SURFACE MOUNT
MICRO HEADER
8
G b p s
(1.27 mm) .050" PITCH • FTSH SERIES
FTSH
Board Mates:
CLP, FLE
Cable Mates:
FFSD, FFTP
FTSH
-1
NO. PINS
PER ROW
02
thru
50
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (FTSH/CLP):
3.4 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
LEAD
STYLE
–01
PLATING
OPTION
–F
= (3.05 mm)
.120" Post
(Mates with
FFSD)
= Gold flash
on post,
Matte Tin
on tail
–02
–L
= (1.91 mm)
.075" Post
(Mates with
FLE)
–03
= (1.65 mm)
.065" Post
(Mates with
CLP–D)
TAIL
OPTION
–DV
Leave Blank
for -DH &
-MT
–DH
–“XXX”
= Double
Vertical
= Polarized
Position
(Specify
position
of
omitted
pin)
(Not
available
with -EX
options)
= Double
Horizontal
(Styles
–01, –02 &
–04 only)
= 10 µ"
(0.25 µm)
Gold
on post,
Matte Tin
on tail
OPTION
–MT
= Mixed
Technology
(Styles
–01, –02 &
–04 only)
–04
PROCESSING
OPTION
1RRISRVLWLRQV[=
Z
–ES
(2.57) .101
–EJ
(15.77) .621
–EC
(3.33) .131
–EP
(5.87) .231
–EL
(6.53) .257
1RRISRVLWLRQV[=
–EJ
= Ejector Shroud
(Style –01 only)
–DH & –MT
not available
10 pins/row
minimum
25 pins/row
maximum
EXTENDED LIFE
PRODUCT
1RRISRVLWLRQV[
HIGH MATING
CYCLES
LEAD
STYLE
A
–01
(3.05)
.120
–02
(1.91)
.075
–03
(1.65)
.065
–04
(3.81)
.150
–05
(4.32)
.170
—EJ OPTION SHOWN
10 YEAR MFG
WITH 30 µ" GOLD
–EC
= End Shroud
with Locking Clip
(Manual
placement
required)
= End Shroud with
Board Lock
(Boards are
positively locked
and cannot be
unmated)
—EX OPTION SHOWN
Molded Pick & Place pads
Latches
Other platings
–ES
= End Shroud
–EL
= (4.32 mm)
.170" Post
(Mates with
CLP–BE)
MOQ Required
(Style –02 & –03
only, –DH & –MT
not available)
9 pins/row
minimum
(Other positions
available. Call
Samtec.)
= End Shroud
with Guide Post
–05
ALSO AVAILABLE
–EP
= (3.81 mm)
.150" Post
(Mates with
CLP-DH)
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
–MT & –DV Tail Option:
(0.10 mm) .004" max (02-25)
–MT & –DH Tail Option:
(0.15 mm) .006" max (26-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
FLEX SHROUD
OPTIONS
—MT
(Styles –01, —02 & —04 only)
64
—DV
Notes:
Severe Environment
Testing qualified; aligns
with MIL-DTL-55302.
Visit samtec.com/set
OTHER
OPTIONS
–K
= Keying
Shroud for
mating
with FFSD
(Style –01 only,
05 thru 25
pins/row only.
13, 17, 20 &
25 only with
–EJ option)
(-DV only)
–A
= Alignment
Pin
(–DV 3 positions
minimum)
(–DH 5 positions
minimum)
(Metal or
plastic at
Samtec
discretion)
–C
= (5.00 mm)
.197" DIA
Polyimide film
Pick & Place Pad
(–DH only)
–P
= Pick &
Place Pad
(–DV 4 positions
minimum)
(–DH & –MT
not available)
–TR
= Tape & Reel
(Flex Shroud
options
not available
except –ES
& –EJ)
–FR
= Full Reel
Tape & Reel
(must order
maximum
quantity
per reel;
contact
Samtec for
quantity breaks)
—DH
(Styles —01, —02, —04 only)
Some sizes, styles and
options are non-standard,
non-returnable.
See SFM/TFM for positive
alignment feature.
F-224
—ES
—EC
—EP
—EL
—EJ
—K
—P
samtec.com?FTSH
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
—A
很抱歉,暂时无法提供与“FTSH-120-01-F-D-EJ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 13+43.2590913+5.59928
