CPTCONNECTOR
Board-to-wire
Features
●Compact design
2.0 mm pitch is realized miniaturization and low profile as the
connector for automobile.
●Terminal construction
Female terminal is designed for simple box structure by having
spring structure on male terminal.
Developed in pursuit of miniaturization and low profile
as PC board connector for automobile.
This connector is surface mounting type connector
having the spring structure on male terminal disproving
the conventional concept.
Specifications
¡Current rating: 3 A AC, DC (0.3 mm2, Single circuit)
¡Voltage rating: 50 V AC, DC
¡Temperature range: -40°C to +100°C
(including temperature rise in applying
electrical current)
¡Contact resistance: Initial value/ 8 mΩ max.
After environmental tests/ 16 mΩ max.
¡Insulation resistance: 100 MΩ min.
¡Withstanding voltage: 1,000 VAC/minute
¡Applicable wire: AESSX-f/ AVSS
0.3 mm2
∗ Compliant with ELV/RoHS.
∗ Contact JST for details.
1
CPTCONNECTOR
Female terminal
Applicable wire range
Conductor
(mm2)
Insulation O.D.
(mm)
Q’ty/reel
SCPT-A021GF-0.5
0.3
1.4
15,000
Material and Finish
Brass, nickel-undercoated, Contact area; gold-plated
Barrel area; tin-plated
5.5
1.4
5.5
Model No.
Female connector
Single row
12.5
¡2 circuits
0.8
6.6
Housing
2
Retainer
6
¡4 circuits
04CPT-B1-2A
13.5
13.5
04CPT-B1-2B
Housing
2
Retainer
2
2 X3=6
2×3=6
10
10
0.8
0.8
6.6
6.6
Housing
Retainer
13.5
¡8 circuits
0.8
6.6
Housing
2
Retainer
2X7=14
18
2
CPT CONNECTOR
Female connector
Double row
¡20 circuits
12.5
13.5
¡8 circuits
Housing
2
Retainer
0.8
0.8
9.1
9.1
Housing
2
2×3=6
2×9=18
10
22
¡24 circuits
13.5
13.5
¡12 circuits
Retainer
Housing
2
Retainer
0.8
0.8
9.1
9.1
Housing
2
2×5=10
2×11=22
14
26
Retainer
¡16 circuits
12.5
Type
Circuits
2
Single row
4
9.1
Housing
0.8
Double row
2
2×7=14
18
3
Retainer
Model No.
02CPT-B-2A
04CPT-B1-2A
04CPT-B1-2B
Q’ty/box
500
600
8
08CPT-B1-2A
400
8
08CPT-B-2A
500
12
12CPT-B-2A
300
16
16CPT-B-2A
250
20CPT-B-2A
250
24
24CPT-B-2A
200
Material and Finish
Housing: Glass-filled PBT, Black
Retainer: Glass-filled PBT, Blue
CPT CONNECTOR
Male connector
Top entry type
Double row
¡8 circuits
Single row
¡2 circuits
15.6
10.5
12.7
1
4
1
8
5
9.2
2
Circuit No.
2.5
6.8
2
Circuit No.
2
11.7
Side entry type
Single row
¡2 circuits
2
14.1
15.2
11.6
10.6
6.8
Circuit No.
2
1
¡4 circuits
SM04B1-CPTK-1A-TB
SM04B1-CPTK-1B-TB
6
6
15.2
18.1
15.6
15.2
18.1
15.6
10.6
10.6
Circuit No.
4
1
6.8
6.8
Circuit No.
4
1
4
CPT CONNECTOR
Male connector
Side entry type
Single row
¡12 circuits
¡8 circuits
14
11
26.1
15.2
23.6
22.1
10.6
15.2
Circuit No.
8
Circuit No.
¡20 circuits
19
30.1
15.2
Circuit No.
2.5
27.6
10
1
9.3
5
6
1
12
7
1
10.6
9.3
6.8
2.5
19.6
10.6
CPT CONNECTOR
Male connector
Side entry type
Double row
¡16 circuits
¡8 circuits
7
15
15.2
Circuit No.
1
8
1
16
9
10.6
9.3
8
Circuit No.
23.6
9.3
4
15.2
26.1
10.6
2.5
15.6
2.5
18.1
5
¡24 circuits
23
Type
Circuits
Top type
34.1
15.2
31.6
10.6
9.3
1
2.5
12
24
Side type
13
Q’ty/reel
2 (Single)
BM02B-CPTK-1A-TB
370
8 (Double)
BM08B-CPTK-1A-TB
240
2 (Single)
SM02B-CPTK-1A-TB
500
4 (Single)
Circuit No.
Model No.
