ESD-118-G-25
ESD-118-G-25
    SAMTEC(申泰)
    ELEVATED SOCKET STRIPS
ESD-118-G-25 数据手册
F-218 SS–132–G–2 ESD–115–TT–05 (2.54 mm) .100" SS, SD, ESD, ESS, HSS SERIES PRECISION MACHINED SOCKET STRIPS Mates with: TS, TD, HTS, BBS, BBD, BBL, BDL, BHS TYPE STRIP NO. PINS PER ROW 1 PLATING OPTION LEAD STYLE OTHER OPTION OPTION SPECIFICATIONS For complete specifications see www.samtec.com?SS, www.samtec.com?ESS, www.samtec.com?SD, www.samtec.com?ESD or www.samtec.com?HSS Insulator Material: SS, SD, ESS, ESD= Black G.F. Polyester HSS= Black Liquid Crystal Polymer Contact: BeCu Shell: Brass except Style 5A Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C Lead Size Range: (0.38 mm to 0.56 mm) .015" to .022" DIA and most IC leads RoHS Compliant: Yes Lead-Free Solderable: Wave only RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –S 01 thru 32 = SS, ESS Series 01 thru 36 = 30 µ" (0.76 µm) Gold contact, Tin shell SS = Standard = High Temp Single Row Socket Single Row Socket = 30 µ" (0.76 µm) Gold contact, 10 µ" (0.25 µm) Gold shell (MOQ Required) • Locking lead option on ESS and ESD series Contact Samtec. Styles – 5A & –05 socket heads not countersunk. (2.54) .100 x No. of Positions –1A, –1B or –1C (2.54) .100 (4.90) .193 (1.32) .052 DIA (2.54) .100 x No. of Positions (2.54) .100 ESD (2.54) (2.54) .100 x No. of Positions .100 TYP = (2.54) Standard Double (5.08) .100 .200 Row Socket (2.54) .100 (0.76) .030 Y = Elevated Double (2.54) Row Socket .100 LEAD STYLE Y –1A or –21A (9.14) .360 (12.95) .510 (6.60) .260 –1B or –21B (0.64) .025 SQ Style –(2.54) 5A not available. TYP& –05 socket Styles.100 –5A heads not countersunk. –1C or –21C (0.76) .030 B A C (0.64) .025 SQ –2, –22*,–5A, or –38* *For LIF specify –22 or –38 (SS, HSS, SD) (2.54) .100 x No. of Positions (2.54) .100 (5.08) .200 For LIF specify –23 (ESS, ESD) (1.83) .072 DIA (2.54) .100 SD –03, –04, –05 For LIF specify –21A, –21B or –21C (SS, HSS, SD) (2.54) .100 TYP N/A Style –5A ALSO AVAILABLE = Tin contact and shell (Styles 1, 2, 4, and 05 except LIF N/A) = Elevated Single Row Socket (0.76) .030 REF Requires -T Plating Option –TT ESS = Non Flush (7.62) .300 (3.43) .135 –G HSS –N Locking Socket Add –L suffix for locking lead socket in end positions. Requires Style -2 or -22 and .035" ± .003 DIA board hole. –T = HSS, SD & ESD Series FILE NO. E111594 (1.83) .072 DIA (2.54) .100 TYP (0.76) .030 (2.54) .100 (1.32) .052 DIA Note: Some lengths, styles and options are non-standard, non-returnable. –L = 10 µ" (0.25 µm) Gold contact, Tin shell (Styles 2 & 22 only) = X LIF= Low Insertion Force LEAD STYLE –2 or –22 Z –38 –5A Y X DIA Y Z (0.51) (3.18) (7.62) .020 .125 .300 (0.51) (4.57) (8.89) .020 .180 .350 (0.89) (12.95) (17.86) .035 .510 .703 LEAD STYLE B C –05 –03 or –23 (11.51) (8.38) (3.12) .453 .330 .123 –04 (14.05) (10.92) (3.12) .553 .430 .123 Locking lead available. See OPTION. Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM A (17.86) (13.46) (4.39) .703 .530 .173 All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ESD-118-G-25 价格&库存
很抱歉,暂时无法提供与“ESD-118-G-25”相匹配的价格&库存,您可以联系我们找货
