RF174-02SJ1-02SJ1-0200
    SAMTEC(申泰)
    SAMTEC - RF174-02SJ1-02SJ1-0200 - RF COAX CABLE, MCX, RG174, 26AWG, 200MM
RF174-02SJ1-02SJ1-0200 数据手册
RF-16 RF174–07SP1–01BJ1–0300 RF174–01RP1–02RP1–0200 50Ω RG 174 CABLE ASSEMBLIES SPECIFICATIONS For complete specifications see www.samtec.com?RF174 Standard performance 26 AWG RG 174 coax cable Mates with: MCX, MMCX, MMCXV, SMA, SMB5, BNC5, TNC, NTPE Plugs and Jacks RF Connector: Outer Contact Material: Ni plated Brass (BNC) Au plated Brass (SMB & SMA) Au plated BeCu (MCX & MMCX) Center Contact Material: Au plated Brass (BNC-P, MCX-P, MMCX-P & SMA-P) Au plated BeCu (SMB-P & SMA-J) Au plated Phos. Bronze (BNC-J) Insulator Material: PTFE Operating Temperature: -50°C to +90°C Insulator Resistance: 5,000 MΩ Impedance: 50Ω Frequency Range: 0~6 GHz (Cable & connector dependent) RoHS Compliant: Yes RG 174 Cable: Impedance: 50Ω Capacitance: 101.024 pF/meter Max Attenuation (cable only): 1.4dB @ 1 GHz for 1 meter Conductor Size: 26 AWG, (0.48 mm) .019" dia. Conductor Material: Copper Insulator Material: LEP Shield Material: Tin Copper Jacket Material: PVC Jacket Diameter: (2.70 mm) .106" Jacket Color: Black Bend Radius: 25.4 mm RoHS Compliant: Yes 2.3dK THINK OUTSIDE THE CATALOG • Create a full system: cable assembly and board level mates, 50Ω and 75Ω solutions • 24-hour samples on standard products • Visit: rf.samtec.com Single or Double Ended Straight or Right Angle END 1 CONNECTOR CABLE TYPE END 2 CONNECTOR Specify END OPTIONS from chart RF174 = RG 174 Cable –01SP1–01RP1 SHOWN XXXX = OAL (millimeters) END OPTIONS –01SP1 = SMA Straight Plug (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) END OPTIONS –02RP1 = MCX Right Angle Plug (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) –02SP1 = MCX Straight Plug (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) –03SP1 = MMCX Straight Plug (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) –03RP1 = MMCX Right Angle Plug (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) –V3SP1 = MMCXV Straight Plug, High Vibration (30µ" (0.76 µm) Gold on Center Contact, Nickel on Shell) –V3RP1 = MMCXV Right Angle Plug, High Vibration (30µ" (0.76 µm) Gold on Center Contact, Nickel on Shell) –V3SJ1 = MMCXV Straight Jack, High Vibration (30µ" (0.76 µm) Gold on Center Contact, Nickel on Shell) –01RP1 = SMA Right Angle Plug (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) –07SP1 = SMB Straight Plug (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) –07RP1 = SMB Right Angle Plug (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) –02SJ1 = MCX Straight Jack (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. RF174–02RP1–02SP1–0200 RF174–03RP1–07RP1–0200 RF174–04BJ2–07SP1–0100 RF174 SERIES Variety of Bulkhead Jacks Heavy Gold plated Standard heat shrink wraps Single or Double ended ALSO AVAILABLE (MOQ Required) • Additional stripping and tinning options • IP67 TNC option • Additional plating options • Additional end connector combinations • Knurled nuts with BNC option Contact Samtec. Choice of RF connector styles OTHER SOLUTIONS • Cable connector kits (see cable components catalog pages) OVERALL LENGTH –“XXXX” = Overall Length in millimeters –0100 (100 mm) minimum (Cable lengths larger than 1000 millimeters are not supported by S.I. Test data) END OPTIONS END OPTIONS –04SP3 = BNC Straight Plug (10µ" (0.25 µm) Gold on Center Contact, Nickel on Shell) –01PN1 = SMA 4-Hole Panel Mount Jack (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) –05SP3 = TNC Straight Plug (10µ" (0.25 µm) Gold on Center Contact, Nickel on Shell) –04BJ2 = BNC Bulkhead Jack (30µ" (0.76 µm) Gold on Center Contact, Nickel on Shell) –07BJ1 = SMB Bulkhead Jack (30µ" (0.76 µm) Gold on Center Contact, Gold flash on Shell) –01BJ1 = SMA Straight Bulkhead Jack –01SB1 = SMA Straight Bulkhead Jack, Sealed –01SR1 = SMA Straight Bulkhead Jack, Sealed, Reversed Polarity –01BR1 = SMA Straight Bulkhead Jack, Reversed Polarity END OPTIONS –SING = Single Ended (End 2 Callout) XXXXXX = Stripped & Tinned (End 2 Callout) B C A STRIPPED & TINNED (Dimensions in mm) –05BJ3 = TNC Bulkhead Jack (10µ" (0.25 µm) Gold on Center Contact, Nickel on Shell) –06BJ2 = N Type Bulkhead Jack (30µ" (0.76 µm) Gold on Center Contact, Nickel on Shell) (30µ" (0.76 µm) Gold on Center Contact, Gold Flash on Shell) WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. CALLOUT –303030 –303040 –403030 –403040 –404040 A 3.0 3.0 4.0 4.0 4.0 B 3.0 3.0 3.0 3.0 4.0 C 3.0 4.0 3.0 4.0 4.0 Both center conductor and braid shield are stripped, only the center conductor is tinned.
RF174-02SJ1-02SJ1-0200 价格&库存
很抱歉,暂时无法提供与“RF174-02SJ1-02SJ1-0200”相匹配的价格&库存,您可以联系我们找货
