TST-117-03-F-D
TST-117-03-F-D
    SAMTEC(申泰)
    CONN HEADER VERT 34POS 2.54MM
TST-117-03-F-D 数据手册
ZST–113–03–F–D–0735 F-215 (Rev 22MAR16) HTST–125–01–L–DV (2.54 mm) .100" TST, HTST, ZST SERIES SHROUDED .025" SQ POST IDC HEADERS Mates with: IDSD, SMSD SPECIFICATIONS For complete specifications www.samtec.com?TST, www.samtec.com?HTST or www.samtec.com?ZST Insulator Material: TST, ZST: Black Glass Filled Polyester HTST: Natural LCP Insulation Resistance: 5000 MΩ min Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (IDSD/TST): 3.4 A per pin (1 pin powered per row) Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Flammability Rating: UL 94V-O Withstanding Voltage: 1000 VRMS RoHS Compliant: Yes TST = Cable Strip LEAD STYLE PLATING OPTION 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 Specify LEAD STYLE from chart. = Gold flash on post, Matte Tin on tail (Not available on –DV) (Standard sizes.) HTST –F –L = High Temp Cable Strip (2.92) .115 (4.19) .165 (14.35) .565 –01 –02 –03 = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (2.54) .100 x No. of Positions + (7.62) .300 (2.54) .100 x No. of Positions + (5.08) .200 LEAD T/H STYLE (A) Processing: Lead–Free Solderable: HTST: Yes TST, ZST: Wave Only SMT Lead Coplanarity: (0.10 mm) .004" max (05-15) (0.15 mm) .006" max (17-36) NO. PINS PER ROW 1 TYPE STRIP –T = Matte Tin 02 (2.54) .100 (2.54) .100 01 (0.38) .015 –D OTHER OPTION –D Surface Mount (lead style –01 only) (HTST only) = Double Row Through-hole (lead style –01, –02 & –03 only) –P –DV = Pick & Place Pad = Double Row Surface Mount (lead style –01 only) (HTST only) –TR = Tape & Reel Packaging –D–RA = Double Row Right-angle (lead style –04 & –05 only) B (6.35) .250 (10.16) .400 (8.89) .350 A LEAD RIGHTSTYLE ANGLE (B) –04 (3.30) .130 –05 (5.84) .230 (9.27) .365 ROW OPTION (5.08) .200 (11.18) .440 (0.64) .025 SQ TYP –DV (HTST ONLY) –D–RA RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality 1 ZST NO. PINS PER ROW LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart. = Gold flash on post, Matte Tin on tail BODY HEIGHT D FILE NO. E111594 OTHER SOLUTIONS 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 • Shrouded board-to-board headers and stackers to mate with SSW, SSQ, ESW, ESQ, SSM and BCS Series. See TSS, HTSS and ZSS Series. (Standard sizes.) (2.54) .100 x No. of Positions + (7.62) .300 (2.54) .100 x No. of Positions + (5.08) .200 ALSO AVAILABLE (MOQ Required) • Other platings & sizes • Alignment Pins • Single Row • Locking Leads • Polarized Contact Samtec. 02 –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –T (2.54) .100 = Matte Tin (9.27) .365 (2.54) .100 01 (6.35) .250 (8.89) .350 (2.29) .090 MIN (0.38) .015 Note: Some lengths, styles and options are non-standard, non-returnable. ZST is non-standard, non-returnable. –F (0.64) .025 SQ TYP (2.54) .100 –“XXXX” = Body Height LEAD STYLE –01 –02 –03 –04 –05 –06 –07 –08 –09 C (OAL) MAX BODY HEIGHT (16.00) .630 (13.72) .540 (18.54) .730 (16.26) .640 (21.08) .830 (18.80) .740 (23.62) .930 (21.34) .840 (26.16) 1.030 (23.88) .940 (28.70) 1.130 (26.42) 1.040 (31.24) 1.230 (28.96) 1.140 (33.78) 1.330 (31.50) 1.240 (36.32) 1.430 (34.04) 1.340 BODY HEIGHT C (OAL) Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
TST-117-03-F-D 价格&库存
很抱歉,暂时无法提供与“TST-117-03-F-D”相匹配的价格&库存,您可以联系我们找货
