REVISION Q
LBS-1XX-X-X-S
POSITION SPECIFICATION
-01 THRU -36
"A" = No. of POS. x .100
DO NOT
SCALE FROM
THIS PRINT
ROW SPECIFICATION
USE LBS-36-S
PLATING SPECIFICATION
-T: MATTE TIN CONTACT AND TAIL
-F: 3µ" FLASH GOLD IN CONTACT AREA, MATTE TIN ON TAIL
-H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" ON TAIL
LEAD STYLE SPECIFICATION
(SEE TABLE 1)
C
"A" .010[.25]
.096 2.44 REF
2 MAX SWAY
(TYP)
.100 2.54
COINED TO
.020 [.51] REF
(TYP BOTH ENDS)
.125±.018 3.18±0.46
C
"B" .008[.20]
"C"
.100 2.54 REF
(TYP)
C
NOTES:
1. MIN. PUSHOUT FORCE: 2 lbs.
2. MAX. ALLOWABLE BOW AFTER ASSEMBLY: .003 [.08] in./in.
3. MAX. VARIATION BETWEEN ANY TWO PINS TO BE .010 [.25] MAX.
4. C REPRESENTS A CRITICAL DIMENSION.
5. MAX CUT FLASH: .005 [.13]
2 MAX SWAY (TYP)
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: ZYTEL HTNFR52G30BL
CONTACT OR TERMINAL:
MAX FLASH ALLOWED: .002
MAX GATE VESTIGE: .002
F:\DWG\SW\Exisprod\Assembly\100\LBS-1XX-X-X-S.SLDDRW
SHEET SCALE: 3:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
DWG. NO.
LBS ASSEMBLY
LBS-1XX-X-X-S
BY: T.WERNE
08/27/02
SHEET 1 OF 1
很抱歉,暂时无法提供与“LBS-114-C-G-S”相匹配的价格&库存,您可以联系我们找货
