Emboss Tape
ZH CONNECTOR
1.5mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
The ZH connector is very small with a
mounting height of 5.6mm and a thickness
of only 3.5mm. Contact retention lances on
the housing make insertion easier, while the
dimple at the center of the contact ensures
reliable contact with the post.
• Compact, low profile design
• Housing lances
• Reliable contact construction
• Distortion resistant construction
• Compatible with the ZR insulation
displacement connectors
• Current rating: 1.0A AC, DC (AWG #26)
• Voltage rating: 50V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/20m Ω max.
After environmental testing/30m Ω max.
• Insulation resistance:
500M Ω min.
• Withstanding voltage: 500V AC/minute
• Applicable wire: AWG #32 to #26
• Applicable PC board thickness: 0.6 to 1.2mm,1.6mm
* RoHS compliant products are published.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
2 R9351092
PC board layout and Assembly layout
〈Through-hole type (viewed from soldering side) 〉
Top entry type
Side entry type
1.5 ±0.05 1.5 min
1.5 ±0.05 1.5 min
3.5
2.7
3.7
(3.4)
5.6
4.6 min
2.2 min
7.1
2.7
(3.4)
φ0.7 ±0.03
4.6
φ0.7 ±0.03
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Hole dimension differ according to the kind of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should
be larger. The dimensions above should serve as a guideline. Contact JST for details.
〈SMT type (viewed from component side) 〉
SM2 type
Side entry type
SM4 type
Top entry type
Side entry type
±0.1
1.5 ±0.05 1.3
1.5 ±0.1
±0.1
1.5 ±0.05 1.4
1.1 ±0.1
0.7 min
Note: 1. N...Number of circuits
2. Tolerances are non-cumulative: ±0.05mm for all centers.
3. The dimensions above should serve as a guideline. Contact JST for details.
16
1.9 ±0.1
1.4 ±0.1
2.3 ±0.1
2.5 max
φ1.1 +0.1
0.7 min
4.3
0.9 ±0.05
0.6
±0.05
2.0
0.7min 1.5
2.0 min
1.5× (N-1)+0.9
ZH CONNECTOR
Contact
4.0
Model No.
2.2
0.5
1.0
1.4
1.1
Applicable wire
AWG#
Insulation O.D. (mm)
mm2
SZH-002T-P0.5
SZH-003T-P0.5
Q'ty /
reel
0.08 ∼0.13
28∼26
0.8∼1.1
13,000
0.032∼0.08
32∼28
0.5∼0.9
16,000
1.5
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
0.3
RoHS compliance
Applicator
Dies
Crimp applicator with dies
MKS-L
MK/SZH-002-05
APLMK SZH002-05
Crimping
machine Crimp applicator
Contact
SZH-002T-P0.5
AP-K2N
Applicator
Dies
MKS-L
MK/SZH-003-05
APLMK SZH003-05
*MKS-SC
SC/SZH-003-05
APLSC SZH003-05
Crimping
Contact
SZH-003T-P0.5
AP-K2N
Note: *Strip-crimp applicator.
Housing
B
1.5
Circuits
Model No.
2
ZHR-2
ZHR-3
ZHR-4
ZHR-5
ZHR-6
ZHR-6(3.0)
ZHR-7
ZHR-8
ZHR-9
ZHR-10
ZHR-11
ZHR-12
ZHR-13
3
3.4
4
A
1.5
0.3
5
6
6
6
5
3
2
1
4.2
7
8
9
0.3
10
11
12
13
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
A
Dimensions (mm)
B
Q'ty /
bag
1.5
4.5
1,000
3.0
6.0
1,000
4.5
7.5
1,000
6.0
9.0
1,000
7.5
10.5
1,000
15.0
18.0
1,000
9.0
12.0
1,000
10.5
13.5
1,000
12.0
15.0
1,000
13.5
16.5
1,000
15.0
18.0
1,000
16.5
19.5
1,000
18.0
21.0
1,000
Material
PA 66, UL94V-0, natural (white)
RoHS compliance
Note: 1. ZHR-6(3.0) is 6 circuits 3.0mm pitch plugged up.
As for this housing, only circuit No.1 is marked.
