MMT-107-02-S-SH-LC
MMT-107-02-S-SH-LC
    SAMTEC(申泰)
    MMT-107-02-S-SH-LC
MMT-107-02-S-SH-LC 数据手册
REVISION DH MMT-1XX-XX-XX-XX-XX-XXX-X-XX NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 2 LB. 3. FOR NON -LC & -A, USE 2TS-XX-D. No OF POSITIONS 4. COPLANARITY TO INCLUDE INSULATOR. 5. MAX BURR ALLOWANCE: .002[0.05]. -02 THRU -50 (PER ROW) 6. MAXIMUM CUT FLASH: .015[0.38]. (NO FLASH TO BE ON BOTTOM OF BODY). 7. -MT OPTION: PIN B TO BE FLUSH TO +/- .003" A LINE MADE BY THE BODY LEAD STYLE -DH OPTION: PIN A TO BE FLUSH TO .003" ABOVE A LINE MADE BY THE BODY -01: .126 [3.20] POST PIN B TO BE FLUSH TO .001" BELOW/.003" ABOVE A LINE MADE BY THE BODY -SH OPTION: PIN A TO BE FLUSH TO +/- .003" A LINE MADE BY THE BODY. -02: .175 [4.45] POST (SEE TABLE 2) C 8. ORIENTATE PINS TO REDUCE THE NUMBER OF BANDOLIER MARKS IN THE POST AREA. (SEE TABLE 4) 9. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED. THE -LC PLATING SPECIFICATION OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" ON TAIL RECOMMENDS MANUAL PLACEMENTFOR ALL ASSEMBLIES WITH -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, THE -LC OPTION. MATTE IN ON TAIL 10. NOTE DELETED. OPTION -P: PICK & PLACE PAD (USE PPP-13) (2 POSITION MINIMUM) OPTION -XXX: POLARIZED POSITION -XXX SPECIFIES POSITION OMITTED (SEE POLARIZATION VIEW) OPTION (SEE NOTE 3) -LC: LOCKING CLIP (SEE NOTE 9) (FOR -DH USE 2TS-XX-DH-LC-XX) (FOR -SH USE 2TS-XX-SH) (NOT AVAILABLE WITH -A) -A: ALIGNMENT PIN (FOR -DH USE 2TS-XX-DH-A-XX) (FOR -SH USE 2TS-XX-SH-A-XX) (NOT AVAILABLE WITH -LC) -K: POLYIMIDE FILM PAD (SEE FIG 14, SHT 6) (3 POS. MIN) (USE K-DOT-.177-.281-.005) -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -T: MATTE TIN CONTACT AND TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -TM: MATTE TIN CONTACT AND TAIL (NO. OF POS x 02 2 MAX SWAY (EITHER DIRECTION) .15748 4.0000 REF 2TS-XX-DH-XX-XX 01 .0787 2.000 .055 1.40 SEE NOTE 6 LC-06-TM .0197 0.500 SQ (TYP) REF "C" (SEE TABLE 2) .11 2.8 .245±.010 6.22±0.254 SEE NOTE 5 0 C 3° .003 0.08 MAX (SEE NOTE 7) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS SEE NOTE 5 ROW OPTION -SH: SINGLE (2TS-XX-SH-X-XX) -DH: DOUBLE (2TS-XX-DH-XX-XX) -MT: MIXED TECHNOLOGY (2TS-XX-DH-XX-XX) (NOT AVAILABLE WITH -LC, OR -A OPTIONS) [0.13] .07874[2.0000]) +.005 - .010 [0.25] (NO OF POS - 1) x .07874[2.0000]) .003[0.08] OPTION -TR: TAPE AND REEL (37 POSTION MAX) (SEE SHT 5) (NO. OF POS x .07874[2.0000] - .15748[4.0000]) .003[0.08] FIG 1 MMT-108-01-X-DH-LC SHOWN ANGLES .XX: .01 [.3] 5 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: C SEE TABLE 5 (SEE NOTE 4) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 INSULATOR: LCP VECTRA; UL 94 V0; COLOR: BLACK TERMINAL: PHOS BRONZE F:\DWG\MISC\MKTG\MMT-1XX-XX-XX-XX-XX-XXX-X-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SMATEC.com code 55322 DESCRIPTION: 2mm HORIZONTAL TERMINAL SURFACE MOUNT STRIP ASSEM DWG. NO. MMT-1XX-XX-XX-XX-XX-XXX-X-XX BY: DEAN P 12/12/2000 SHEET 1 OF 6 REVISION DH .07874 2.0000 REF 2TS-XX-SH-X 01 SEE NOTE 6 .043 1.09 REF 2 MAX SWAY (EITHER DIRECTION) "C" (SEE TABLE 2, SHT 1) .060 1.52 REF .07874 2.000 REF .11 2.8 .050 1.27 REF (NO. OF POS x .07874[2.0000] - .15748[4.0000]) .003[0.08] 5° C 0 C .006[0.15] (SEE