281-101
    WAGO(万可电子)
    端子块连接器 2 位置 馈通式 灰色 12-28 AWG
281-101 数据手册
Data sheet  |  Item number: 281-101 2-conductor through terminal block; 4 mm²; lateral marker slots; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP® www.wago.com/281-101 Color: Item description 29.03.2019    Page 1/10 Data sheet  |  Item number: 281-101 www.wago.com/281-101 Note: Terminating Aluminum Conductors WAGO spring clamp terminal blocks are suitable for solid aluminum conductors up to 4 mm²/12 AWG if WAGO “Alu-Plus” Contact Paste is used for termination. “Alu-Plus” Contact Paste Advantages: Automatically destroys the oxide film during clamping. Prevents fresh oxidation at the clamping point. Prevents electrolytic corrosion between aluminum and copper conductors (in the same terminal block). Provides long-term protection against corrosion. Using terminal blocks with CAGE CLAMP® Spring Pressure Connection Technology, aluminum conductors must first be cleaned with a blade and then immediately be inserted into the clamping units filled with “Alu-Plus” Contact Paste. It is also possible to apply WAGO “Alu-Plus” additionally on the whole surface of the aluminum conductor before termination. Please note that the nominal currents must be adapted to the reduced conductivity of the aluminum conductors: 2.5 mm² (14 AWG) = 16 A 4 mm² (12 AWG) = 22 A Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 800 V Rated impulse voltage (III / 3) 8 kV Rated current 32 A Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Connectable conductor materials Copper Solid conductor 0.08 … 4 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 4 mm² / 28 … 12 AWG Strip length 9 … 10 mm / 0.35 … 0.39 inch Total number of connection points 2 Total number of potentials 1 Number of levels 1 Type of wiring Side-entry wiring Leiterquerschnitte eindrähtig 0.08 mm² Geometrical Data 29.03.2019    Page 2/10 Data sheet  |  Item number: 281-101 www.wago.com/281-101 Geometrical Data Width 6 mm / 0.236 inch Height from upper-edge of DIN-35 rail 32.5 mm / 1.28 inch Depth 42.5 mm / 1.673 inch Plug width 6 mm / 0.236 inch Mechanical data Design horizontal Type of mounting DIN-35 rail Marking level Side marking Material Data Color gray Insulating material Polyamide 66 (PA 66) Fire load 0.108 MJ Weight 5.887 g Commercial data Product Group 1 (Rail Mounted Terminal Blocks) Country of origin IN GTIN 4044918618168 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CSA DEKRA Certification B.V. C22.2 No. 158 1505034 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 14HG1293677PDA BV Bureau Veritas S.A. EN 60947 07436/E0 BV DNV GL - TAE00001V2 29.03.2019    Page 3/10 Data sheet  |  Item number: 281-101 www.wago.com/281-101 DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register EN 60947 91/20112 (E9) UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 1059 E45172 Compatible products check Item no.: 209-170 Test plug adapter; 8.3 mm wide; for 4 mm Ø test plugs; suitable for 1.5 mm² - 10 mm² tbs www.wago.com/209-170 Item no.: 210-657 Operating tool with partially insulated shaft; Blade (3.5 x 0.5) mm; short www.wago.com/210-657 Item no.: 210-658 Operating tool with partially insulated shaft; Blade (3.5 x 0.5) mm; short; angled www.wago.com/210-658 Item no.: 210-720 Operating tool with partially insulated shaft; Type 2, blade (3.5 x 0.5) mm www.wago.com/210-720 Item no.: 216-106 Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated www.wago.com/216-106 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated www.wago.com/216-201 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated www.wago.com/216-202 tools ferrule Item no.: 216-203 29.03.2019    Page 4/10 Data sheet  |  Item number: 281-101 www.wago.com/281-101 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated www.wago.com/216-203 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated www.wago.com/216-204 Item no.: 216-205 Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated www.wago.com/216-205 Item no.: 216-206 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated www.wago.com/216-206 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-243 Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-244 Item no.: 216-246 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90 www.wago.com/216-246 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated www.wago.com/216-302 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-196 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Carrier rail Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-198 29.03.2019    Page 5/10 Data sheet  |  Item number: 281-101 www.wago.com/281-101 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715 www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715 www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715 www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715 www.wago.com/210-508 Item no.: 281-301 End and intermediate plate; 3 mm thick www.wago.com/281-301 Item no.: 281-302 End and intermediate plate; 3 mm thick www.wago.com/281-302 Item no.: 281-322 Separator plate; 2 mm thick; oversized www.wago.com/281-322 Item no.: 281-332 Separator