750-624/000-001
750-624/000-001
    WAGO(万可电子)
750-624/000-001 数据手册
Data sheet  |  Item number: 750-624/000-001 Filter module for field-side power supply (surge); 24 VDC; Without power jumper contacts; light gray www.wago.com/750-624/000-001 Color: 17.10.2019    Page 1/9 Data sheet  |  Item number: 750-624/000-001 www.wago.com/750-624/000-001 Item description Required for applications with more stringent surge requirements, such as for shipbuilding and onshore/offshore automation and under the standards of leading agencies such as Germanischer Lloyd. Required for shipbuilding certified operation with 750 Series I/O modules. Including overvoltage protection Without link-end power jumper contacts (may also be used as a supply module) Data Technical Data Type of signal Voltage Type of signal voltage DC 24 V System supply voltage DC 5 V; via data contacts Field supply voltage DC 24 V (-25 … +30 %); via wiring level (CAGE CLAMP® connection) Number of outgoing power jumper contacts 3 Current carrying capacity of the power jumper contacts 10 A 17.10.2019    Page 2/9 Data sheet  |  Item number: 750-624/000-001 www.wago.com/750-624/000-001 Connection data Connection technology: field supply 6 x CAGE CLAMP® Connection type (1) Field supply Solid conductor 0.08 … 2.5 mm² / 28 … 14 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 14 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Geometrical Data Width 12 mm / 0.472 inch Height 69.8 mm / 2.748 inch Height from upper-edge of DIN-35 rail 62.6 mm / 2.465 inch Depth 100 mm / 3.937 inch Mechanical data Type of mounting DIN-35 rail Material Data Color light gray Housing material Polycarbonate, polyamide 6.6 Weight 47 Conformity marking CE Environmental Requirements Surrounding air (operating) temperature 0 … 55 °C Surrounding air (storage) temperature -40 … 85 °C Protection class IP20 Degree of pollution (5) 2 per IEC 61131-2 Operating altitude 0 … 2000 m Mounting position horizontal (standing/lying) or vertical Relative air humidity (no condensation) 95 % Vibration resistance 4g per IEC 60068-2-6 Shock resistance 15g per IEC 60068-2-27 EMC immunity to interference acc. to EN 61000-6-2, marine applications EMC emission of interference acc. to EN 61000-6-3, marine applications Exposure to pollutants Per IEC 60068-2-42 and IEC 60068-2-43 Permissible H2S contaminant concentration at a relative humidity 75 10 ppm % Permissible SO2 contaminant concentration at a relative humidity 75 25 ppm % 17.10.2019    Page 3/9 Data sheet  |  Item number: 750-624/000-001 www.wago.com/750-624/000-001 % Commercial data Product Group 15 (Remote I/O) Packaging type BOX Country of origin DE GTIN 4050821328735 Customs Tariff No. 85389091890 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text UL Underwriters Laboratories Inc. (HAZARDOUS LOCATIONS) ANSI/ISA 12.12.01 Certificate name E198726 Sec.1 Country specific Approvals Logo Certificate name Approval Additional Approval Text KC National Radio Research Agency Article 58-2, Clause 3 Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1821926 DNV GL Det Norske Veritas, Germanischer Lloyd - TAA0000194 LR Lloyds Register - 02/20026 (E6) PRS Polski Rejestr Statków - TE/2236 /880590/19 MSIPREM-W43FTM750 Ship Approvals Logo Certificate name 17.10.2019    Page 4/9 Data sheet  |  Item number: 750-624/000-001 www.wago.com/750-624/000-001 Compatible products Carrier rail Item no.: 210-112 www.wago.com/210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 www.wago.com/210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715 www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715 www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715 www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715 www.wago.com/210-508 Supply module Item no.: 750-601 Power Supply; 24 VDC; fuse holder; light gray www.wago.com/750-601 Item no.: 750-602 Power Supply; 24 VDC; light gray www.wago.com/750-602 Item no.: 750-610 Power Supply; 24 VDC; fuse holder; Diagnostics www.wago.com/750-610 Item no.: 750-612 www.wago.com/750-612 17.10.2019    Page 5/9 Data sheet  |  Item number: 750-624/000-001 www.wago.com/750-624/000-001 Item no.: 750-612 Power Supply; 0 … 230 V AC/DC; light gray www.wago.com/750-612 Marking accessories Item no.: 2009-145 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-145 Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-006 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-145 /000-006 Item no.: 2009-145/000-007 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-145 /000-007 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 248-501 Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card www.wago.com/248-501 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501/000-017 www.wago.com/248-501 17.10.2019    Page 6/9 Data sheet  |  Item number: 750-624/000-001 www.wago.com/750-624/000-001 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 750-100 Marker card; as a DIN A4 sheet; plain; white www.wago.com/750-100 Item no.: 750-103 Group marker carrier www.wago.com/750-103 Item no.: 750-106 Group marker carrier www.wago.com/750-106 shield connection Item no.: 790-108 Shield clamping saddle; 11 mm wide; diameter of compatible conductor www.wago.com/790-108 Item no.: 790-116 Shield clamping saddle; 19 mm wide; diameter of compatible conductor; 7 ... 16 mm www.wago.com/790-116 Item no.: 790-124 Shield clamping saddle; 27 mm wide; diameter of compatible conductor; 6 ... 24 mm www.wago.com/790-124 Item no.: 790-140 Shield clamping saddle; diameter of compatible conductor www.wago.com/790-140 Item no.: 790-208 Shield clamping saddle; 12.4 mm wide; 3 ... 8 mm www.wago.com/790-208 Item no.: 790-216 Shield clamping saddle; 21.8 mm wide; 6 ... 16 mm www.wago.com/790-216 Item no.: 790-220 Shield clamping saddle; 30 mm wide; 6 ... 20 mm www.wago.com/790-220 Item no.: 850-804 IP65 enclosure; Stainless steel; WxHxD (400x123x200 mm); 4 x M20, 16 x M16, 28 x M12 cable grip www.wago.com/850-804 Item no.: 850-804/000-001 IP65 enclosure; Stainless steel; WxHxD (400x123x200 mm); 2 x M20, 13 x M16, 32 x M12 cable grip www.wago.com/850-804 /000-001 Item no.: 850-805 IP65 enclosure; Stainless steel; WxHxD (600x123x200 mm); 4 x M20, 19 x M16, 67 x M12 cable grip www.wago.com/850-805 Item no.: 850-814/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (200x120x200 mm); without flange plate www.wago.com/850-814 /002-000 system box Item no.: 850-815/002-000 17.10.2019    Page 7/9 Data sheet  |  Item number: 750-624/000-001 www.wago.com/750-624/000-001 Item no.: 850-815/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (300x120x200 mm); without flange plate www.wago.com/850-815 /002-000 Item no.: 850-816/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (400x120x200 mm); without flange plate www.wago.com/850-816 /002-000 Item no.: 850-817/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (600x120x200 mm); without flange plate www.wago.com/850-817 /002-000 Item no.: 850-825 IP65 enclosure; Aluminium (RAL 7032); WxHxD (160x100x160 mm); 9 x M12, 4 x M20 www.wago.com/850-825 Item no.: 850-826 IP65 enclosure; Aluminium (RAL 7032); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-826 Item no.: 850-826/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-826 /002-000 Item no.: 850-827 IP65 enclosure; Aluminium (RAL 7032); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-827 Item no.: 850-827/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-827 /002-000 Item no.: 850-828 IP65 enclosure; Aluminium (RAL 7032); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable grip www.wago.com/850-828 Item no.: 850-828/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable grip www.wago.com/850-828 /002-000 Item no.: 850-834 IP65 enclosure; Polyester (RAL 7032); WxHxD (164x100x164 mm); 9 x M12, 4 x M20 www.wago.com/850-834 Item no.: 850-835 IP65 enclosure; Polyester (RAL 7032); WxHxD (244x100x164 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-835 Item no.: 850-836 IP65 enclosure; Polyester (RAL 7032); WxHxD (324x100x164 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-836 Downloads Documentation Additional Information Disposal; Electrical and electronic equipment, Packaging V 1.0.0 pdf 265.8 kB Download pdf Download System Description 17.10.2019    Page 8/9 Data sheet  |  Item number: 750-624/000-001 www.wago.com/750-624/000-001 750/753 Series I/O-System ‒ General Product Information Overview on WAGO-I/O-SYSTEM 750 approvals pdf 1.7 MB Download pdf 780.2 kB Download URL Download CAD/CAE-Data CAD data 3D Download 750-624/000-001 EPLAN EPLAN Data Portal 750-624/000-001 Download WSCAD WSCAD Universe 750-624/000-001 Download Device Files Device Driver WAGO USB Service Kabel Treiber / Serie 750 und 857 6.5.3.0 10-Sep-2014 zip 4.8 MB Download Handling Instructions Product family 750/753 Series ‒ I/O System Show all products from the family   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 17.10.2019    Page 9/9
750-624/000-001 价格&库存
很抱歉,暂时无法提供与“750-624/000-001”相匹配的价格&库存,您可以联系我们找货