NOTE 4) F:\DWG\MISC\MKTG\MMT-1XX-XX-XX-XX-XX-XXX-X-XX-MKT.SLDDRW * FIG 2 MMT-108-01-X-SH-A SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 2mm HORIZONTAL TERMINAL SURFACE MOUNT STRIP ASSEM DWG. NO. MMT-1XX-XX-XX-XX-XX-XXX-X-XX BY: DEAN P 12/12/2000 SHEET 2 OF 6 REVISION DH 50 01 CL 90° 02 .050 1.27 36/100 01 35/99 .100±.010 2.53±0.25 FIG 3 FIG 4 -MT: MIXED TECHNOLOGY (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) ((NO. OF POS. X .07874 [2.000])/2 - "E") POLARIZATION VIEW .010[0.25] .300 7.62 REF "E" .157 4.00 PIN A (-DH) PPP-13 .250 6.35 REF PIN A (-SH) PPP-13 -SH CL FIG 5 -P: PICK & PLACE PAD OPTION -DH * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\MMT-1XX-XX-XX-XX-XX-XXX-X-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SMATEC.com code 55322 DESCRIPTION: 2mm HORIZONTAL TERMINAL SURFACE MOUNT STRIP ASSEM DWG. NO. MMT-1XX-XX-XX-XX-XX-XXX-X-XX BY: DEAN P 12/12/2000 SHEET 3 OF 6 REVISION DH 90° "C" (SEE TABLE 2, SHT 1) "C" (SEE TABLE 2, SHT 1) "C" (SEE TABLE 2, SHT 1) .11 2.8 .050 1.27 .100 2.53 "D" (SEE TABLE 2, SHT 1) "D" (SEE TABLE 2, SHT 1) -SH -DH & MT .113 2.87 -MT -MT -DH FIG 7 FIG 6 IN-PROCESS 2 IN-PROCESS 1 -DH FIG 8 IN-PROCESS 3 "D" (SEE TABLE 2, SHT 1) .295 7.49 "D" (SEE TABLE 2, SHT 1) .295 7.49 -DH -DH FIG 9 IN-PROCESS 4 -MT -MT FIG 10 IN-PROCESS 5 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\MMT-1XX-XX-XX-XX-XX-XXX-X-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SMATEC.com code 55322 DESCRIPTION: 2mm HORIZONTAL TERMINAL SURFACE MOUNT STRIP ASSEM DWG. NO. MMT-1XX-XX-XX-XX-XX-XXX-X-XX BY: DEAN P 12/12/2000 SHEET 4 OF 6 REVISION DH FIG 12 POST TO RIGHT -TR TAPE AND REEL VIEW (DRAWING NOT DETAILED) ROUND HOLES .245 6.22 .245 6.22 OBLONG HOLES USER DIRECTION OF UN-REELING POCKET NOT DETAILED NOTE: PARTS MUST BE ORIENTED PER THE DESIGN OF THE POCKET TOOL. POCKETS DESIGNED AFTER REVISION BW MUST ORIENT PARTS PER THIS VIEW. -DH -MT FIG 11 IN-PROCESS 6 F:\DWG\MISC\MKTG\MMT-1XX-XX-XX-XX-XX-XXX-X-XX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SMATEC.com code 55322 DESCRIPTION: 2mm HORIZONTAL TERMINAL SURFACE MOUNT STRIP ASSEM DWG. NO. MMT-1XX-XX-XX-XX-XX-XXX-X-XX BY: DEAN P 12/12/2000 SHEET 5 OF 6 REVISION DH FIG 13 -T PLATING ONLY POST AREA (SEE NOTE 8) (SEE TABLE 4) C "C" REF (SEE TABLE 2, SHT 1) .075 1.905 REF NOTES: LOAD ALL PARTS (EXCEPT THOSE WITH -SH OPTION) POS 1 FIRST IN SAME DIRECTION AS ARROW. FOR 2 & 3 POSITIONS, TUBE PACKAGING ONLY AVAILABLE WITH -P OPTION. 2 & 3 POSITIONS WITHOUT -P OPTIONS MUST BE LAYER PACKAGED. ALL OTHERS, TUBE AS SHOWN. BANDOLIER REF TAIL AREA PACKAGE PARTS AS SHOWN FIG 14 -K: POLYIMIDE FILM PAD "R" (SEE NOTE ) .049±.020 1.25±0.51 .162 4.13 "S" (SEE NOTE ) .084 2.13 * .177 4.50 REF -SH NOTE: "R" = USED MEASURED DIMENSION (REF) "S" = {("R" - .177 [4.50]) / 2} ±.020 [0.51] -DH PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\MMT-1XX-XX-XX-XX-XX-XXX-X-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SMATEC.com code 55322 DESCRIPTION: 2mm HORIZONTAL TERMINAL SURFACE MOUNT STRIP ASSEM DWG. NO. MMT-1XX-XX-XX-XX-XX-XXX-X-XX BY: DEAN P 12/12/2000 SHEET 6 OF 6
MMT-107-02-S-SH-LC 价格&库存
很抱歉,暂时无法提供与“MMT-107-02-S-SH-LC”相匹配的价格&库存,您可以联系我们找货
MMT-107-02-S-SH-LC
  • 40+24.2433940+3.13206
