F-215
MIS–019–01–F–D
MIS–057–01–L–D
MIS–038–01–F–D
(0,635 mm) .025"
MIS SERIES
MIXED TECHNOLOGY SOCKET
SPECIFICATIONS
Board Mates:
MIT
For complete specifications and
recommended PCB layouts see
www.samtec.com?MIS
Cable Mates:
MICD
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +125°C
Voltage Rating:
275 VAC
Max Cycles:
100
RoHS Compliant:
Yes
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (019-057)
Board Stacking:
For applications requiring more
than two connectors per board
contact ipg@samtec.com
RECOGNITIONS
Integral metal plane
for power or ground
Polarized
• Mixed
technology
footprint
MIT/MIS
Type Rated @ 3dB Insertion Loss*
5 mm Stack Height
Single-Ended Signaling
–D
8.5 GHz / 17 Gbps
Differential Pair Signaling –D
8.5 GHz / 17 Gbps
Differential Pair Signaling –DP
9.5 GHz / 19 Gbps
*Performance data includes effects of a non-optimized PCB.
Performance data for other stack heights and complete
test data available at www.samtec.com?MIS or contact
sig@samtec.com
MIS
76 signal lines
per linear inch
OTHER SOLUTIONS
• Board Spacing Standoffs.
See SO Series.
NO. OF POSITIONS
PER ROW
01
PLATING
OPTION
D
For complete scope of
recognitions see
www.samtec.com/quality
–K
–F
–019, –038, –057
= Gold Flash on Signal Pins and
Ground Plane, Matte Tin on tails
(38 total positions per bank)
ALSO AVAILABLE
–L
(MOQ Required)
• 11 mm, 16 mm, 18,75 mm
and 22 mm stack height
• 30µ" (0,76 µm) Gold
• Differential Pair and
“Partitionable” (combine
differential & single-ended
banks in same connector)
available.
• 76, 95, 114 and 133
positions per row
• Edge Mount
= 10µ" (0,25 µm)
Gold on Signal Pins and
–C*
= Electro-Polished Selective
50µ" (1,27 µm) min Au over
150µ" (3,81 µm) Ni on
Signal Pins in contact area,
10µ" (0,25 µm) min Au over
50µ" (1,27 µm) Ni on Ground
Plane in contact area, Matte Tin
over 50µ" (1,27 µm) min Ni
on all solder tails
(No. of Positions/19) x (12,70) .500 + (12,70) .500
(12,70) .500
01
(6,22)
.245
Contact Samtec.
(0,635)
.025
02
(0,15)
.006
(1,32)
.052
(3,43)
.135
(0,69) .027
(3,63)
.143
(7,49)
.295
(0,18)
.007
*Note: –C Plating passes
10 year MFG testing
Note: Some lengths, styles
and options are non-standard,
non-returnable.
OTHER
OPTION
Note: Rugged through-hole ground plane soldered to board
(requires paste-over-hole, not press fit) for added retention to PCB.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
= (7,00 mm)
.275" DIA
Polyimide
film Pick &
Place Pad
–TR
= Tape &
Reel
很抱歉,暂时无法提供与“MIS-019-01-L-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+79.360831+10.31498
- 112+56.55061112+7.35020
- 国内价格 香港价格
- 56+79.2148656+10.29600
- 112+59.91894112+7.78800
- 国内价格 香港价格
- 1+75.016141+9.75027
- 国内价格
- 56+64.21532
- 112+48.52120
- 448+43.21325
- 952+32.74244
- 4088+22.19908