2. ZHR-6(3.0) is not UL/CSA/TÜV approved.
ZHR-2-oo(blank)…natural (white)
K…black R…red E…blue M…green
Through-hole type shrouded header
Circuits Top entry
type
(2 circuits)
B
(3 circuits or more)
B
3.5
2
3.5
3
4.5
4.5
4
5
6
φ0.5
2.7
Note) 3.4
2.2
2.7
Note) 3.4
7
A 1.5
1.5
A
1.5
2.2
8
9
10
11
12
Side entry type
13
B
B2B-ZR
B3B-ZR
B4B-ZR
B5B-ZR
B6B-ZR
B7B-ZR
B8B-ZR
B9B-ZR
B10B-ZR
B11B-ZR
B12B-ZR
B13B-ZR
Side entry
type
Note)
Note)
Top entry type
S2B-ZR
S3B-ZR
S4B-ZR
S5B-ZR
S6B-ZR
S7B-ZR
S8B-ZR
S9B-ZR
S10B-ZR
S11B-ZR
S12B-ZR
S13B-ZR
B2B-ZR-3.4
B3B-ZR-3.4
B4B-ZR-3.4
B5B-ZR-3.4
B6B-ZR-3.4
B7B-ZR-3.4
B8B-ZR-3.4
B9B-ZR-3.4
B10B-ZR-3.4
B11B-ZR-3.4
B12B-ZR-3.4
B13B-ZR-3.4
Q'ty / box
Top entry Side entry Side entry
type
type type-3.4
Side entry type
A
B
S2B-ZR-3.4
S3B-ZR-3.4
S4B-ZR-3.4
S5B-ZR-3.4
S6B-ZR-3.4
S7B-ZR-3.4
S8B-ZR-3.4
S9B-ZR-3.4
S10B-ZR-3.4
S11B-ZR-3.4
S12B-ZR-3.4
S13B-ZR-3.4
1.5
4.5 2,000 2,000 2,000
3.0
6.0 2,000 2,000 1,000
4.5
7.5 2,000 2,000 2,000
6.0
9.0 2,000 1,000 1,000
7.5 10.5 2,000 1,000 1,000
9.0 12.0 1,000 1,000 1,000
10.5 13.5 1,000 1,000 1,000
12.0 15.0 1,000 1,000 1,000
13.5 16.5 1,000 1,000 1,000
15.0 18.0 1,000
500
500
16.5 19.5 1,000
500
500
18.0 21.0
500
500
500
1.5
1.5
4.6
1.4
2.7
Note) 3.4
2.4
3.7
Material and Finish
H JST
φ0.5
A
Dimensions (mm)
Model No.
Top entry type
Pin: Brass, copper-undercoated, tin-plated (reflow treatment)
Wafer: Glass-filled PA 66, UL94V-0, natural (ivory)
RoHS compliance This product displays (LF)(SN) on a label.
Note: Headers with 3.4mm long solder tails, suited for the 1.6mm thick PC
board.
ex. B2B-ZR-3.4-oo(blank)…natural (ivory)
17
ZH CONNECTOR
SMT type shrouded header
SM2 type
SM2 type
Side entry type
Model No.
Side entry type
S2B-ZR-SM2-TF
S3B-ZR-SM2-TF
S4B-ZR-SM2-TF
S5B-ZR-SM2-TF
S6B-ZR-SM2-TF
S7B-ZR-SM2-TF
S8B-ZR-SM2-TF
S9B-ZR-SM2-TF
S10B-ZR-SM2-TF
S11B-ZR-SM2-TF
S12B-ZR-SM2-TF
S13B-ZR-SM2-TF
Circuits
2
3
4
5
B
A
5.0
1.5
1.5
1.0
1.5
6
7
8
3.7
9
10
HJST
1.5
11
12
φ1.0
0.9
13
Dimensions (mm)
A
B
Q'ty /
reel
1.5
4.5
1,000
3.0
6.0
1,000
4.5
7.5
1,000
6.0
9.0
1,000
7.5
10.5
1,000
9.0
12.0
1,000
10.5
13.5
1,000
12.0
15.0
1,000
13.5
16.5
1,000
15.0
18.0
1,000
16.5
19.5
1,000
18.0
21.0
1,000
Material and Finish
Wafer: Glass-filled PA 46, UL94V-0, natural (ivory)
SM4 type
SM4 type (with solder tabs)
Top entry type
B
A
Model No.
