MPT-04-01-03-L-RA-LC 数据手册
HIGH POWER SYSTEMS
20-60 A
p er bla de
FEATURES & BENEFITS
• Current Rating: 23 A - 58.7 A per power blade
• 3.81 mm, 5.00 mm and 6.35 mm pitch
• Dual blade contact system
• Power only or power/signal combinations available
• Right-angle and vertical orientations
• Rugged screw down and locking clip options
• Discrete wire cable assemblies with 10-16 AWG wire
(see pages 246-248)
• “Hinged” for unique mating in any orientation
from 0° to 90° and space confined applications
CREEPAGE & CLEARANCE
Hermaphroditic options
samtec.com?MPPT and
samtec.com?UPPT
Hinging options available
samtec.com?FMPT and
samtec.com?FMPS
PITCH
CREEPAGE
CLEARANCE
UPT/UPS/UPPT
5.50 mm
1.51 mm
MPT/MPS/MPTC/MPSC
2.95 mm
2.71 mm
PET/PES/PETC/PESC
3.66 mm
3.31 mm
Selectively loading contacts achieves customer specific
creepage and clearance requirements.
KEY SPECIFICATIONS
SERIES
SERIES
INSULATOR CONTACT
MATERIAL MATERIAL
PLATING
OPERATING
TEMP RANGE
CURRENT RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
UPT/UPS
(3.81 mm)
.150"
Black LCP
BeCu
Sn or Au over
-55 ºC to +105 ºC (Sn)
50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au)
23 A
(1 pin powered)
438 VAC
Yes
UPPT
(3.81 mm)
.150"
Black LCP
Copper Alloy
Sn or Au over
21.4 A
(1 pin powered)
425 VAC
Yes
MPT/MPS
(5.00 mm)
.1969"
Black LCP
Copper Alloy
Sn or Au over
28.8 A
(1 pin powered)
575 VAC
Yes
(5.00 mm)
.197" (pwr)
MPTC/MPSC (2.00 mm)
.079" (sig)
Black LCP
Signal:
Phosphor
Sn or Au over
Bronze
Terminal:
Copper Alloy
28.8 A
(pwr - 1 pin powered)
5A
(sig - 4 pins powered)
250 VAC
Yes
PET/PES
(6.35 mm)
.250"
Black LCP
Copper Alloy
Sn or Au over
58.7 A
(1 pin powered)
450 VAC
Yes
PETC/PESC
(6.35 mm)
.250" (pwr)
(2.54 mm)
.100" (sig)
Black LCP
Copper Alloy
Sn or Au over
31.4 A
5.7 A
650 VAC (pwr)
450 VAC (sig)
Yes
F-224
samtec.com/PowerStrip
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(5.00 mm) .1969" PITCH • 30 A DUAL BLADE/LEAF SYSTEMS
SERIES
MPT
POWER
PINS
–02,
–03, –04,
–06, –08
Terminal
MPS
LEAD
STYLE
–6.30
Socket
TAIL LENGTH
–01
= (6.30 mm) 0.248" (MPT only)
= Use with (1.60 mm) .062" Thick PCB
–7.70
= Use with (2.36 mm) .093" Thick PCB
–03
= (7.70 mm) 0.303" (MPS only)
–L
TAIL
(Required
Callout)
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–V
= Vertical
–T
= Matte Tin
1RRISRVLWLRQV[
MPT
PLATING
OPTION
Board Mates:
MPS
Cable Mates:
MPSS
A
–01
(2.72) .107
–03
(3.51) .138
MATED HEIGHT
1RRISRVLWLRQV[
MPS
TAIL
LENGTH
MPS
13.81 mm
MPT
Board Mates:
MPT
TAIL
LENGTH
View complete specifications at: samtec.com?MPT & samtec.com?MPS
SERIES
MPT
Terminal
MPS
Socket
POWER
PINS
–02, –04,
–06, –08
01
TAIL LENGTH
–01
–03
–01
(2.72) .107
–03
(3.52) .139
RA
SD
–L
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
–T
= Matte Tin
MPT-RA
Board Mates:
MPS
Cable Mates:
MPSS
PLATING OPTION
A
1RRISRVLWLRQV[
TAIL
LENGTH
A
–01
(2.72) .107
–03
(3.51) .138
TAIL
LENGTH
A
MPS-RA
1RRISRVLWLRQV[
Board Mates:
MPT
–01
(2.72) .107
–03
(3.52) .139
Note:
Some lengths, styles and
options are non-standard,
non-returnable
F-224
MPT-04-01-03-L-RA-LC 价格&库存
很抱歉,暂时无法提供与“MPT-04-01-03-L-RA-LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+39.72240
- 192+15.85440
- 512+15.32520
- 1024+15.06600
