TCMD-22-D-10.00-01-D03-M
    SAMTEC(申泰)
    2MM DOUBLE ROW MALE IDC ASSEMBLY
TCMD-22-D-10.00-01-D03-M 数据手册
TIGER ™ IDC EYE HIGH-RELIABILITY IDC HEADER CABLE (2.00 mm) .0787" PITCH • TCMD SERIES TCMD Mates: SMM*, MMS*, ESQT, PTF, SQT, SQW, TLE SPECIFICATIONS Insulator Material: Black Glass Filled Polyester Terminal: Phosphor Bronze Plating: Au or Sn over 50 μ" (1.27 μm) Ni Wire: 28 AWG 7/36 Stranded, Tinned, Copper with Gray PVC Insulator Current Rating: 2.6 A per pin (2 pins powered) Operating Temp Range: -40 °C to +105 °C SERIES - TCMD - NO. PINS PER ROW –04,–05, –07 –08, –10, –12, –13, –15, –17, –20, –22, –25 = Terminal Strip (Standard sizes) - END OPTION –S OVERALL LENGTH - 01 - –“XX.XX” = Single End = Assembled Length –D = Double End –T = Transfer End TRANSFER OPTION Leave blank for –S and –D End Options. For –T End Option Specify “–N” (Socket has notch polarization) - OTHER OPTION –P “XX” = Position Polarization (Specify “XX” as position number. Requires Transfer End. Only Socket is polarized.) –B “XX” = Breakout (Specify “XX” as number of conductors to be broken out) –RW = Reverse Wiring (Blue or black wire opposite position #1) 01 (4.00) .158 –D “XX” ALSO AVAILABLE MOQ Required = Daisy Chain No. of positions x (2.00) .0787 + (4.00) .158 Other sizes –SR (5.08) .200 = Strain Relief (Not available with –O, –M, –R, –DXX or –BXX) Assembled Length in INCHES (±1/8") 2 inches minimum –R = Reversed Assembled Length (–“XX.XX”) Single End (—S) –M = Middle Reversed (Requires –DXX) –O = Outside Reversed (Requires –DXX) 01 02 “XX” Double End (—D) Transfer End (—T) Position Polarization (—P “XX”) 2" min. 01 *Note: Standard TCMD callout will not mate with SMM, MMS. Must use gold plated callouts. (See drawing on web.) When mated with a socket, Wire 1 mates with Pin 2; Wire 2 mates with Pin 1, etc. Note: TCMD Series assemblies are non-standard, non-returnable. 02 4" minimum “XX” ± 1/8" Double Row Connectors Outer Most (End of assembly) Reverse Wiring (—RW) Daisy Chain (—D “XX”) Reversed (—R) Middle Reversed (—M) 5"max. 2"min. Breakout starts with Number 1 lead indicated by brown wire or red stripe. Shown on top side. Breakout (—B “XX”) No. of positions x (2.00) .0787 + (7.874) .3100 Strain Relief (—SR) Outside Reversed (—O) samtec.com?TCMD Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
TCMD-22-D-10.00-01-D03-M 价格&库存
很抱歉,暂时无法提供与“TCMD-22-D-10.00-01-D03-M”相匹配的价格&库存,您可以联系我们找货
  • 1+187.926121+24.40128
