Printview: PCB connector strip; for solder pin strip; 8-pole; pin spacing 5 mm / 0.197 in - Item No.: 806-108
/ 0.197 in
Item No.: 806-108
Marking
Business data
Supplier
WAGO
Item no.
806-108
GTIN / EAN
4045454076962
Content
1
Order amount
100
Customer item number
Notes
Compact, 2-conductor PCB connector strips with screwdriver-actuated Push-in CAGE CLAMP®Simple, push-in
terminations of solid and ferruled conductorsDouble-conductor connection for feed-in and potential distributionQuick
and easy PCB replacement, without disrupting looped-through potentials
Technical data
Miscellaneous
No. of poles
8
Pin Spacing
5 mm / 0.197 in %
Total number of connection points
16
Total number of potentials
8
Color
gray
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
Pollution degree (1)
2
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Rated voltage EN (1) [V]
320 [V]
Rated surge voltage (1) [kV]
4 [kV]
Nominal current [A]
10 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
630 [V]
Rated surge voltage (2) [kV]
4 [kV]
Nominal current (2) [A]
10 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
250 [V]
Rated surge voltage (3) [kV]
4 [kV]
Nominal current (3) [A]
10 [A]
Number of individual connection objects at the product
1
Connection technology (1)
Push-in CAGE CLAMP®
Solid sizes 1
0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded wires 1
Fine-stranded wires with insulated ferrule 1
0.25 … 1 mm² / …
Fine-stranded wires with uninsulated ferrule 1
0.25 … 1 mm² / …
Strip length 1
9 … 10 mm / 0.35 … 0.39 in
Conductor entry angle to the PCB 1 [°]
45 [°]
Solder pin diameter [mm]
1 [mm]
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 105 C
Clamping spring material
Chrome-nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Fire load [MJ]
0.2 [MJ]
Weight [g]
10.114 [g]
Width
41.5 mm / 1.634 in
Height
16.25 mm / 0.64 in
Length
19.8 mm / 0.78 in
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“806-108”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+108.692771+14.05693
