MECT-135-01-M-D-RA1-TR
    SAMTEC(申泰)
    70 位置 SFP+ 插座 连接器 焊接 表面贴装,直角
MECT-135-01-M-D-RA1-TR 数据手册
F-217 MECT–110–01–M–D–RA1 MECT–135–01–M–D–RA1 MECT–115–01–M–D–RA1 (0.80 mm) .0315" MECT SERIES SFP & SFP+ TRANSCEIVER INTERFACES SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?MECT 2x10 position for Small Form Factor Pluggable (SFP & SFP+) Fiber Optic Transceivers Mates with: SFP, SFP+, XFP or XENPAK transceivers Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Sn or Au over 100 µ" (2.54 µm) Ni Operating Temp Range: -55 °C to +125 °C Current Rating: 2 A per pin (6 pins powered) Voltage Rating: 265 VAC RoHS Compliant: Yes Alignment pin 2x10, 2x15 and 2x35 position for XENPAK and XFP Transceivers PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (10-35) RECOGNITIONS MECT 1 For complete scope of recognitions see www.samtec.com/quality POSITIONS PER ROW CARD THICKNESS Choice of three standard pin counts PLATING OPTION –01 = (1 mm) .039" thick board 10, 15, 35 FILE NO. E111594 OTHER OPTION RA1 –TR = Tape & Reel Packaging –M = 15 µ" (0.38 µm) Gold on contact, Matte Tin on tail No. of Positions x (0.80) .0315 + (3.00) .118 APPLICATION MECT SFPC D (7.40) .291 Press-Fit, Solder Tail or PCI Press-Fit Cage 01 02 (0.80) .0315 No. of Positions x (0.80) .0315 + (1.40) .055 Transceiver or Patch Cable (1.20) .047 (5.20) .205 (2.65) .104 (0.90) (1.40) .035 x .055 DIA (1.40) .055 DIA (3.25) .128 (0.95) .037 (9.10) .358 Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (1.05) .041
MECT-135-01-M-D-RA1-TR 价格&库存
很抱歉,暂时无法提供与“MECT-135-01-M-D-RA1-TR”相匹配的价格&库存,您可以联系我们找货
  • 375+46.20973375+5.99718
  • 750+43.28562750+5.61769
库存:56
  • 1+76.437951+9.92025
  • 10+64.9674510+8.43159
  • 25+60.8924725+7.90273
  • 50+57.9867450+7.52562
  • 100+55.21849100+7.16636
库存:56
