BM08B-SURS-TFT(LF)(SN) 数据手册
Emboss Tape
SUR CONNECTOR
0.8mm pitch/Disconnectable Insulation displacement connectors
Specifications –––––––––––––––––––
• Current rating:
The world's first 0.8mm pitch wire-to-board
insulation displacement connector. Side
entry type is only 3.9mm depth and
1.75mm height after mounting on the PC
board, and top entry type is only 2.2mm
depth and 3.9mm height.
Compared to the conventional 1.0mm pitch
SSR connector, occupation space on the
board is reduced by 34% (side entry type).
• 3-point grip construction
• Super fine wires are applicable
• Shrouded header
• Twin U-slot insulation displacement section
0.5A AC, DC (AWG #32)
0.2A AC, DC (AWG #36)
• Voltage rating: 30V DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/20m Ω max.
After environmental testing/40m Ω max.
• Insulation resistance:
100M Ω min.
• Withstanding voltage: 200V AC/minute
• Applicable wire: Conductor size/AWG #32, #36
Conductor/7 strands,
tin-coated copper alloy
Insulation O.D./0.39mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
PC board layout (viewed from component side) and Assembly layout
Top entry type
Side entry type
2.25
2.0
0.8±0.05
0.5 ±0.1
1.7
±0.1
1.75
1.1
3.95
Header outline
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Dimensions above should serve as a guideline. Contact JST for details.
1
0.7 ±0.1
1.2 ±0.1
±0.1
0.8±0.05
0.35
0.5
±0.1
1.0
±0.1
3.9
2.3
1.2
1.7
0.7
0.3
Header outline
SUR CONNECTOR
Socket
Circuits
2
Circuit No.1
3
5
1.25
1.45
1.65
4
6
H JST 5
1.7
0.8
A
B
8
0.8
10
2.9
12
14
15
16
17
Model No.
Dimensions (mm)
#32(Natural)
#36(Lemon yellow)
A
B
02SUR-36L
02SUR-32S
0.8
2.4
03SUR-36L
03SUR-32S
1.6
3.2
04SUR-36L
04SUR-32S
2.4
4.0
05SUR-36L
05SUR-32S
4.8
3.2
06SUR-36L
06SUR-32S
4.0
5.6
08SUR-36L
08SUR-32S
5.6
7.2
10SUR-36L
10SUR-32S
7.2
8.8
12SUR-36L
12SUR-32S
8.8
10.4
14SUR-36L
14SUR-32S
10.4
12.0
15SUR-36L
15SUR-32S
11.2
12.8
16SUR-36L
16SUR-32S
12.0
13.6
17SUR-36L
17SUR-32S
12.8
14.4
20SUR-36L
20SUR-32S
15.2
16.8
22SUR-36L
22SUR-32S
18.4
16.8
Q'ty / box
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
Material and Finish
Contact: Copper alloy, tin-plated (reflow treatment)
Housing: PA, UL94V-0
RoHS compliance
Shrouded header
Top entry type
Circuits
2
2.0
B
3
4
5
2.7
6
8
10
0.6
A
12
1.0
14
15
Side entry type
16
17
Circuit No.1
B
A
22
0.8
Dimensions (mm)
Model No.
A
B
Top entry type
Side entry type
BM02B-SURS-TF SM02B-SURS-TF
0.8
3.8
BM03B-SURS-TF SM03B-SURS-TF
1.6
4.6
BM04B-SURS-TF SM04B-SURS-TF
5.4
2.4
SM05B-SURS-TF
3.2
6.2
SM06B-SURS-TF
7.0
4.0
BM08B-SURS-TF SM08B-SURS-TF
5.6
8.6
BM10B-SURS-TF SM10B-SURS-TF
10.2
7.2
BM12B-SURS-TF SM12B-SURS-TF
8.8
11.8
SM14B-SURS-TF
10.4
13.4
BM15B-SURS-TF SM15B-SURS-TF
14.2
11.2
SM16B-SURS-TF
15.0
12.0
SM17B-SURS-TF
12.8
15.8
BM20B-SURS-TF SM20B-SURS-TF
18.2
15.2
SM22B-SURS-TF
16.8
19.8
Q'ty / reel
Top entry type Side entry type
2,500
3,500
2,500
3,500
2,500
3,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
3,500
2,500
3,500
3,500
2,500
3,500
3,500
3,500
3,500
2.7
Material and Finish
1.75
Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA, UL94V-0, natural
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
1.0
0.2
1.0
0.45
RoHS compliance This product displays (LF)(SN) on a label.
Note: The products listed above are supplied on embossed-tape.
2
