IP5-04-01-L-S-RA1-TR 数据手册
F-221 WEB
IP5–04–01–L–S–RA1–TR
IP5–08–05.0–L–S–1–TR
IP5–04–05.0–L–S–1–TR
(4.00 mm) .1575"
IP5, IP5-RA SERIES
50 W HIGH ISOLATION RF PLUGS
SPECIFICATIONS
IP5
For complete specifications and
recommended PCB layouts see
www.samtec.com?IP5
Shell Material:
Copper Alloy
Insulator Material:
Black LCP
Contact Material:
Copper Alloy
Dielectric Material:
Black LCP
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (Vertical):
Signals: 2.36 A per pin
(2 adjacent pins powered)
Grounds: 4.4 A per pin
Operating Temp Range:
-55 °C to +125 °C
Dielectric Withstanding
Voltage:
IP5 = 600 VAC
IP5-RA = 190 VAC
Working Voltage:
IP5 = 200 VAC
IP5-RA = 190 VAC
RoHS Compliant:
Yes
Mates with:
IJ5, IJ5C
NO. OF
PLUGS
A
–01
(8.33)
.328
(12.32)
.485
(20.32)
.800
(28.32)
1.115
(36.32)
1.430
–02
–04
–06
–08
PLUGS
PER ROW
05.0
–01,
–02, –04,
–06, –08
PLATING
ROW
OPTION
–L
= Single Row
TAIL
XR
–L
–TR
–1
–S
= 10 µ" (0.25 µm)
Gold on contact area,
Matte Tin on tail
OPTION
= (1.60 mm)
.062"
board
thickness
–D
= Double Row
(Not available
with –01)
–FR
= Full
Reel
Tape
& Reel
(must
order
max.
quantity
per reel;
Contact
Samtec
for
quantity
breaks)
A
(8.53)
.336
= Tape
& Reel
= Cable
Latch
(Single
Row only)
(12.52)
.493
(4.00) .1575
(1.52) .060
(9.09)
.358
(1.52) .060
PROCESSING
–S
(4.00).1575
–D
Lead–Free Solderable:
Yes
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
IP5
Mates with:
IJ5, IJ5C
FILE NO. E111594
PLUGS
PER ROW
01
–02, –04,
–06, –08
A
B
(23.64) .931 (21.27) .838 (20.32) .800
(31.64) 1.246 (29.27) 1.153 (28.32) 1.115
(39.64) 1.561 (37.27) 1.468 (36.32) 1.430
(8.92)
.351
(1.52)
.060
IP5
B
–RA1 SHOWN
C
(15.64) .616 (13.27) .523 (12.32) .485
(14.72) .580
(12.52) .493
C
(4.00) .1575
10 mm
= (1.60 mm)
.062"
board
thickness
= 10 µ" (0.25 µm)
Matte Tin on grounds,
tails & weld tabs
NO. OF PLUGS
–02
–04
–06
–08
IJ5
–RA1
–L
A
APPLICATION
TAIL
OPTION
S
PLATING
(8.34)
.328
(9.72) .383
XR
OPTION
–TR
(Leave blank
for no Cable
Latch)
= Tape
& Reel
–L
= Cable Latch
–FR
= Full
Reel
Tape
& Reel
(must
order
max.
quantity
per reel;
Contact
Samtec
for
quantity
breaks)
(0.64) .025
(4.76) .188
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
IP5-04-01-L-S-RA1-TR 价格&库存
很抱歉,暂时无法提供与“IP5-04-01-L-S-RA1-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 150+153.31243150+19.84470
- 国内价格
- 1+226.67040
- 150+90.45000
- 450+87.42600
- 1050+85.92480
