SFC-135-T2-F-D
SFC-135-T2-F-D
    SAMTEC(申泰)
    SMD,P=1.27mm
    排母 间距:1.27mm 2x35P 立贴
SFC-135-T2-F-D 数据手册
F-215 SFC–135–T2–L–D–A–K SFC–120–T2–L–D–A ™ SFC–110–T1–L–D–A SYSTEM (1,27 mm) .050" SFC SERIES COST SAVING RELIABLE SOCKET SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SFC Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating: 2.9 A per pin (1 pin powered per row) Voltage Rating: 350 VAC mated with TFC Operating Temp Range: -55°C to +125°C Contact Resistance: 15 mΩ Insertion Depth: (3,05 mm) .120" to (4,06 mm) .160" Insertion Force: (Single contact only) 2.5 oz (0,69 N) avg. Withdrawal Force: (Single contact only) 2.0 oz (0,56 N) avg. Max Cycles: 10,000 with 30µ" (0,76 µm) Au RoHS Compliant: Yes Alignment pin option Slotted SMT tails Polarized SFC 1 NO. PINS PER ROW Processing: LEAD STYLE PLATING OPTION OPTION D –T1 Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (04-25) (0,15 mm) .006" max (30-50) 04, 05, 10, 15, 20, 25, 30, 35, 40, 45, 50 RECOGNITIONS (Standard sizes) For complete scope of recognitions see www.samtec.com/quality FILE NO: 090871_0_000 (1,27 mm x 1,27 mm) .050" x .050" micro pitch High reliability Tiger Eye™ LITE contacts Mates with: TFC, TFSD, TFSDT (2,03) .080 –A = Through-hole Tiger Eye™ LITE = Alignment Pin –F = Gold flash on contact, Matte Tin on tail –T2 = Surface Mount Tiger Eye™ LITE –K = (4,00 mm) .157" DIA Polyimide film Pick & Place Pad –L = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail (1,27) .050 x No. of Positions + (3,94) .155 except for alignment pin option: (1,27) .050 x No. of Positions + (3,17) .125 –TR = Tape & Reel (–T2 only) (1,27) .050 (1,27) .050 x No. of Positions + (0,38) .015 02 ALSO AVAILABLE (3,68) .145 (MOQ Required) (3,05) .120 (1,27) .050 TYP • Other sizes Contact Samtec. 01 (1,59) .063 (1,27) .050 (4,57) .180 –A OPTION (0,58) .023 (0,13) .005 TYP (2,79) .110 (0,51) .020 (0,51) .020 (3,05) .120 (0,13) .005 TYP –T1 Note: Some sizes, styles and options are non-standard, non-returnable. (1,27) .050 DIA WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (4,19) .165 –T2
SFC-135-T2-F-D 价格&库存
很抱歉,暂时无法提供与“SFC-135-T2-F-D”相匹配的价格&库存,您可以联系我们找货
SFC-135-T2-F-D
  • 12+42.7674312+5.55774
