MNT-118-BK-G
MNT-118-BK-G
    SAMTEC(申泰)
MNT-118-BK-G 数据手册
SHUNTS & JUMPERS (2.54 mm) .100" PITCH • SNT/MNT/2SN/SNM/PK/JL SERIES SNT/MNT Mates: TSW, HTSW, MTSW, HMTSW, TLW, DW, EW, ZW, HW, TSM, BST, PHT - SNT 100 - BODY COLOR –BK Mates: TMMH, TMM, MTMM, MMT, TW, LTMM, ZLTMM, TSH, EHT = Red –BL Mates: TMS, MTMS, DWM = Tin (14.00) .550 (6.10) .240 A (0.64) .025 DIA REF (3.18) .125 (2.54) .100 Note: Other Gold plating options available. SNT Insulator Material: Glass Filled Polyester Contact Material: Phosphor Bronze Current Rating (SNT/TSW): 4.3 A per pin (1 pin powered per row) Operating Temp Range: -55 °C to +125 °C (Gold) -55 °C to +105 °C (Tin) Insertion Depth: (4.32 mm) .170" minimum Lead Size accepted: (0.64 mm) .025" SQ Insulation is white Teflon® = Yellow (5.08) .200 SPECIFICATIONS –H = Handle (Black Only) –YW (6.10) .240 JL HANDLE OPTION –T = Blue SNM - = 10 µ" (0.25 µm) Gold –RD (2.54) .100 PLATING OPTION –G = Black 2SN - MNT - - NO. OF POSITIONS 1 02 thru 20 BODY COLOR –BK = Black - PLATING OPTION –G = 10 µ" (0.25 µm) Gold –T = Tin MNT (5.08) .200 Same as SNT except: Current Rating (MNT/TSM): 3.9 A per pin (1 pin powered per row) Working Voltage: 450 VAC PART NO. A JL–100–25–T (2.54) .100 JL–250–25–T (6.35) .250 JL–400–25–T (10.16) .400 Note: For complete specifications see www.samtec.com?JL (2.54) .100 X No. of Positions 2SN PK (6.10) .240 Same as SNT except: Insertion Depth: (2.29 mm) .090" minimum Lead Size accepted: (0.51 mm) .020" SQ Note: Some lengths, styles and options are non-standard, non-returnable. B SNM Same as SNT except: Insertion Depth: (3.43 mm) .135" minimum Max Processing Temp: Not recommended for IR/VP 2SN SNM A PART NO. (1.27) .050 (3.99) .157 (1.02) .040 (3.30) .130 A B PK–01–06 (0.64) (5.84) .025 .230 SQ PK–01–07 (0.51) (3.18) .020 .125 SQ PART NO. (4.45) .175 2SN-BK-G PART NO. SNM-100-BK-G (2.00) .0787 F-224 (Rev 07FEB24) Insulator Material: Natural Thermoplastic Note: Order per wheel. 6 pins per wheel. samtec.com?SNT, samtec.com?MNT, samtec.com?2SN or samtec.com?SNM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MNT-118-BK-G 价格&库存
很抱歉,暂时无法提供与“MNT-118-BK-G”相匹配的价格&库存,您可以联系我们找货
