MEC1-108-02-F-D-NP-A
    SAMTEC(申泰)
    SMD,P=1mm
    1MM P数:16P
MEC1-108-02-F-D-NP-A 数据手册
MICRO EDGE CARD SYSTEMS 0.50 mm, 0.635 mm, 0.80 mm, 1.00 mm, 1.27 mm, 2.00 mm PITCH FEATURES & BENEFITS • Up to 56 Gbps PAM4 • PCI Express® 4.0 (MEC5 Series) • Solutions for (1.60 mm) .062" and (2.36 mm) .093" thick cards • Choice of pitch: 0.50 mm, 0.635 mm, 0.80 mm, 1.00 mm, 1.27 mm, 2.00 mm Staggered press-fit tails (MEC8-VP) • Vertical, right-angle and edge mount orientations • Available in surface mount and through-hole Justification beam ensures card and body are flush (MEC5) KEY SPECIFICATIONS SERIES PITCH TOTAL POSITIONS INSULATOR MATERIAL CONTACT MATERIAL OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING LEAD-FREE SOLDERABLE MEC5 0.50 mm 60-200 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 1.5 A (2 pins) 125 VAC Yes MEC6 0.635 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 2.4 A (2 pins) 185 VAC Yes MEC8 0.80 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 2.3 A (2 pins) 180 VAC Yes F-224 MEC1 1.00 mm 20-140 Black LCP Phosphor Bronze -55 ℃ to +125 ℃ 2.2 A (2 pins) 250 VAC Yes MECF 1.27 mm 10-100 Black/Natural LCP BeCu -55 ℃ to +125 ℃ 3.5 A (2 pins) 280 VAC Yes MEC2 2.00 mm 10-100 Black/Natural LCP BeCu -55 ℃ to +125 ℃ 3.5 A (2 pins) 235 VAC Yes samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 14 G b p s (1.00 mm) .0394" PITCH • MINI EDGE CARD SOCKET MEC1 - 1 POSITIONS PER ROW - 02 - 05, 08, 10, 20, 30, 40, 50, 60, 70 PLATING OPTION - D - - NP –F Leave blank for polarization –L =No Polarization (05, 08, 20 & 30 positions only) = Gold flash on contact, Matte Tin on tail MEC1 Card Mates: (1.60 mm) .062" thick card (No. of Positions + 2) x (1.00) .03937 + (2.54) .100 –A = Alignment Pin metal or plastic at Samtec discretion –NP = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail OTHER OPTIONS –K = (7.87 mm) .310" DIA Polyimide film Pick & Place Pad POSITIONS PER ROW POLARIZED POSITIONS (No Contact) 05 3, 4 08 5, 6 10 13, 14, 20 15, 16, 30 21, 22 40 31, 32 50 41, 42 60 31, 32, 63 & 64 70 53, 54, 115 & 116 - “X”R Leave blank for Tube Packaging –TR =Tape & Reel (05-60 only) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (05-60 only) (6.99) .275 (No. of Positions + 2) x (1.00) .03937 (9.04) .356 (1.40) .055 (8.51) .335 Note: Some sizes, styles and options are non-standard, non-returnable. –A OPTION View complete specifications at: samtec.com?MEC1 samtec.com/EdgeCard Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
MEC1-108-02-F-D-NP-A 价格&库存
很抱歉,暂时无法提供与“MEC1-108-02-F-D-NP-A”相匹配的价格&库存,您可以联系我们找货
  • 1+35.175061+4.55936
  • 25+31.0802625+4.02860
  • 50+27.5192650+3.56702
  • 100+24.59291100+3.18771
  • 500+22.69772500+2.94206
库存:21