2
2.25
3
5.0
1.5
4
3.7
5
6
HJST
7
1.5
8
9
Side entry type
10
11
B
A
Dimensions (mm)
Circuits
5.0
2.25
1.5
1.5
1.0
12
13
Q'ty / reel
type
type
Top entry type
Side entry type
A
B
B2B-ZR-SM4-TF
B3B-ZR-SM4-TF
B4B-ZR-SM4-TF
B5B-ZR-SM4-TF
B6B-ZR-SM4-TF
B7B-ZR-SM4-TF
B8B-ZR-SM4-TF
B9B-ZR-SM4-TF
B10B-ZR-SM4-TF
B11B-ZR-SM4-TF
B12B-ZR-SM4-TF
B13B-ZR-SM4-TF
S2B-ZR-SM4A-TF
S3B-ZR-SM4A-TF
S4B-ZR-SM4A-TF
S5B-ZR-SM4A-TF
S6B-ZR-SM4A-TF
S7B-ZR-SM4A-TF
S8B-ZR-SM4A-TF
S9B-ZR-SM4A-TF
S10B-ZR-SM4A-TF
S11B-ZR-SM4A-TF
S12B-ZR-SM4A-TF
S13B-ZR-SM4A-TF
1.5
6.0
1,000
1,000
3.0
7.5
1,000
1,000
4.5
9.0
1,000
1,000
6.0
10.5
1,000
1,000
7.5
12.0
1,000
1,000
9.0
13.5
1,000
1,000
10.5
15.0
1,000
1,000
12.0
16.5
1,000
1,000
13.5
18.0
1,000
1,000
15.0
19.5
1,000
1,000
16.5
21.0
1,000
1,000
18.0
22.5
1,000
1,000
3.7
Material and Finish
Wafer: PA 6T, UL94V-0, natural (ivory)
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
HJST
Note: 1. The products listed above are supplied on embossed-tape.
2. Contact JST for the top entry type headers with suction cap.
ex.
18
S2B-ZR-SM4A-oo-TF(blank)…natural (ivory)
ZH CONNECTOR
Taping specifications ––––––––––––––––––––––––––––––––––––––––––––––––––––––
Feeding direction
φ330±2.0
Feeding direction
Carrier tape
Cover tape leader
Leader part
100min.
The end part Connector
400min.
160min. mounting part
(φ13)
W1+2.5
–1.0
2.0±0.5
SM2 type
(Side entry type) 2 to 11 circuits
SM4 type
(Side entry type) 2 to 10 circuits
Feeding direction
φ1.55±0.05
4.0±0.1 2.0±0.1
φ1.55±0.05
1.75±0.1
Feeding direction
4.0±0.1
2.0±0.1
1.75±0.1
SM2 type
(Side entry type) 12 to 13 circuits
SM4 type
(Side entry type) 11 to 13 circuits
Cover tape
F±0.1
F±0.1
W±0.3
(S)
S±0.1
W±0.3
Cover tape
Carrier tape
Carrier tape
12.0±0.1
12.0±0.1
SM4 type
(Top entry type)
2 to 10 circuits
SM4 type
(Top entry type)
11 to 13 circuits
φ1.55±0.05
4.0±0.1 2.0±0.1
Cover tape
F±0.1
(S)
Carrier tape
Carrier tape
12.0±0.1
12.0±0.1
Taping dimensions (mm)
Circuits
Reel dimensions
(mm)
Q'ty /
reel
F
S
W
W1
Side
SM2 entry 7 to 11
Type type
12 to 13
7.5
6.75
16.0
17.5
1,000
11.5
10.75
24.0
25.5
1,000
14.2
28.4
32.0
33.5
1,000
2
5.5
4.75
12.0
13.5
1,000
3 to 5
7.5
6.75
16.0
17.5
1,000
6 to 10
11.5
10.75
24.0
25.5
1,000
11 to 12
14.2
28.4
32.0
33.5
1,000
13
20.2
40.4
44.0
45.5
1,000
2 to 5
7.5
6.75
16.0
17.5
1,000
6 to 10
11.5
10.75
24.0
25.5
1,000
11 to 12
14.2
28.4
32.0
33.5
1,000
13
20.2
40.4
44.0
45.5
1,000
2 to 6
Top
entry
type
SM4
Type
Side
entry
type
S±0.1
W±0.3
Cover tape
F±0.1
W±0.3
4.0±0.1 2.0±0.1
1.75±0.1
φ1.55±0.05
1.75±0.1
Feeding direction
Feeding direction
Note:
1. Specifications conform to JIS C 0806. The tape width, connector recess
dimensions, etc. are determined by the number of circuits and external
shape of the connector to be loaded.
2. Specifications are subject to change without prior notice.
