MTMM-130-03-G-Q-000
MTMM-130-03-G-Q-000
    SAMTEC(申泰)
    插件,P=2mm
    排针 间距:2mm 插件
MTMM-130-03-G-Q-000 数据手册
F-218 MTMM–108–07–F–D–350 MTMM–114–05–F–Q–235 MTMM–124–15–T–S–650 (2.00 mm) .0787" MTMM SERIES MODIFIED THROUGH-HOLE HEADER Choice of single, double or quad row Board Mates: CLT, SQT, SQW, ESQT, TLE, SMM, MMS SPECIFICATIONS For complete specifications see www.samtec.com?MTMM Cable Mates: TCSD Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold RoHS Compliant: Yes Lead–Free Solderable: Yes Specify post height in (0.13 mm) .005" increments RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality (2.00 mm) .0787" pitch FILE NO. E111594 NO. PINS 1 PER ROW MTMM ALSO AVAILABLE 01 thru 50 (MOQ Required) • Other platings Contact Samtec. LEAD STYLE PLATING OPTION ROW OPTION Specify LEAD STYLE from chart. –F = Single Row = Gold flash on post, Matte Tin on tail –L (2.00) .0787 No. of positions x (2.00) .0787 50 01 02 100 = 10 µ" (0.25 µm) Gold post, Matte Tin on tail –Q Example: –070 = (1.78 mm) .070" = Quad Row LEAD STYLE 196 200 (6.00) .236 (8.00) .315 01 05 195 197 (0.50) .020 SQ (1.50) .059 (2.00) .0787 (0.00) .000 MIN POST HEIGHT OAL (2.00) .0787 Note: This Series is non-standard, non-returnable. –D = Double Row –T –“XXX” = Post Height in inches (0.13 mm) .005" increments 99 04 08 –S –D (0.00) .000 MIN –Q – 02 –03 –04 –05 –06 –07 –08 –09 –10 –11 –12 –13 –14 –15 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM OPTION –S = Matte Tin (3.94) .155 01 POST HEIGHT All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. OAL (6.48) .255 (7.67) .302 (8.20) .323 (9.58) .377 (10.08) .397 (11.58) .456 (12.09) .476 (13.59) .535 (14.10) .555 (15.09) .594 (15.60) .614 (17.09) .673 (19.08) .751 (21.08) .830 –“XXX” = Polarized Position Specify position of omitted pin
MTMM-130-03-G-Q-000 价格&库存
很抱歉,暂时无法提供与“MTMM-130-03-G-Q-000”相匹配的价格&库存,您可以联系我们找货
