MTLW-102-07-SM-S-280 数据手册
F-218
MTLW–130–05–G–S–110
TLW–118–06–T–D
(2.54 mm) .100"
TLW, MTLW SERIES
LOW-PROFILE .025" SQ POST HEADERS
Board Mates:
BSW, CES, SLW, HLE
1
TLW
Cable Mates:
SMSD, SMSS
NO. PINS
PER ROW
PLATING
OPTION
Specify
LEAD STYLE
from chart
= Gold flash
on post,
Matte Tin
on tail
= Single
Row
–G
= Double
Row
–F
FEATURES
01 thru 40
These headers provide
= Single Row
the ultimate low-profile
(0.64 mm) .025" square
(2.54) .100 x No. of Positions
post board stacking
system. The
40
01
high quality
(2.54)
TLW
.100
Phosphor
(6.60)
TYP
CES = .260
Bronze
terminals
(6.09)
SLW =
.240
are available
with a
= Double Row
standard short
post height
02
72
(TLW Series) for mating
(2.54)
with low-profile sockets,
.100
or the post height can be
Modified (MTLW Series)
01
71
to accommodate IDC
assemblies and other
applications.
(1.52)
.060
(2.48)
.098
01 thru 36
SPECIFICATIONS
MTLW
For complete specifications
see www.samtec.com?TLW or
www.samtec.com?MTLW
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (TLW/SLW):
5.2 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +105 °C with Tin
-55 °C to +125 °C with Gold
RoHS Compliant:
Yes
Lead–Free Solderable:
Yes
1
C
C
(3.05)
.120
(1.52)
.060
A
(0.64)
.025
–01
–05 & –06
(5.03)
.198
ROW
OPTION
LEAD
STYLE
LEAD
STYLE
A
C
– 01
N/A
– 05
(4.32)
.170
(3.43)
.135
(5.84)
.230
(2.67)
.105
(2.67)
.105
– 06
= 10 µ"
(0.25 µm)
Gold on post,
Gold flash
on tail
–S
–D
OTHER
OPTION
–RA
= Right-angle
(–01 Lead
Style only)
–“XX”
= Polarized
Position
Specify
position for
omitted pin.
–T
= Matte Tin
ALSO AVAILABLE
(MOQ Required)
• Other platings
Contact Samtec.
NO. PINS
PER ROW
01 thru 40
LEAD
STYLE
PLATING
OPTION
Specify
LEAD STYLE
from chart
= Single Row
ROW
OPTION
POST
HEIGHT
–S
–“XXX”
= Single Row
–D
= Post Height
Dimension
(In inches)
= Double Row
POST
(0.00) .000
MIN
40
(2.54)
.100
TYP
01
(2.48)
.098
01 thru 36
RECOGNITIONS
02
72
–06
(5.03)
.198
FILE NO. E111594
(2.54)
.100
Note:
Some lengths, styles and
options are non-standard,
non-returnable. MTLW Series
is non-standard, non-returnable.
01
(0.64) .025 SQ
TAIL
(0.00) .000
MIN
LEAD
STYLE
– 05
= Double Row
For complete scope of
recognitions see
www.samtec.com/quality
(OAL)
71
–07
–08
–09
(1.52)
.060
–10
–22
–23
–24
OAL
(8.51)
.335
(7.62)
.300
(10.92)
.430
(13.46)
.530
(18.54)
.730
(21.08)
.830
(16.00)
.630
(11.30)
.445
(12.19)
.480
–F
= Gold flash on post,
Matte Tin on tail
–L
= 10 µ" (0.25 µm) Gold on post,
Matte Tin on tail
–G
Gold flash on tail
–T
= Matte Tin
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
MTLW-102-07-SM-S-280 价格&库存
很抱歉,暂时无法提供与“MTLW-102-07-SM-S-280”相匹配的价格&库存,您可以联系我们找货
