F-218
TMMH–116–04–L–6
TMMH–125–04–F–D–EP
(2.00 mm) .0787"
FLEXIBLE THROUGH-HOLE HEADER
Choice of 2, 3, 4, 5 and
6 rows on (2.00 mm)
.0787" pitch
Board Mates:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS
SPECIFICATIONS
For complete specifications
see www.samtec.com?TMMH
Cable Mates:
TCSD
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (TMMH/ESQT):
4.5 A per pin
(2 pins powered)
Current Rating (TMMH/SQT):
5.1 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
Voltage Rating:
281 VAC mated with SQW;
250 VAC mated with SQT
RoHS Compliant:
Yes
Lead–Free Solderable: Yes
(2.00 mm)
.0787"
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
APPLICATION
Through-hole
ALSO AVAILABLE
(2.00 mm)
.0787"
(MOQ Required)
Retention Clip Option (–RC)
• Other platings
Contact Samtec.
RECOGNITIONS
Specify
LEAD STYLE
from chart
FILE NO. E111594
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
03 thru 50
Other Solutions
06
See PTT Series.
300
No. of
rows
x
(2.00)
.0787
Surface
Mount
01
See previous page.
Low Profile
(2.00)
.0787
See TMM Series.
02
295
No. of positions x (2.00) .0787 + Z
01
See TMM Series.
(2.92)
.115
(4.70)
–EC
.185
–EP & –EPC (6.10)
.240
–EL & –EBC (4.45)
.175
– ES
(2.00) .0787
100
(2.00)
.0787
B
(Shrouded option requires -D)
–01
–04
(6.45) (1.91) (2.57)
.254 .075 .101
–05
(5.94) (1.65) (2.29)
.234 .065 .090
–06
(8.74) (3.20) (3.53)
.344 .126 .139
(2.00)
.0787
C
99
–T
(2.00) .0787
–Q
(2.00) .0787
B
A
See TMMS Series.
C
Paste In Hole (PIH) processing.
Contact Samtec ASP Group for
part customization.
(0.50) .020
SQ
C
(7.67) (3.20) (2.46)
.302 .126 .097
A
–D
Shrouded
Four Row
Vertical &
Right-angle
A
–F
= Gold flash
on post,
Matte Tin on tail
B
(6.35)
.250
Right-angle
Four Row
LEAD
STYLE
Z
OPTION
Press-fit
PLATING
OPTION
LEAD
STYLE
NO. PINS
PER ROW
1
TMMH
For complete scope
of recognitions see
www.samtec.com/quality
(2.00) .0787
–5
–6
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
–T
= Matte Tin
TMMH–125–04–F–D–RA–ES
TMMH–118–04–T–D–EL
TMMH–110–04–L–D
TMMH–109–01–L–D
TMMH–120–01–L–D–RA
Right-angle
option
TMMH SERIES
FLEX SHROUD OPTIONS
–EL OPTION
–EBC OPTION
–ES OPTION
APPLICATIONS
SQT TMMH
Optional
end shrouds
–EP OPTION
–EPC OPTION
HORIZONTAL
ROW
OPTION
–D
FLEX SHROUD OPTIONS
–RA
Flex Shroud requires -D row & 9 pins/row minimum
(For board-to-board interfaces. Will not mate with TCSD)
= Right-angle
(Double & Triple Row only)
(–ES, –EP, –EL Double Row only)
(–EC, –EBC and –EPC not available)
(–06 Lead style not available)
= Double Row
(Required for
Flex Shroud
option)
–T
= Triple Row
B
–ES
= End Shroud with Locking Clip
(Manual placement required)
–EP
–5
(2.00)
.0787
–D– RA
–6
LEAD
STYLE
D
–04
–05
(3.20)
.126
–EL
–T– RA
(Lead style –01 only)
= Six Row
–01
= Retention Clip
(Mates to TCSD)
(Double row only,
minimum position 4
and available only
–06 lead style)
= End Shroud with Guide Post
(2.62)
.103
= Five Row
–01
E
D
–RC
–EC
= Four Row
LEAD
STYLE
–“XXX”
= Polarized Position
(Specify position
of omitted pin)
= End Shroud
(1.27)
.050
–Q
OTHER
OPTIONS
TAIL OPTION
E
–D– RA –ES
(–RA also available with
other flex shroud options)
(2.34) (6.60)
.092 .260 (1.17)
(2.62) (5.26) .046
.103 .207
(3.12) (5.26)
.123 .207
Y
(5.84) (4.45)
.230 .175
–EPC
(4.00)
.157
(1.91)
.075
DIA
Y
(2.03)
.080
(1.83)
.072
X
(1.41) .056
–D– EBC
–RC
= End Shroud with Guide Post and Locking Clip
(2.29)
.090
–D– EL
–EBC
= End Shroud with Board Lock and Locking Clip
(Boards are positively locked and cannot be unmated)
–04 & (4.50) (3.02)
–05 .177 .119
(3.20)
.126
(2.44)
.096
X
–D– ES
(1.83)
.072
(1.41)
.056
–D– EC
(1.83)
.072
(1.41) .056
–D– EPC
WWW.SAMTEC.COM
–D– EP
Y
很抱歉,暂时无法提供与“TMMH-118-01-F-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+18.02769
- 1000+13.67493
- 2000+12.52628
- 5000+9.67281
- 12200+6.74678
- 32800+6.39614
