1) [in] 0.33 [in] Material group I WAGO Kontakttechnik GmbH & Co. KG 2 Printview: 1-conductor feedthrough terminal strip; with fixing flanges; 8-pole; pin spacing 5 mm / 0.197 in; Wire-wrap pin 1 x 1 mm; for flush-mounting - Item No.: 731-138/048-000 Technical data Insulating material Polyamide 6.6 (PA 6.6) Flammability rating per UL 94 V0 Lower limit temperature -60 [C] [C] Upper temperature limit [C] 105 [C] Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) Contact plating tin-plated Fire load [MJ] 0.206 [MJ] Weight [g] 12.584 [g] Width [mm] 55.2 [mm] Width [in] 2.173 [in] Height [mm] 12 [mm] Height [in] 0.472 [in] Length [mm] 15.5 [mm] Length [in] 0.61 [in] Pin spacing from [mm] 5 [mm] Pin spacing up to [mm] 5 [mm] Pin spacing from [in] 0.197 [in] Pin spacing up to [in] 0.2 [in] Approbation Item No. Registration Registration no. Voltage [V] Current [A] Cross section [mm², AWG] 731-138/048-000 CCA 5764 400 12 1x1 731-138/048-000 CSA 154112-1466354 300 5 28-14 731-138/048-000 KEMA 2083746.02 400 12 1x1 731-138/048-000 UL E45172 300 5 28-14 731-138/048-000 UL E45171 600 15 28-12 Accessories WAGO Kontakttechnik GmbH & Co. KG 3 Printview: 1-conductor feedthrough terminal strip; with fixing flanges; 8-pole; pin spacing 5 mm / 0.197 in; Wire-wrap pin 1 x 1 mm; for flush-mounting - Item No.: 731-138/048-000 Accessories General accessory Item no. Description Pack. unit (Sub Pack) 209-147 Self-tapping screw 100 210-657 Operating tool with partially insulated shaft; blade (3.5 x 0.5) mm; short; suitable for 260, 261, 1 262, 264, 270, 280, 281, 869, 870 and 880 Series 210-658 Operating tool with partially insulated shaft; blade (3.5 x 0.5) mm; short; angled; particularly 1 suitable for 280 Series actuator and sensor terminal blocks and also for Series 260, 261, 262, 264, 280, 281, 869, 870, 880, 2002, 210-720 Operating tool with partially insulated shaft; Type 2, blade (3.5 x 0.5) mm; suitable for 260, 261, 262, 264, 270, 280, 281, 290, 775, 776, 777, 769, 780, 781, 869, 870, 880, 2002, 2003, 2004, 2005 and 2022 Series WAGO Kontakttechnik GmbH & Co. KG 4 1 Printview: 1-conductor feedthrough terminal strip; with fixing flanges; 8-pole; pin spacing 5 mm / 0.197 in; Wire-wrap pin 1 x 1 mm; for flush-mounting - Item No.: 731-138/048-000 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 5 Printview: 1-conductor feedthrough terminal strip; with fixing flanges; 8-pole; pin spacing 5 mm / 0.197 in; Wire-wrap pin 1 x 1 mm; for flush-mounting - Item No.: 731-138/048-000 . WAGO Kontakttechnik GmbH & Co. KG 6 Printview: 1-conductor feedthrough terminal strip; with fixing flanges; 8-pole; pin spacing 5 mm / 0.197 in; Wire-wrap pin 1 x 1 mm; for flush-mounting - Item No.: 731-138/048-000 Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 7
731-138/048-000 价格&库存
很抱歉,暂时无法提供与“731-138/048-000”相匹配的价格&库存,您可以联系我们找货