SM04B1-CPTK-1A-TB
SM04B1-CPTK-1B-TB
500
8 (Single)
SM08B1-CPTK-1A-TB
500
8 (Double)
SM08B-CPTK-1A-TB
390
12 (Double)
SM12B-CPTK-1A-TB
390
16 (Double)
SM16B-CPTK-1A-TB
390
20 (Double)
SM20B-CPTK-1A-TB
390
24 (Double)
SM24B-CPTK-1A-TB
390
Material and Finish
Terminal: Copper alloy, nickel-undercoated,
Solder tail; tin-plated (reflow treatment)
Housing: Glass-filled LCP, Black
Peg: Brass, nickel-undercoated, tin-plated (reflow treatment)
6
CPT CONNECTOR
Taping Specifications
Top entry type
¡2 circuits
1.5+0.1
Cover tape
28.4
φ380±2
14.2±0.1
2
Feeding direction
32±0.3
±0.1
1.75±0.1
4±0.1
Feeding direction
±0.1
¡2, 8 circuits
Carrier tape
(φ13)
33.5+2.5
-1
2±0.5
16
±0.1
¡8 circuits
1.5+0.1
Connector
mounting part
28.4
Leader
part
100min.
The end
part
160min.
Cover tape
400min.
32 ±0.3
Cover tape leader
14.2±0.1
Carrier tape
±0.1
1.75±0.1
Feeding direction
4±0.1
±0.1
Feeding direction
Carrier tape
24±0.1
Side entry type
¡2, 4, 8, 12, 16, 20, 24 circuits
1.75±0.1
Feeding direction
4±0.1
1.5+0.1
Cover tape
C
±0.1
φ380±2
B±0.1
2±0.1
D±0.3
Feeding direction
Carrier tape
(φ13)
A+2.5
-1
2±0.5
20±0.1
Feeding direction
Carrier tape
Cover tape leader
Type
The end
part
160min.
Leader
part
100min.
Connector
mounting part
Single
400min.
Double
7
Circuits
A
B
C
D
2
33.5
14.2
28.4
32
4
33.5
14.2
28.4
32
8
45.5
20.2
40.4
44
8
45.5
20.2
40.4
44
12
45.5
20.2
40.4
44
16
45.5
20.2
40.4
44
20.2
40.4
44
24
57.5
26.2
52.4
56
CPT CONNECTOR
PC board layout, Assembly layout
Top entry type
¡8 circuits
¡2 circuits
15.7±0.1
6.8
±0.05
16.1
6.2±0.05
16
11.8±0.1
±0.1
5.8
3±0.05
4.9±0.05
Circuit No.1
1
9.2
1.6±0.05
Circuit No.1
5.5±0.05
1.85
13.5
4.95±0.05
14.5
Circuit No.2
3±0.05
4.35±0.05
1.35±0.05
8.2
10.9±0.1
2±0.05
Circuit No.8
4.75±0.05
2±0.05
1±0.05
6±0.1
Side entry type
¡2, 4, 8 (Single) circuits
¡4 circuits
¡2 circuits
a
1
19.6
Circuit No.a
Circuit No.1
16
1
6.8
6.8
Circuit No. a
20.6
15
A±0.05
3.3±0.05
0.75±0.03
2±0.05
20.6
Circuits
A
B
2
2
15.8
4
6
19.8
8 (Single)
14
27.8
3.85±0.05
7.4±0.05
B±0.1
16
6.8
5±0.05
8.8±0.05
¡8 (Single) circuits
¡8 (Double), 12, 16, 20, 24 circuits
Circuit No.a
Circuit No.1
a
¡8 (Double) circuits
¡12 circuits
20.6
19.6
1
16
15
b
Circuit No.c
Circuit No.
a c
9.3
Circuit No.b
9.3
c
1b
0.75±0.03
¡20, 24 circuits
¡16 circuits
1±0.05
20.6
19.6
A
B
8 (Double)
7
19.8
12
11
23.8
16
15
27.8
31.8
24
23
35.8
3.85±0.05
6.4±0.05
B±0.1
16
9.3
5±0.05
8.8±0.05
Circuits
15
9.3
3.3±0.05
A±0.05
Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers.
2. The dimensions above should serve as guideline. Contact JST for details.
Crimping machine, Applicator
Crimp applicator MKS-L
Strip terminal
Crimping
machine
Dies
Crimp applicator with dies
SCPT-A021GF-0.5
AP-K2N
MK/SCPT-A021-05
APLMK SCPT-A021-05
Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal.
8
很抱歉,暂时无法提供与“SM04B1-CPTK-1A-TB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+17.33696
- 125+16.95581
- 250+16.61632
- 国内价格
- 125+16.95581
- 250+16.61632
- 国内价格 香港价格
- 1+22.099401+2.87240
- 10+20.1710010+2.62180
- 25+19.1169025+2.48480
- 100+17.71550100+2.30260
- 250+15.69120250+2.03950
- 500+13.23570500+1.72040
- 1000+13.151801000+1.70950
- 2500+12.445102500+1.61760
- 5000+11.666605000+1.51640
