F-224 SUPPLEMENT
MIS–019–01–F–D
MIS–057–01–L–D
MIS–038–01–F–D
MIS SERIES
(0.635 mm) .025"
MIXED TECHNOLOGY SOCKET
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?MIS
Board Mates:
MIT
Standoffs:
SO
Integral metal plane
for power or ground
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
275 VAC
Max Cycles:
100
RoHS Compliant:
Yes
Polarized
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (019-057)
Board Stacking:
For applications requiring more
than two connectors per board
contact ipg@samtec.com
76 signal lines
per linear inch
MIS
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
POSITIONS
PER ROW
D
= Gold Flash on Signal Pins and
Ground Plane, Matte Tin on tails
—L
Leave blank for
tray packaging
= (7.00 mm)
.275" DIA
Polyimide film
Pick &
Place Pad
—TR
=Tape & Reel
—FR
= 10 µ" (0.25 µm) Gold on
Signal Pins and Ground Plane,
Matte Tin on tails
ALSO AVAILABLE
(MOQ Required)
—C*
• 11 mm, 16 mm, 18.75 mm
and 22 mm stack height
• 30 µ" (0.76 µm) Gold
• Differential Pair and
“Partitionable” (combine
differential & single-ended
banks in same connector)
available.
• 76, 95, 114 and 133
positions per row
= Electro-Polished Selective
50 µ" (1.27 µm) min Au over
150 µ" (3.81 µm) Ni on Signal Pins
in contact area, 10 µ" (0.25 µm) min Au
over 50 µ" (1.27 µm) Ni on Ground Plane
*Note:
in contact area, Matte Tin over 50 µ"
–C Plating passes 10 year
(1.27 µm) min Ni on all solder tails
MFG testing
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(No. of Positions/19) x (12.70) .500 + (12.70) .500
(12.70) .500
01
(6.22)
.245
MATED HEIGHT*
(0.635) .025
(0.15) .006
MIS
LEAD
STYLE
02
(1.32)
.052
(3.43)
.135
(0.69) .027
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
PACKAGING
OPTION
—K
—F
—019, —038, —057
(38 total positions per bank)
FILE NO. E111594
PLATING
OPTION
01
Note: Rugged through-hole ground plane soldered to board
(requires paste-over-hole, not press-fit) for added retention to PCB.
(7.49)
.295
(3.63)
.143
(0.18)
.007
–01
MIT LEAD
STYLE
–01
–02
(5.00) (8.00)
.197 .315
*Processing conditions
will affect mated height.
See SO Series for board
space tolerances.
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“MIS-114-01-F-D”相匹配的价格&库存,您可以联系我们找货
