FTSH-120-01-LM-D
FTSH-120-01-LM-D
    SAMTEC(申泰)
    .050'' X .050 TERMINAL STRIP
FTSH-120-01-LM-D 数据手册
F-218 (Rev 10OCT17) FTSH–110–01–L–DV 10 YEAR MFG WITH 30 µ" GOLD FTSH–120–01–F–DV EXTENDED LIFE PRODUCT HIGH MATING CYCLES FTSH–125–01–L–DV–EJ (1.27 mm) .050" SMT MICRO HEADER SPECIFICATIONS Board Mates: CLP, FLE APPLICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?FTSH Cable Mates: FFSD, FFTP CLP FTSH OTHER SOLUTIONS OPTIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (FTSH/CLP): 3.4 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C RoHS Compliant: Yes –ES OPTION (1.27 mm) .050" –P OPTION HORIZONTAL –EC OPTION –EP OPTION PROCESSING Ultra-low profile option available. End Shrouds available. Call for FTS Series specifications. Lead-Free Solderable: Yes SMT Lead Coplanarity: –MT & –DV Tail Option: (0.10 mm) .004" max (02-25) –MT & –DH Tail Option: (0.15 mm) .006" max (26-50)* *(.004" stencil solution may be available; contact IPG@samtec.com) –EJ OPTION –EL OPTION LEAD STYLE NO. PINS PER ROW 1 FTSH –TR OPTION RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –01 = (3.05 mm) .120" Post (Mates with FFSD, CLP–DH) 02 thru 50 –02 FILE NO. E111594 ALSO AVAILABLE • Molded Pick & Place pads • Latches • Other platings Contact Samtec. A No. of positions x (1.27) .050 + Z (MOQ Required) 100 02 (4.78) .188 (1.27) .050 01 –EX OPTION SHOWN (5.64) .222 Z – ES (2.57) .101 (15.77) .621 (3.33) .131 (5.87) .231 (6.53) .257 –EC 100 –EP –EL (3.43) .135 (1.27) .050 01 OPTION –EJ –EJ OPTION SHOWN No. of positions x (1.27) .050 (0.40) .016 SQ 99 A A Notes: Some sizes, styles and options are non-standard, non-returnable. See SFM/TFM for positive alignment feature. = (1.65 mm) .065" Post (Mates with CLP–D) –04 –DH (Styles –01, –02, –04 only) No. of positions x (1.27) .050 + Z 02 –03 (0.81) .032 (0.51) .020 (2.29) .090 99 = (1.91 mm) .075" Post (Mates with FLE) (5.33) .210 = (3.81 mm) .150" Post –05 = (4.32 mm) .170" Post (Mates with CLP–BE) LEAD STYLE – 01 (5.08) .200 (1.27) .050 (5.84) .230 – DV – 05 (1.27) (0.81) (2.29) .050 .032 .090 –MT (Styles –01, –02 & –04 only) Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM – 03 – 04 (2.51) .099 (2.92) .115 – 02 All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. A (3.05) .120 (1.91) .075 (1.65) .065 (3.81) .150 (4.32) .170 FTSH–112–02–L–DH FTSH–130–02–L–DV–EP FTSH–116–02–L–DV FTSH–110–01–F–DV FTSH–116–03–L–DV–EP–P FTSH SERIES Optional guide post (2.92 mm) .115" Surface mount Optional end shrouds and ejector shrouds (1.27 mm) .050" micro pitch PLATING OPTION –F TAIL OPTION OPTION –DV Leave Blank for -DH & -MT = Gold flash on post, Matte Tin on tail = Double Vertical –L = Double Horizontal (Styles –01, –02 & –04 only) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Polarized Position (Specify position of omitted pin) (Not available with -EX options) –MT = Mixed Technology (Styles –01, –02 & –04 only) –ES –EL = End Shroud = End Shroud with Board Lock (Boards are positively locked and cannot be unmated) –EC = End Shroud with Locking Clip (Manual placement required) –EP = End Shroud with Guide Post (1.91) .075 DIA (3.05) .120 (3.05) .120 (1.22) .048 (4.83) .190 – EC (0.89) .035 DIA (2.16) .085 (5.08) .200 (11.18) .440 (3.20) .126 –EJ –C = (5.00 mm) .197" DIA Polyimide film Pick & Place Pad (–DH only) –P –A (3.30) .130 x (5.08) .200 –K = Pick & Place Pad (–DV 4 positions min.) (–DH & –MT not available) (0.86) .034 –TR (4.10) .160 (2.29) .090 –EL –A = Alignment Pin (–DV 3 positions min.) (–DH 5 positions min.) (Metal or plastic at Samtec discretion) = Ejector Shroud (Style –01 only) –DH & –MT not available 10 pins/row minimum 25 pins/row maximum –EP (1.17) .046 = Keying Shroud (For mating with FFSD Style –01 only and 05, 08, 10, 13, 17, 20 & 25 pins/row only. 13, 17, 20 & 25 pins/row only with –EJ option) (–DV only) –EJ (4.83) .190 –ES –K (Style –02 & –03 only, –DH & –MT not available) 9 pins/row minimum (Other positions available. Call Samtec.) –“XXX” –DH OTHER OPTIONS FLEX SHROUD OPTIONS = Tape & Reel Packaging (Flex Shroud options not available except –ES & –EJ) –P Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
FTSH-120-01-LM-D 价格&库存
很抱歉,暂时无法提供与“FTSH-120-01-LM-D”相匹配的价格&库存,您可以联系我们找货
