S1SS-05-28-GF-20.00-S
    SAMTEC(申泰)
S1SS-05-28-GF-20.00-S 数据手册
F-214 (Rev 05AUG14) S1SST–20–28–GF–03.00–D S1SS–20–28–GF–03.00–D (1,00 mm) .03937" S1SS, S1SST SERIES MICRO CABLE ASSEMBLY SPECIFICATIONS Mates with: T1M For complete specifications see www.samtec.com?S1SS or www.samtec.com?S1SST Insulator Material: Nylon Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -10°C to +85°C Current Rating: 3.3 A per pin (1 pin powered) Voltage Rating: 250 VAC/353 VDC Wire: 28 or 30 AWG RoHS Compliant: Yes *DuPont™ Teflon ® is a registered trademark of the E.I. du Pont de Nemours and Company or its affiliates. 28 AWG or 30 AWG Choice of single or double ended (1,00 mm) .0394" pitch TYPE STRIP NO. OF POSITIONS WIRE GAUGE PLATING OPTION ASSEMBLED LENGTH –30 –GF = 30 AWG = 3µ" (0,07 µm) Gold, 50µ" (1,27 µm) Ni on contact and tail –“XX.XX” –S = Assembled Length in Inches (45,72 mm) 01.80" min. = Single Ended (Requires –D option) –D = No Latch, “N” up, straight END OPTION END 2 OPTION RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality S1SS = Single Row PVC Cable S1SST ALSO AVAILABLE (MOQ Required) = Single Row ® *Teflon Cable (28 AWG only) –02, –03, –05, –07, –10 –15, –20 –28 = 28 AWG (Standard Sizes) = Double Ended –T • Other sizes • Color coded cable (*Teflon® N/A) Contact Samtec. (1,00) .03937 (2,80) .110 (5,00) .197 Note: Teflon ® cable is intended for crimp only. Contact Samtec for solderable cable applications. Assembly Length ±(3,18) .125 Assembly Length ±(3,18) .125 –S –NDS = No Latch, “N” down, straight = Tin No. of positions x (1,00) .03937 + (1,20) .047 –NUS –D–NUS Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –D–NDS
S1SS-05-28-GF-20.00-S 价格&库存
很抱歉,暂时无法提供与“S1SS-05-28-GF-20.00-S”相匹配的价格&库存,您可以联系我们找货