plate; 2 mm thick; oversized www.wago.com/281-332 Item no.: 281-333 Step-down intermediate plate; 1 mm thick; "only for 4 mm terminal blocks www.wago.com/281-333 Item no.: 281-336 Step-down intermediate plate; 1 mm thick; "only for 4 mm terminal blocks www.wago.com/281-336 End plate Marking accessories Item no.: 2009-115 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-006 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 www.wago.com/2009-115 29.03.2019    Page 6/10 Data sheet  |  Item number: 281-101 www.wago.com/281-101 Item no.: 2009-115/000-023 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for smartPRINTER; on reel; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/2009-115 /000-024 Item no.: 209-140 Group marker carrier www.wago.com/209-140 Item no.: 209-141 Group marker carrier www.wago.com/209-141 Item no.: 209-142 Group marker carrier www.wago.com/209-142 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snapon type www.wago.com/793-5501 Item no.: 793-5501/000-002 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snapon type www.wago.com/793-5501 /000-002 Item no.: 793-5501/000-005 www.wago.com/793-5501 29.03.2019    Page 7/10 Data sheet  |  Item number: 281-101 www.wago.com/281-101 Item no.: 793-5501/000-005 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-005 Item no.: 793-5501/000-006 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-006 Item no.: 793-5501/000-007 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-007 Item no.: 793-5501/000-012 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-012 Item no.: 793-5501/000-017 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-017 Item no.: 793-5501/000-023 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-023 Item no.: 793-5501/000-024 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type www.wago.com/793-5501 /000-024 Item no.: 210-103 Wire commoning chain; insulated; 50 connections www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; 50 connections www.wago.com/210-123 Item no.: 249-123 Push-in type wire jumper; insulated; wire length 180 mm; Conductor cross section 0.75 mm² www.wago.com/249-123 Item no.: 249-125 Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross section 0.75 mm² www.wago.com/249-125 Item no.: 249-126 Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 0.75 mm² www.wago.com/249-126 Item no.: 249-127 Push-in type wire jumper; insulated; wire length 250 mm; Conductor cross section 0.75 mm² www.wago.com/249-127 Item no.: 281-402 Adjacent jumper; insulated; IN = IN terminal block www.wago.com/281-402 Item no.: 281-409 Alternate jumper; insulated; IN = IN terminal block www.wago.com/281-409 Item no.: 281-422 Adjacent jumper; insulated; IN = IN terminal block www.wago.com/281-422 Item no.: 283-414 Step-down jumper; insulated; from 16 mm² to 4 mm²; Nominal current 32 A www.wago.com/283-414 Item no.: 284-413 www.wago.com/284-413 Jumper 29.03.2019    Page 8/10 Data sheet  |  Item number: 281-101 www.wago.com/281-101 Item no.: 284-413 Step-down jumper; insulated; from 10/6 mm² to 6/4 mm²; Nominal current 30 A www.wago.com/284-413 Item no.: 284-414 Step-down jumper; insulated; from 10/6 mm² to 4/2.5/1.5 mm²; Nominal current 15 A www.wago.com/284-414 Item no.: 709-110 Wire commoning chain; insulated; 4 connections; 3 x 110 mm www.wago.com/709-110 Item no.: 709-111 Wire commoning chain; insulated; 3 connections; 2 x 120 mm www.wago.com/709-111 Item no.: 709-112 Wire commoning chain; insulated; 3 connections; 2 x 170 mm www.wago.com/709-112 Item no.: 781-452 Staggered jumper; insulated; from 1 to 2; Spacing: 6 mm www.wago.com/781-452 Item no.: 781-453 Staggered jumper; insulated; from 1 to 3; Spacing: 6 mm www.wago.com/781-453 Item no.: 781-454 Staggered jumper; insulated; from 1 to 4; Spacing: 6 mm www.wago.com/781-454 Item no.: 781-455 Staggered jumper; insulated; from 1 to 5; Spacing: 6 mm www.wago.com/781-455 Item no.: 781-456 Staggered jumper; insulated; from 1 to 6; Spacing: 6 mm www.wago.com/781-456 General accessories Item no.: 249-105 Group marker carrier www.wago.com/249-105 Item no.: 280-404 Test plug adapter; 5 mm wide; for test plug 210-137 (2.3 mm Ø); suitable for 1.5 mm² - 4 mm² tbs www.wago.com/280-404 Item no.: 281-407 Test plug; 6 mm wide; Nominal current 24 A; for 0.08 mm² - 2.5 mm² www.wago.com/281-407 Protective Warning Marker Item no.: 281-405 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks www.wago.com/281-405 Item no.: 209-106 Mounting carrier; for isolated mounting on DIN 35 rails www.wago.com/209-106 Item no.: 709-153 Cover; Type 1; suitable for cover carrier, type 1; 1 m long www.wago.com/709-153 assembling Downloads CAD files CAD data 3D Download 281-101 URL Download 29.03.2019    Page 9/10 Data sheet  |  Item number: 281-101 www.wago.com/281-101   Subject to changes. WAGO Corporation Germantown, WI 53022 Phone: 1-800-DIN-RAIL (346-7245) | Fax: (262) 255-6222 Email: info.us@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at {0}. 29.03.2019    Page 10/10
281-101 价格&库存
很抱歉,暂时无法提供与“281-101”相匹配的价格&库存,您可以联系我们找货
    • 1+7.30455
    • 100+6.57415
    库存:57
    281-101
      • 1+3.37102
      库存:1
